  • 5556阅读
  • 4回复
[HamApps] New - JTAlert 2.5.0 available [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-11-14
>  New Features:
>     - Option to have a solid color area behind Band Activity area of titlebar.
>        (Default: OFF, Window : Settings, Section: Window,Band Activity Display).
>     - Decodes History display. Provides detailed data about each decode, current
>        and previous minutes and the alerts triggered. Exports to daily csv files.
>        (Default: OFF, Window: Settings, Section: Window,Decodes History).
>     - Confirmed / Worked Bands display, for QSO partner, their DXCC or US State.
>        This is available in the Log Fields area and logging must be enabled.
>        (Default: ON, Window: Main, Menu: Settings,Show Worked Bands).
>     - QSO Start time field in Log Fields area. Populated with the utc time when
>        a new QSO partner Callsign is detected. If it contains a value it will
>        override the time provided by WSJT-X and JT65-HF logging event.
>     - Option to upload newly logged QSOs to QRZ.com Logbook.
>        (Default: OFF, Window: Settings, Section: Web Services,Online Logbooks).
>     - Option to upload newly logged QSOs to eQSL.cc Logbook.
>        (Default: OFF, Window: Settings, Section: Web Services, Online Logbooks).
>     - Display time for Text Message received popup window can varied or turned off.
>        (Default: Auto close, 20secs, Window Settings, Section: Web Services).
>     - Works with new 0.9.90 version of JT65-HF HB9HQX Edition.
>        (Important Note: Only JT65-Log, the default, is supported)
>     - Right-click context menu (same as callsign slots) on QSO partner callsign.
>     - Decoded callsign summary tooltip now includes Distance (km) and the
>        Bearing (short-path) to Station if the Gridsquare is known.
>     - Standalone utility to facilitate Station Callsign changes.
>   Changes:
>     - JTAlert-X name changed to JTAlertX. (removed hyphen)
>     - If a band change is detected mid-minute (after 15secs) the processing of any
>        new decodes is skipped.
>     - Saving decodes history to csv file no longer available. This has been replaced
>        with the Decodes History display which provides a csv export function.
>     - JTAlert in HB9HQX mode will now wait for JT65-HF HB9HQX to be running before
>        continuing its startup.
>     - If DXKeeper lookup on new Callsign is enabled, the DXKeeper Callsign filter
>        is removed when QSO partner Callsign is cleared.
>     - QSL flags changed to stripes. LotW on left & eQSL on right of callsign.
>        (old style flags are still available).
>     - QRZ & HamQTH XML lookup results are now cached for up to 7 days.
>     - Improved Decoded Callsign and Gridsquare validation.
>     - Band Activity Display now shows both TX & RX Callsign counts for JT65 & JT9.
>     - JTAlert will exit with a warning if JT65-HF or WSJT-X don't have a Grid set.
>     - Callsign clearing now at 45secs for JT65-HF HB9HQX (others 47secs).
>     - When WSJT-X is docked to JTAlertX, the WSJT-X Wide Graph window will follow
>        the main WSJT-X window when it is minimized and restored.
>        (Default: ON, Window: Settings, Section: Appplications,WSJT-X).
>     - Local user appdata directory restucture. All files now stored under "HamApps".
>     - Several DXCC names changed to be consistent with ARRL naming convention.
>        (eg. "Kampuchea" changed to "Cambodia", "Gambia" changed to "The Gambia")
>     - Halt TX position (left or right) option removed. Now always right of Callsigns.
>   Fixes:
>     - Dragging windows showing only a frame rather than the content of the window.
>     - ADIF Log, Incorrect Name/QTH data being displayed after previous QSO lookup.
>     - Line 23503 error when cancelling "Waiting for WSJT-X to start" dialog.
>     - If JTAlert power set to 0, JT65-HF and WSJT-X power ignored and not logged.
>     - Error downloading program versions/updates available data.
>     - Corrected DXCC name "Fed. Republic of Germany" for HRD Logbook.
>     - WSJT-X 1.4 "-rig-name" command line option not detected.
>     - Occasional hidden JTAlert process needed to be killed by taskmanager.
>     - Reading incorrect data from 3.9 DL3VCO Comfort JT65-HF Edition when additional
>        controls added to Comfort window while it is running.
> JTMacros Version History:
>   New Features:
>     - "=" macro substitution. Number of QSOs plus current QSO (from JTAlert log).
>     - "{" macro substitution. Number of JT65 QSOs (from JTAlert log).
>     - "}" macro substitution. Number of JT9 QSOs (from JTAlert log).
>     - "[" macro substitution. Number of worked JT65 Bands (from JTAlert log).
>     - "]" macro substitution. Number of worked JT9 Bands (from JTAlert log).
>     - Window can now be resized vertically when not docked to WSJT-X or JT65-HF.
>        (use normal mouse border grab method to resize)
>     - "Don't Activate" option. Will not activate WSJT-X or JT65-HF Freetext
>        radio button. (Default: OFF)
>     - Help button. Visible when window is expanded.
>   Fixes:
>     - When in single-instance mode and JTAlert in multi-instance mode, only
>        reading data from first instance of JTAlert.
>     - WSJT-X Freetext message radio button not enabled when macro text sent.
>        (For Tab 2, Radio button is only enabled if not transmitting)
>        (For Tab 1, Radio button is always enabled)
>   Changes:
>     - JTMacros-X name changed to JTMacrosX. (removed hyphen)
>     - JTMacros will now wait until JT65-HF HB9HQX edition is found running.
