  • 4317阅读
  • 2回复
为KX3-IQ / FCD-IQ设计的频谱软件NaP3 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-04-10
v3.0.0 supercollapse failed to remember correctly plain vanilla expanded/collapsed window sizes/positions.
v3.0.1 should avoid this. It now remembers, including between sessions.
v3.0.1
Revised gain distribution with 11dB more DSP headroom to increase card stability.
Default RF ‘gain’ per band now 85 to accommodate revised gain.
Input ‘Set Gain’ control avoids Windows Mixer completely, works with all drivers.
‘Set Gain’range is now +10 to -50dB.
‘Set Gain’ value is saved with all drivers.
Simpler, more sensitive, single bargraph balance meter.
FUNCube Dongle Pro Plus configuration saved with all systems.
The ‘Third RX’ SUB button context option available on all rigs unlink
the rig VFOB and NAP3 VFOB.
A Collapsed window will not open overlapping the bottom of the screen, at 96/120/144dpi.
Window maximise and minimise now work, at 96/120/144dpi.
‘Supercollapse’ to minimal display. using Ctrl+PageUp.
Window state prior to supercollapse is saved, including between sessions
Panadapter S scale removed.
下载地址
http://www.panadapter.com/nap3-installation/
v3.0.1 NaP3 v3.0.1 Setup
Default RF ‘gain’ per band now 85 to accommodate revised gain..
‘Supercollapse’ to minimal display with Ctrl+PageUp.
[ 此帖被BG4DRL在2014-04-10 00:42重新编辑 ]
只看该作者 1楼 发表于: 2014-04-10
PX3出来前最好的IQ频谱软件。
更新很频繁约每周一次更新一个版本
在线李铁柱79
只看该作者 2楼 发表于: 2015-04-27
打不开
需要翻墙吧
现工作地址:
郑州市金水区纬五路-东明路 手机1823718382九
