FX-4 Specs
Transceiver size in inches 4.10L X 2.8W X 1.5T
Transceiver Weight 12.8 oz.
Current Drain on receive 250-270 ma
Current Drain on transmit 1200 ma
Receive/Transmit Bands 7.000.00 to 7.300.00 MHz
14.000.00 to 14.350.00 MHz
9.999.00 to 10.150.00 MHz
18.068 to 18.168.00 MHz
Frequency control 75 MHz
Display type LCD-128×64
Transmitter Max output power 5 watts CW
5 Watts SSB
Spurious emissions -43dB at 5 Watts
Side tone pitch 550Hz to 1500Hz adjustable
Receiver sensitivity 0.3uV
Selectivity -3dB/ 2.6K -40db/ 4.5K
Audio Output 1 Watt with 8 ohm speaker
Keyer Iambic A & B adjustable speed from 5 to 40 wpm
Memory Storage 10 per each Band total of 40
DSP filtering 300KHz, 500KHz. 1.3KHz, 1.6KHz, 1.9KHz, 2.2KHz, and 2.5KHz.
VFO Drift <5Hz after 5 minute warm up at 30c (<10Hz after 30 minute operation @ 40c)
