  • 2348阅读
  • 3回复
Frequency  Chart of most used Modes [复制链接]
离线bd2bh
只看楼主 倒序阅读 0楼 发表于: 2019-12-08
作为老HAM应知应会的呼叫频率、工作模式,统称Calling Frequency。请按照约定俗成的游戏规则行事!
【160 METERS】
1.830-1.840    CW, RTTY and other narrowband modes, intercontinental QSOs only
1.825 - 1.826    DXpeditions often call her and listen 1.830 to 1.8350
1.838    MFSK
1838.150    PSK31 Calling Frequency
1.840-1.850    CW, SSB, SSTV and other wideband modes, intercontinental QSOs only
1828.5    DXpeditions CW Operations are frequently here
1.916    SSTV
【80/75 METERS】
3.500-3.525    CW DX & DXpedition Window
3.505    DXpeditions CW are frequently here
3.580    MFSK
3580.15    PSK-31 (offset -115 for USB)
3.590    RTTY DX
3.640-3.650    SSB (some Europeans will transmit here and listen above 3800kHz)
3.690-3.700    SSB (some Europeans will transmit here and listen above 3.800)
3.71    QRP Novice/Tech CW Calling Freq
3.790-3.800    SSB DX & DXpedition Window 3.799 DXpeditions SSB are frequently here DX may transmit below 3750 KHz and listen above 3800 KHz.
3.730~3.740    SSTV Operating Frequency -- IARU Region 1
3.845 & 3.857    SSTV Operating Frequency USA/Canada
3.885    AM Calling Frequency
3.575    HELL, Region #1
3.559    HELL, Region #2
【60 METERS (Max ERP is 50 watts.)】
5330.5 kHz USB
5346.5 kHz USB
5366.5 kHz USB
5371.5 kHz USB
5403.5 kHz USB
【40 METERS】
7.000 - 7.010    CW DX & DXpedition Window
7.005    DXpeditions CW are frequently here
7.035~7.045    SSTV Operating Frequency -- IARU Region 1
7.035.15    PSK-31 (offset -115 for USB)FOR Region 1 and 7080.15 for region 2
7.037    MFSK
7.040    RTTY DX
7.040 to 7.099    SSB DX & DXpedition Transmit -- Listening above 7.150
7.050    XTAL Controlled Rigs
7.065    DXpedition SSB USA split to 7.150 and above
7.072.50    Most PSK31 has moved to this freq.   LSB
7.171 & 7.172    SSTV Operating Frequency USA/Canada
7.228 *    Digital SSTV,  *Or after Analog Portion Of The NET ends
7.245    FAX Operating Frequency
7.290    AM Calling Frequency
7.030-7.040    HELL
【30 METERS】
10.110    DXpeditions CW are frequently here
10140.150    PSK31
10.135-10.145    HELL
10.147    MFSK
【20 METERS】
14.025    DXpeditions are frequently here CW Freq -- Usually Split
14070.15    PSK-31 (14069.00 USB)
14.072-14.079    MFSK16
14.080    RTTY Freq & MFSK
14.100    NCDXF Beacons
14.195    Rare DX & DXpeditions Frequently Operate SSB Here -- Generally Listening Up (Split Operation)
14.225~14.235    SSTV Operating Frequency -- IARU Region 1
14.230    SSTV Operation USA/Canada
14.233    SSTV Operation USA
14.236    SSTV Operation USA
14.245    FAX Operating Frequency
14.286    AM Calling Frequency
14.063-14.070    HELL
【17 METERS】
18.145    DXpeditions SSB are frequently here -- Usually Split
18100.150    PSK31
18.075    DXpeditions CW are frequently here -- Usually Split
18.101-18.107    HELL
18.105    MFSK
18.1625    Digital SSTV
【15 METERS】
21.025    Rare DX & DXpeditions Frequently Operate CW Here -- Generally Listening Up (Split Operation)
21.070    PSK-31 (offset -115 for USB)
21.080    RTTY & MFSK
21.295    Rare DX & DXpeditions Frequently Operate SSB Here -- Generally Listening Up (Split Operation)
21.335~21.345    SSTV Operating Frequency -- IARU Region 1
21.340    SSTV Operating Frequency USA/Canada or Digital SSTV
21.345    FAX Operating Frequency
21.063-21.070    HELL
【12 METERS】
24.945    Rare DX & DXpeditions Frequently Operate SSB Here -- Generally Listening Up (Split Operation)
24920.150    PSK31
24.929    MFSK
24.895    Rare DX & DXpeditions Frequently Operate CW Here -- Generally Listening Up (Split Operation)
【10 METERS】
28.025    CW Rare DX & DXpeditions Frequently Operate Here -- Split
28.063-28.070    HELL
28070.15    PSK-31 (offset -115 for USB)
28.080    RTTY  & MFSK
28.1010 10/10    Intl CW Calling Frequency
28120.150    PSK31
28.120-28.300    Beacons
28.340    Hoodlums Net, every Saturday 10 PM EST, Rock Hill, SC
28.380    10/10 SSB Intl Calling Frequency
28.425    10/10 SSB Intl Calling Frequency
28.495    SSB Rare DX & DXpeditions Frequently Operate Here -- Split
28.600    Old General Callin Frequency - Still used by Old Timers
28.610    Local RagChew Freq. for Gastonia, NC
28.660~28.700    SSTV Operating Frequencys
28.680    SSTV Operations USA/Canada
28.690    SSTV Repeaters (K3ASI)
28.700    SSTV Repeaters
28.800    10-10  Net
28.825    10-10 Backskatter Net - Paper Chasers Net
28.885    6M DX Liaison Frequency -- Listen here for 6 Meter DX opening announcements and discussions.
