  • 17434阅读
  • 43回复
一个苹果上的利用耳机接口收发aprs的软件pocketpacket [复制链接]
离线BG6JJI
只看楼主 倒序阅读 0楼 发表于: 2011-10-16
interfacing details
when using the audio modem option, in a very silent environment, even placing your iphone's built-in microphone close to the transceiver's speaker will let you receive some packets. for best results though, connect your device's microphone-in port to your transceiver's audio or data-out port and vice versa.
the iphone's microphone-in and audio-out ports are available at the 4 conductor 3.5mm connector located at the top of the device. you can buy an appropriate adapter or easily build your own (tip: left out, ring 1: right out, ring 2: ground, sleeve: mic in). when connecting your iphone to your transceiver, also consider buying or building a "sound card interface", in order to isolate the path between the radio and the device and to be able to control the volume of the audio channels. such interface schematics can be found in amateur radio handbooks, radio manuals or the internet (e.g. check out http://www.foxdelta.com). for sending data, as the iphone lacks an extra control port to provide a ptt signal, you should use an interface that automatically triggers ptt on available audio, or a transceiver that provides such a feature automatically. for instance, the yaesu ft-897d will automatically transmit when audio is available at the front mic input, when the "vox" feature is enabled.
这是接口部分的英文说明,说需要打开vox控制发射。
请看附图,注意最下面的audio modem   它可以打开transmit项目,我打开时就会听到一声调制声,这两天购买插接线,把它跟对讲机接起来,然后再给大家上报告。
如果可以的话,其实买个touch4 就可以用了,平常听歌,出去了配个3g路由可以上网。还能跟对讲机连起来。
只看该作者 1楼 发表于: 2011-10-16
不知道这软件是否支持用rs232?
http://blog.zol.com.cn/429/article_428128.html
离线BG6JJI
只看该作者 2楼 发表于: 2011-10-17
谁能编一个?用232的
离线BG4BWP
只看该作者 3楼 发表于: 2011-10-18
去app stroe看了,4.99美元,价格适中,如果支持rs232通讯的话就更加方便了。
等楼主的测试报告,记得以前bh4aik在他的苹果设备上折腾过类似软件。
离线BG6JJI
只看该作者 4楼 发表于: 2011-10-19
iphone耳机线序
看图
uv3r线序
1gnd 2 ptt 3 mic 4 speaker 猜的
离线ZL1CH
只看该作者 5楼 发表于: 2011-10-19
我的ipad是越狱过的版本,installous里搜索了一下发现也有!已经下载安装,貌似很好用,可以发送自己的位置,接收别人的位置,貌似还有数字中继功能,很强大!就是不知道电台音频输出和ipad的音频输入该怎么整?楼上的朋友说定义是猜的。。。
离线BG6JJI
只看该作者 6楼 发表于: 2011-10-19
今天测试结果
1,确定线序,楼上已经写出来了。
2,确定从苹果接对讲机vox发出,已经完成
  需要注意,主机音量要设置够,否则vox启动不了
3,接收测试,用耳机连接线测试未成功。
        直接用 iphone 和ipad2的机载mic和speaker 直接外成功 请看图。
4,用对讲机转2台机器测试:过几天做好线再测试,后面再看报告。
  手捏着插头对接太难受了
5,用avrt2加入测试网络:后面找时间测试,今天测试不了了。
离线BG6JJI
只看该作者 7楼 发表于: 2011-10-19
我猜对了,呵呵。今天测试结束,外面吃饭中
离线BG5少尉
只看该作者 8楼 发表于: 2011-10-19
记号 我的ipad 又可以多一个好玩的功能了
离线ZL1CH
只看该作者 9楼 发表于: 2011-10-19
厉害的~~~
离线BG6JJI
只看该作者 10楼 发表于: 2011-10-19
这个如果跟电台直接接驳有问题的话,还需要一个连接器,比如radio link
离线BG4BWP
只看该作者 11楼 发表于: 2011-10-19
jji这苹果的4芯线哪里买的?
离线BG6JJI
只看该作者 12楼 发表于: 2011-10-19
我几个月前在淘宝买的 买的是某些播放器上的四芯3•5插头转莲花的带线的头,买了十几条好像
离线BG6JJI
只看该作者 13楼 发表于: 2011-10-19
今天测试的接uv3r开vox在另外一台对讲机上出来的声音完整清晰,还不错。
离线BG6JJI
只看该作者 14楼 发表于: 2011-10-20
早上用安卓手机上的aprsdroid的afsk的喇叭播放功能放着收音机的同时发出调制声,pocketpacket依旧能够解码
离线李铁柱79
只看该作者 15楼 发表于: 2011-10-20
iphone耳机线序
看图
uv3r线序
宝峰uv3r的线序 确实是这样的 你猜的没错
离线BG6JJI
只看该作者 16楼 发表于: 2011-10-23
今天测试了
1.从安卓手机用aprsdroid直接接线从uv3r发送,对端6100plus对讲机可以正常接收
2.从ipad用pocketpacket接线6100plus发送,对端uv3r可以正常发声,但是缺一个头,说明vox有延迟。
3.ipad接收今天不知何故,无论是不接线直接用手机对着机载mic还是接线都无法成功解码。
4.2头4芯插头是直接线对线连接,未使用电容隔离。
具体解法请看下图
插头名称   1     2       3         4
苹果     麦克   地     右声道     左声道
uv3r     地     ptt     麦克       喇叭
苹果       uv3r
地   ---- 地
麦克 ---- 喇叭
左声道---- 麦克
右声道---- 麦克
    ---- ptt 空置
离线BG6JJI
只看该作者 17楼 发表于: 2011-10-23
估计需要一个radio link,但是ptt没法控制,尤其是开始的报头,aprsdroid倒是发了一个长长的报头,可是它只能发不能收。
只看该作者 18楼 发表于: 2011-10-24
可以找带有vox的车台手台。只是关心电台vox转换速度是否可以?或者这个软件有地方设置发送数据实际载荷内容延时吗?
离线BG6JJI
只看该作者 19楼 发表于: 2011-10-24
[quote=老干部]可以找带有vox的车台手台。只是关心电台vox转换速度是否可以?或者这个软件有地方设置发送数据实际载荷内容延时吗?[/quote]
没有设置延时的地方
