  • 2057阅读
  • 11回复
如何理解和分析,RBN台的解码数据? [复制链接]
离线bd4lb
只看楼主 倒序阅读 0楼 发表于: 2024-07-13
非常感谢,国内的RBN解码台。
我发射的CW信号,知道了它跳跃的距离。
但是,如何分析跳跃的次数,我还没有搞明白。
(我知道,不会是距离的倍数关系。)
哪位先生,能帮我科普一下吗?
先谢谢啦!
以下是,我发射6瓦功率的信号,国内RBN台的解码数据。
● Spotter (de)● Spotted (dx)callsign● spotter ● spotted distance mifreqmodetypesnrspeedtimeseen
 BI4SSB  BD4LB288 mi7030.0CWCQ17 dB20 wpm1003z 13 Jul10 minutes ago
 BI4MPH-1  BD4LB117 mi7030.0CWCQ11 dB20 wpm1003z 13 Jul10 minutes ago
BI4SSB  BD4LB288 mi7030.0CWCQ11 dB20 wpm0953z 13 Jul20 minutes ago
 BH4XDZ  BD4LB120 mi7030.0CWCQ15 dB20 wpm0953z 13 Jul20 minutes ago
BG4GOV  BD4LB364 mi7030.0CWCQ10 dB20 wpm0953z 13 Jul20 minutes ago
 BH4XDZ  BD4LB120 mi7030.0CWCQ17 dB20 wpm0943z 13 Jul30 minutes ago
BH4RXP  BD4LB318 mi7030.0CWCQ5 dB19 wpm0943z 13 Jul30 minutes ago
BI4MPH-1  BD4LB117 mi7030.0CWCQ4 dB20 wpm0938z 13 Jul35 minutes ago
BG4GOV  BD4LB364 mi7030.0CWCQ11 dB20 wpm0938z 13 Jul35 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ13 dB20 wpm0933z 13 Jul40 minutes ago
BI4MPH-1  BD4LB117 mi7030.0CWCQ8 dB20 wpm0928z 13 Jul45 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ14 dB20 wpm0923z 13 Jul50 minutes ago
BG4GOV  BD4LB364 mi7030.0CWCQ5 dB20 wpm0918z 13 Jul55 minutes ago
BI4MPH-1  BD4LB117 mi7030.0CWCQ10 dB20 wpm0918z 13 Jul55 minutes ago
BI4SSB  BD4LB288 mi7030.0CWCQ5 dB20 wpm0913z 13 Jul60 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ14 dB19 wpm0913z 13 Jul60 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ15 dB20 wpm0908z 13 Jul65 minutes ago
BH4RXP  BD4LB318 mi7030.0CWCQ14 dB19 wpm0905z 13 Jul68 minutes ago
BI4MPH-1  BD4LB117 mi7030.0CWCQ10 dB20 wpm0905z 13 Jul68 minutes ago
BG4GOV  BD4LB364 mi7030.0CWCQ5 dB20 wpm0905z 13 Jul68 minutes ago
BG4GOV  BD4LB364 mi7030.0CWCQ10 dB20 wpm0853z 13 Jul80 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ11 dB20 wpm0848z 13 Jul85 minutes ago
BI4SSB  BD4LB288 mi7030.0CWCQ7 dB20 wpm0838z 13 Jul95 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ11 dB20 wpm0833z 13 Jul100 minutes ago  BI4MPH-1  BD4LB117 mi7030.0CWCQ10 dB20 wpm0818z 13 Jul115 minutes ago
BH4XDZ  BD4LB120 mi7030.0CWCQ18 dB20 wpm0818z 13 Jul115 minutes ago
BH4RXP  BD4LB318 mi7030.0CWCQ17 dB20 wpm0813z 13 Jul2 hours ago
BI4RFP-YZ  BD4LB118 mi7030.0CWCQ3 dB20 wpm0758z 13 Jul2 hours ago
BG4GOV  BD4LB364 mi7030.0CWCQ4 dB20 wpm0738z 13 Jul2 hours ago
BG4GOV  BD4LB364 mi7030.0CWCQ4 dB20 wpm0653z 13 Jul3 hours ago
BH4RXP  BD4LB318 mi7030.0CWCQ7 dB20 wpm0648z 13 Jul3 hours ago
BH4RXP  BD4LB318 mi7030.0CWCQ13 dB20 wpm0618z 13 Jul3 hours ago
BH4RXP  BD4LB318 mi7030.0CWCQ9 dB20 wpm0553z 13 Jul4 hours ago
BH4RXP  BD4LB318 mi7030.0CWCQ10 dB20 wpm0542z 13 Jul4 hours ago
 BH4RXP  BD4LB318 mi7030.0CWCQ13 dB20 wpm0517z 13 Jul4 hours ago
 BH4RXP  BD4LB318 mi7030.0CWCQ7 dB20 wpm0458z 13 Jul5 hours ago
BH4RXP  BD4LB318 mi7030.0CWCQ13 dB20 wpm0442z 13 Jul5 hours ago
BI4SSB  BD4LB288 mi7030.0CWCQ7 dB20 wpm0337z 13 Jul6 hours ago
Version: v2.2.5
只看该作者 1楼 发表于: 2024-07-15
怎么理解?反正你的信号没有跳出4区
离线bd4lb
只看该作者 2楼 发表于: 2024-07-15
@BD8CS
谢谢留言!