下载JTAlert 2.5.0   HamApps_JTAlert_2.5.0_Setup.rar (4157 K) 下载次数:27
[ 此帖被BG4DRL在2014-11-14 12:59重新编辑 ]
只看该作者 1楼 发表于: 2014-11-14
>新功能:
> - 选择有标题栏后面的乐队活动面积纯色区域。
>(默认值:OFF,窗口:设置,章节:窗,带活动显示)。
> - 历史解码显示。提供有关每个解码,目前详细数据
>与先前分钟,警报被触发。出口到日常的CSV文件。
>(默认值:OFF,窗口:设置,部分:窗口,历史解码)。
> - 确认/工作频段显示,通联的合作伙伴,他们的DXCC或国美。
>这是在日志字段区域提供日志记录,必须启用。
>(默认:ON,窗口:主,菜单:设置,显示曾为乐队)。
> - 在日志字段区域通联开始时间字段。人口与UTC时间
>一个新的合作伙伴通联呼号检测。如果它包含一个值时,它会
>覆盖由WSJT-X和JT65-HF伐木活动提供了时间。
> - 选择新登录通联上传到QRZ.com日志。
>(默认值:OFF,窗口:设置,部分:Web服务,在线工作日志)。
> - 选择新登录通联上传到eQSL.cc日志。
> - 显示时间短信收到弹出式窗口可以更改或关闭。
>(默认:自动关闭,20secs,窗口设置,部分:Web服务)。
> - 新的0.9.90版本JT65-HF HB9HQX版的作品。
>(重要提示:只有JT65-日志中,默认情况下,支持)
> - 右键单击上下文菜单上的合作伙伴通联呼号(同呼号插槽)。
> - 解码呼号摘要提示现在包括距离(公里)和
>轴承(短程),以车站,如果Gridsquare是已知的。
> - 独立的实用程序,以方便车站呼号的变化。
>更改:
> - 更改为JTAlertX JTAlert-X的名字。 (去掉连字符)
> - 如果一个频带变化被检测中间分钟(15secs之后)的任何处理
>新解码被跳过。
> - 保存解码历史csv文件不再可用。这已被替换
>与解码历史显示,它提供一个CSV导出功能。
> - JTAlert在HB9HQX模式,现在就等待JT65-HF HB9HQX被运行之前,
>继续其启动。
> - 如果新的呼号DXKeeper查找被激活,DXKeeper呼号过滤器
>当QSO伙伴呼号被清除被删除。
> - QSL标志改为条纹。 LotW左&EQSL在呼号的权利。
>(旧式标志仍然可用)。
> - QRZ&HamQTH的XML查询结果现在缓存长达7天。
> - 改进解码的呼号和Gridsquare验证。
> - 带活动显示,现在同时显示TX和RX呼号算个JT65&JT9。
> - JTAlert将警告退出,如果JT65-HF或WSJT-X没有一个网格设置。
> - 现在呼号结算在45secs为JT65-HF HB9HQX(其他47secs)。
> - 当WSJT-X停靠JTAlertX的WSJT-X宽图形窗口将跟随
>最小化时,恢复主WSJT-X的窗口。
>(默认:ON,窗口:设置,章节:Appplications,WSJT-X)。
> - 本地用户的AppData目录restucture。所有的文件现在保存在“HamApps”。
> - 几个DXCC名称更改为与ARRL命名约定相一致。
>(如“柬埔寨”改为“柬埔寨”,“冈比亚”改为“冈比亚”)
> - 暂停TX位置(左或右)选项去掉。现在总是正确的呼号。
>修正:
> - 拖动窗口仅显示一帧,而不是窗口的内容。
> - ADIF日志,以前的QSO查询后显示不正确的姓名/ QTH数据。
> - 取消时,23503号线错误“等待WSJT-X启动”对话框。
> - 如果JTAlert功率设置为0,JT65-HF和WSJT-X忽视的力量,而不是记录。
> - 错误下载的程序版本/更新的数据。
> - 修正DXCC名“联邦共和国德国。”人力资源开发日志。
> - 未检测到WSJT-X1.4“-rig名”命令行选项。
> - 需要通过任务管理器杀偶尔隐藏JTAlert过程。
> - 从3.9 DL3VCO舒适JT65-HF版读取不正确的数据时附加
>添加到舒适窗口在运行时控制。
> JTMacros版本历史:
>新功能:
> - “=”宏替换。类星体以及类星体电流(从JTAlert日志)的数量。
> - “{”宏替换。 JT65类星体(从JTAlert日志)的数量。
> - “}”宏替换。 JT9类星体(从JTAlert日志)的数量。
> - “[”宏替换。工作JT65乐队(来自JTAlert日志)的数量。
> - “]”宏替换。工作JT9乐队(来自JTAlert日志)的数量。
> - 窗口现在可以调整垂直时,没有停放WSJT-X或JT65-HF。
>(使用普通鼠标的边框抢的方法来调整)
> - “不激活”选项。不会激活WSJT-X或JT65-HF FREETEXT
>单选按钮。 (默认值:OFF)
> - 帮助按钮。可见,当窗口被扩大。
>修正:
> - 在单实例模式和JTAlert在多实例模式下,只有
>从JTAlert一审读取数据。
> - 当宏文本发送未启用WSJT-X FreeText的消息单选按钮。
>(对于第2个标签,单选按钮只有在不发送使能)
>(用于制表1,单选按钮始终处于启用状态)
>更改:
> - JTMacros-X更名为JTMacrosX。 (去掉连字符)
> - JTMacros现在等到JT65-HF HB9HQX版本被发现运行。
只看该作者 2楼 发表于: 2014-11-14
只看该作者 3楼 发表于: 2014-11-14
传播越来越差,JT65越来越受欢迎
900兆:要奇奇陆吧三铃摇摇就散
离线李铁柱79
只看该作者 4楼 发表于: 2014-11-16
要是有安卓版的,就爽死了
现工作地址:
郑州市金水区纬五路-东明路 手机1823718382九
