  • 21259阅读
  • 197回复
宇航员太空漫步扔业余卫星(2011.8.3晚) [复制链接]
离线bd4rs
只看楼主 倒序阅读 0楼 发表于: 2011-08-03
离线bd4rs
只看该作者 1楼 发表于: 2011-08-03
145.950 mhz fm downlink
fm transmissions will cycle between a voice id as rs01s, select telemetry values, 24 international greeting messages in 15 languages and sstv images. one of the messages will be a conversation between yuri gagarin and ground control.
435 mhz - 145 mhz linear transponder
the linear transponder will operate in mode u/v (70 cm up, 2m down). it is an 16 khz wide inverting passband and the convention will be to tx lsb on the 435 mhz uplink and rx usb on the 145 mhz downlink. this mode is designed to work with low power transmitters and omni antenna.
145.919 mhz cw beacon
the cw transmissions will be callsign id rs01s, select telemetry, and callsigns of people actively involved with the ariss program.
145.920 mhz ssb bpsk-1000 telemetry
the bpsk transmissions will feature a new 1kbpsk protocol developed by phil karn, ka9q to be readable in low signal level conditions. the bpsk data will transmit satellite telemetry. when the cw2 beacon on 145.919 mhz is active this indicates that the bpsk-1000 format is being transmitted. if the cw1 beacon on 145.939 mhz is active this indicates the backup of bpsk-400 format is being transmitted.
只看该作者 2楼 发表于: 2011-08-03
今晚上屋顶发呆。
离线bd4rs
只看该作者 3楼 发表于: 2011-08-03
今晚上屋顶发呆。
今晚在家看tv
离线BH1IEO
只看该作者 4楼 发表于: 2011-08-03
离线bg7abh
只看该作者 5楼 发表于: 2011-08-03
手台收听 试试
离线BH1IEO
只看该作者 6楼 发表于: 2011-08-03
要等第二圈了,熬夜+啤酒。
just use the iss data for the first day. arissat-1 will be deployed retrograde (behind and below the iss) and will hang out behind the iss for several orbits. it will eventually catch up to the iss (just below) and then begin to lead the iss. by the time this happens, actual predicts for arissat-1 should begin to be available.
离线BD4DLN
只看该作者 7楼 发表于: 2011-08-03
晚上便宜手台到家,正好测试
离线BH1IEO
只看该作者 8楼 发表于: 2011-08-03
试试能不能抄到这段蹩脚的中文。
附件: ARISSat-1.zip (0 K) 下载次数:294
离线BD4WM
只看该作者 9楼 发表于: 2011-08-03
今晚看汪老师微博直播
离线BG2BHC
只看该作者 10楼 发表于: 2011-08-03
离线BG2TOS
只看该作者 11楼 发表于: 2011-08-03
蛤蟆们   别忘录音啊
离线bd4rs
只看该作者 12楼 发表于: 2011-08-03
查了半天,没看到功率是多大,手台天线可能够呛。
不过用这个木头天线+手台应当可以了。
附件内有这个天线的资料。
附件: Cheap Antennas-LEOs.pdf (0 K) 下载次数:112
离线BH1IEO
只看该作者 13楼 发表于: 2011-08-03
不过用这个木头天线+手台应当可以了。
附件内有这个天线的资料。
手台抄收:
http://player.youku.com/player.php/sid/xmjkwmdi3nzi0/v.swf
离线bd4rs
只看该作者 14楼 发表于: 2011-08-03
手台抄收:
60r+拉杆天线?
离线BH1IEO
只看该作者 15楼 发表于: 2011-08-03
是墙外老外抄收的。
离线BG8SF
只看该作者 16楼 发表于: 2011-08-03
今晚就扔了!等待围观
离线BG2BHC
只看该作者 17楼 发表于: 2011-08-03
不过用这个木头天线+手台应当可以了。
附件内有这个天线的资料。
fm下行是250 mw
那个天线做过两个,感觉u段接收效果一般般,不如那个io天线,不过这次是收2m
附件: ARISSat-1 CDR SDX.pdf (0 K) 下载次数:58
离线BG2TOS
只看该作者 18楼 发表于: 2011-08-03
[size=5]就上个图 我要干啥你们懂得
离线bg4xxv
只看该作者 19楼 发表于: 2011-08-03
等待.....