有时候,能被日本的RBN台解码~
个别时候,被您的RBN解码了。
这次测试,只有这些解码台的数据。
RBN解码台,数量不足,分布也不均匀……
只能参考~
以前,在清晨,在7兆,CW模式,我用4瓦功率,通联过一次欧洲台。
实际的通联,和被RBN解码,并不是同时存在的。
有几次,在7.003兆,我用QRP呼叫,通联过日本台。
然后,查看RBN,并没有被解码的数据。
本帖提到的人: @BD8CS
离线liute
只看该作者 3楼 发表于: 2024-07-16
我觉得通信就象个弹弓子,打哪指哪,能打到哪都不意外,分析我是不做的,比如通到某个台是几跳之类的,因这分析也不会让我打得更远。要想通得远,得换个更大的弹弓。
辽宁沈阳 BG2QMO
期待与您通联,来卡必回。
离线bd4lb
只看该作者 4楼 发表于: 2024-07-16
@liute
谢谢留言!
明白您的意思。
我是希望,通过分析数据,找到改进天线系统的方法。
跳跃次数,对于小功率通联,太重要了。
弹弓的比喻,有点儿意思。哈哈哈~
本帖提到的人: @liute
在线BA5CW
只看该作者 5楼 发表于: 2024-07-16
从你的数据看,没有超出一跳,40m一跳可以到1500KM以上,然而你这些台的距离说明你的辐射仰角比较高,大部分能量并不足以通过更低的仰角跳更远,更何况第二第三跳的更大衰减。
另外,RBN台一般是全向的简单天线,代表一个比较平均的水平,还有的RBN接收环境未必好,所以RBN没有数据未必代表直接通联不可能,参与直接通联的台有可能天线和接收环境远比RBN的台好。
离线bd4lb
只看该作者 6楼 发表于: 2024-07-16
@BA5CW
谢谢留言!
看来,被日本台解码,才算是第一次跳跃。
国内4区的解码,只能是近距离传播。
明白了。
本帖提到的人: @BA5CW
离线bd4lb
只看该作者 7楼 发表于: 2024-07-18
在7.0386兆,我发射200毫瓦左右的wspr beacon,被日本台解码更容易,也更稳定一些。
CW模式的RBN解码台,还是没有wspr解码台的数量多。
分析wspr的被解码数据,更容易知道,DX传播的准确开通时间。
今天,7兆的DX传播,1500公里左右,开通时间是UTC0920。
离线bh5hzg
只看该作者 8楼 发表于: 2024-07-19
回 bd4lb 的帖子
bd4lb:在7.0386兆,我发射200毫瓦左右的wspr beacon,被日本台解码更容易,也更稳定一些。
.. (2024-07-18 17:58)
DX有准确的开通时间吗?
我的感觉是传播是逐步变化的, 不是开关一样开通和关闭, 即使WSPR能解码, 但是CW解不了, 或者CW能听清, SSB不行, 所以WSPR的信标数据仅对WSPR有用, 不能指导CW和SSB 。
RIG:IC-705, IC-7300
ANT:gp,  4band inverte V
GRID:PM00EG
Freq:7019/14019/21019/28019 kHz
qq:435022441
Email:bh5hzg@163.com
SKCC number:26449
离线bd4lb
只看该作者 9楼 发表于: 2024-07-20
@bh5hzg
谢谢留言!
在7.0386兆,我用wspr beacon测试的发射功率,最大是1瓦。
目前,通常使用100毫瓦,或者,200毫瓦左右。
发射持续的时间,一般10个小时左右。
每次发射的间隔时间10分钟。
例如,从上午8点,持续到 晚上22点。发射功率200毫瓦。
第一次看到解码数据,是被日本台解码,在BJT17:09。然后,解码数据就越来越多了。
17:09之前,是没有解码数据的。
这个现象,我觉得,传播的开通,可能是比较快的。就像是,打开了开关。
参加CW比赛的时候,从BJT17:00开始,我会在7兆,注意收听有没有出现北美洲的信号……
不同的地区,不同的季节,开通DX的时间,有差别~~
上海和青岛,就是不一样的~
以前,为了测试RBN,在7兆,CW模式,我用20瓦功率呼叫~
偶尔,可以被N6TV的RBN台,解码。
wspr模式,适合用微功率,远距离传输信号……
这是以前没有的通信技术~
本帖提到的人: @bh5hzg
离线bh5hzg
只看该作者 10楼 发表于: 2024-07-21
回 bd4lb 的帖子
bd4lb:@bh5hzg
谢谢留言!
发射持续的时间,一般10个小时左右。
....... (2024-07-20 22:43)
还有个比较快捷的方法判断信号传播, 就是看看FT8, 如果FT8都没有,可能传播就是不行了, 通常情况下FT8看起来比CW强 。
RIG:IC-705, IC-7300
GRID:PM00EG
qq:435022441
SKCC number:26449
离线bd4lb
只看该作者 11楼 发表于: 2024-07-21
@bh5hzg
以前,关于传播情况,我会听一下,各个波段,有没有FT8的信号。
现在,不会了。
主要的问题是,FT8的信号里面,有很多大功率信号。
对分析小功率的DX传错,没有参考意义。
目前,我使用wspr beacon,测试传播和天线的情况。
本帖提到的人: @bh5hzg