28.945    FAX Operating Frequency
29.000-29.200    AM Operations
29.300-29.510    Satellite Downlinks
29.550    FM, Digital SSTV
29.520-29.580    Repeater Inputs
29.600    FM Simplex - Calling Frequency
29.620-29.680    Repeater Outputs
【6 METERS】
50.680    SSTV
50.0 - 50.1    CW
50.110    SSB DX CALLING
50.100 - 50.124    SSB DX
50.125    SSB US CALLING
50.200    ARRL New Calling Freq.
50.125 - 50.200    SSB
50.200 - 52.00    Only during hot F2 openings do you find SSB much above 50.200.
50.400    AM
50.260    WSJT (high speed meteorite scatter)
51.120    FM PSK31
50.290    SSB PSK31
52.00 - 54.00    FM Repeaters
52.525    FM Simplex
【2 METERS】
144.200    SSB
145.500    FM SSTV
145.550    FM PSK31
144.144    SSB PSK31
144.390    APRS
144.140    FSK441 Meteor Scatter
144.40 - 144.44    Experimental
144.45 - 144.49    Satellite (SAREX and ARISS voice up-links)
145.00-145.09    PACKET
144.510 - 144.890     FM Repeater Inputs
145.110 - 145.490     FM Repeater Outputs
145.710    PACKET
146.010 - 146.505     FM Repeater Inputs
146.400 - 146.585    FM Voice Simplex and Alternate Repeater Inputs
146.610 - 147.390    FM Repeater Outputs
147.600 - 147.990    FM Repeater Inputs
146.520    National Simplex Calling Frequency
【222-225 MHz】
222.000 - 222.015    Guard Band (15 KHz)
222.015 - 222.050    EME - (Earth/Moon/Earth) (50 KHz)
222.050 - 222.060    Propagation Beacons (10 KHz)
222.060 - 222.100    Weak Signal CW/Experimental (40 KHz)
222.100     CW/SSB Calling Frequency
222.100 - 222.200    Weak Signal CW/SSB (100 KHz)
222.200 - 222.350    Repeater Control/Link Frequency (150 KHz)
222.350 - 222.450    Hi Speed Digital w/222.40 Center (100 KHz)
222.450 - 222.460    Propagation Beacons (10 KHz)
222.460 - 222.490    EME/Weak Signal/Experimental (30 KHz)
222.500 - 223.380    FM Repeater Inputs (880 KHz with 20 KHz spacing)
223.400 - 223.640    FM Simplex Voice (240 KHz)
223.660 - 223.780    Digital Channels (120 KHz with 20 KHz spacing)
223.800 - 223.900    Hi Speed Digital w/223.85 center (100 KHz)
223.910 - 224.080    Control & Link Frequencies (170 KHz)
224.100 - 224.980    FM Repeater Outputs (880 KHz with 20 KHz spacing)
224.990 - 225.000    Guard Band (10 KHz)
223.400 223.420 223.440 223.460 223.480 223.500*
223.520 223.540 223.560 223.580 223.600 223.620 223.640    FM Voice Simplex Frequencies
* 223.500 is the National FM Voice Simplex Calling Frequency
420-450 MHz
420.0000 - 420.2000     Repeater Links
420.0000 - 426.0000    ATV Repeater Output 421.250 Video -425.750 Audio
426.0000 - 432.0000    ATV Simplex 427.250 Video - 431.750 Audio
432.0000 - 433.0000    SSB & Weak Signal 432.100 National SSB Calling Frequency
433.0125 - 433.2000    Repeater Links
433.0000 - 439.0000    ATV Simplex Only 434.000 Video - 438.500 Audio
438.7750 - 439.5875    Repeater Links
439.6000 - 440.4750    FM Digital/Packet Operation
440.5125 - 440.7250    Narrow Band Digital Repeater Outputs/Duplex Backbones/Link
440.7375 - 440.9000    Simplex Cross Band Voice - Base
440.9125 - 441.1750    Simplex Digital
441.1875 - 441.4875    Links, Control Frequencies
441.5000    Simplex Digital 441.000 National Digital Calling Frequency
441.5250 - 441.7750    Duplex Link Repeaters
441.8000 - 444.9750    FM Standard Repeater Outputs
445.0250 - 445.4750    Digital
445.5125 - 445.7250    Digital Repeater Inputs
445.7375 - 445.9000    Simplex Cross Band Voice - Mobile
445.9125 - 446.1750    FM Simplex 446.000 National FM Calling Frequency
446.1875 - 446.4875    Links, Control Frequencies
446.5000    Simplex Digital
446.5250 - 446.7750    Duplex Link Repeaters
446.8000 - 449.9750    FM Standard Repeater Inputs
445.9125 445.9250 445.9375 445.9500 445.9625 445.9750 445.9875 446.0000*
446.0125 446.0250 446.0375 446.0500 446.0625 446.0750 446.0875 446.1000 446.1125 446.1250 446.1375 446.1500 446.1625 446.1750
Voice FM Simplex Frequencies
*446.000 is the National FM Voice Simplex Calling Frequency
BD2BH_SHE@163.COM
离线bg2kaj
只看该作者 1楼 发表于: 2019-12-08
这是美国的吧,60m分频道,40m到7300
离线BG6SNJ
只看该作者 2楼 发表于: 2019-12-08
没有时下流行的FT8 FT4模式的频点
QTH: 宜昌
Mail: bg6snj@qsl.net
LOG: http://log.bg6snj.cn/
QQ: 241201343
VX: bg6snj
离线李铁柱79
只看该作者 3楼 发表于: 2019-12-12
没有时下流行的FT8 FT4 JT65 WSPR等等模式的频点?
同问
现工作地址:
郑州市金水区纬五路-东明路 手机1823718382九
