  • 9011阅读
  • 38回复
IARU灾害通信演练,有谁愿意做BY的主控台? [复制链接]
离线BA1RB
只看楼主 倒序阅读 0楼 发表于: 2010-11-06
一年2次的iaru灾害通信演习在11月13日举行,愿意参加的dxcc实体可以有一个主控台,有谁愿意做这次by的主控台,可尽快和我联系。
以下转发vk3pc, iaru 3区灾害通信委员会主席的信:
hello all,
      the twice-yearly global simulated emergency test (globalset) is
on saturday 13 november. the main change is that it will be 1100 to 1500 local time of the stations taking part.
this will mean that some stations may start working before a hq station is
available but this should encourage more relaying of information. it will
also allow us to compare conditions experienced by all three regions a little
more fairly.
the rules are below:
rgds, jim linton vk3pc, iaru region 3 disaster communications committee chairman
global simulated emergency test ? november 2010
saturday november 13th 2010 11.00 - 15.00 local time
iaru region 1 invites the hq-stations of all iaru member societies and
stations of emergency communications groups to participate in a global
simulated emergency test on saturday november 13th, 2010 11.00 ? 15.00
local time. the operation will take place on and near the emergency
centre-of-activity (coa) frequencies on 80, 40, 20, 17 and 15 metres
(+-qrm ).
this event is different to earlier ones as we will not be
activating all stations around the globe at the same time, instead the
event will call for stations to be active at their local time. this will
mean that some stations will have to wait for hq stations to come on air
to pass their messages but will reduce the inter-region interference
that may occur.
the objectives of the test are;
1. increase the common interest in emergency communications.
2. test how usable the coa frequencies are across itu regions.
3. create practices for international emergency communication and
4. practice the relaying of messages using all modes.
so, please remember that this is not a contest, it is an emergency
communications exercise to develop the skills we will need to provide an
international emergency network.
messages may be passed on voice (ssb), data or cw modes as detailed below.
voice mode
each iaru region will have a hq station operating on voice.
hq stations will be qrv at 11.00-15.00 local time in their qth on all
coa frequencies appropriate to their region +- qrm as shown below.
region 1 region 2 region 3
3760 3750 or 3895 3600
7060 or 7110 7060, 7240 or 7290 7110
14300 14300 14300
18160 18160 18160
21360 21360 21360
a list of participating stations will also be available at
http://bit.ly/bejvvw participating stations should call 'cq globalset'
giving their callsign and organisation (ares,raynet, netmar etc) of radio
society.
message format
each participating station will send messages to their regional hq
station formatted using the iaru hf international emergency operating
procedure which can be seen at http://bit.ly/2rrbww that page also has
the message forms to be used for the exercise.
stations should relay messages received towards the regional hq station.
to comply with licence regulations, all messages should be addressed to
greg mossop, g0dub and should come from a licenced radio amateur.
messages should be less than 25 words and must not include anything
which would be considered as a 'real emergency' message by a listener.
for example, acceptable message would be:
* weather report at the station location
* number of operators available
* interesting fact about the station
an example message would be;
1 routine zs6buu 6 johannesburg 1100 8 apr
to greg mossop g0dub
johannesburg weather 15 degrees and sunny
from francois botha zs6buu
there is no limit on the number of messages to be sent but each one must
have a unique message number.
regional hq stations will not be sending messages, only receiving them.
to avoid qrming the hq stations, please move to frequencies near the coa
in steps of 5khz for contacts with others.
to create a more realistic situation, please limit your transmitting
power during the exercise to 100 watts. we are especially interested in
stations operating mobile/portable and/or on emergency power.
data modes
data stations must send the same format as used for voice messages.
there will not be any hq stations for data modes in all regions, data
stations should use the frequencies defined for their preferred mode in
national bandplans unless otherwise shown. this makes the use of 'cq
globalset' and registering your intended participation particularly
important.
'structured' modes such as winlink, ale, pskmail should send their
messages directly to g0dub@winlink.orgthis e-mail address is being
protected from spambots. you need javascript enabled to view it , other
data modes should attempt to relay the messages through two other
stations before sending them to globalset-data@raynet-hf.netthis e-mail
address is being protected from spambots. you need javascript enabled to
view it for analysis. where possible, email responses will be sent as
the messages are received.
cw mode
cw is included in this set to increase the possibility of stations
making contacts in difficult conditions and should be used when ssb or
data contacts are proving impossible. there will not be any hq stations
for cw unless otherwise shown, cw stations should operate near the coa
frequencies when ssb traffic cannot be heard.
cw stations must send the same format as used for voice messages and not
exceed 15wpm. if necessary cw messages can be relayed through two other
stations before sending them to globalset-cw@raynet-hf.netthis e-mail
conclusion
a log sheet for messages passed is provided at http://bit.ly/8zyotg so
that analysis of the exercise will be easier. stations are only required
to submit logs of the messages relayed, not the messages themselves.
it is acknowledged that there have been significant delays in the
production of reports from earlier events. however please send your logs
with comments, pictures and suggestions for future exercises to;
globalset08@raynet-hf.netthis e-mail address is being protected from
spambots. you need javascript enabled to view it as soon as possible
after the set so that information can be gathered for a report of the
event as soon as the backlog has been cleared.
thanks for your support of emergency communications.
greg mossop, g0dub
iaru region 1 emergency communications co-ordinator
stations intending to participate are requested to register through
their iaru regional/national emergency communications co-ordinators as
follows;
region 3 - http://www.iaru-r3.org/dcom/r3dcom-com.htm
离线BA3OE
只看该作者 1楼 发表于: 2010-11-07
e文e语都不强,还是沙发顶
离线BA3AO
只看该作者 2楼 发表于: 2010-11-07
责任很重哦
离线BA1RB
只看该作者 3楼 发表于: 2010-11-07
责任很重哦
责任倒也不是很重,只是个例行的演习,需要模拟产生灾害通信的消息,传送给参加演习的台,或者给那些台中转。by1, by4, by5, by7的电台以前都参加过这个演练。有兴趣的台可和我联系,在演习中代表crsa作为中国总部电台参加演习。希望有更多关心业余无线电灾害通信的电台参与这个iaru的官方演习。
离线bd8ub
只看该作者 4楼 发表于: 2010-11-08
看不大懂英文,规则和要求能翻译过来看看吗?
离线BG2BHC
只看该作者 5楼 发表于: 2010-11-08
周六我们刚好期中考试结束,看了下规则是所有的电台都可以参加对吧?当主控台我们应该是不行……在力所能及的范围内参加吧。
离线BA1RB
只看该作者 6楼 发表于: 2010-11-08
主要的意思是在每个iaru分区的应急通信频率下进行演练:
14300 14300 14300
18160 18160 18160
21360 21360 21360
呼叫的时候使用cq globalset, 可以使用phone, cw, data等模式。
这次最大的变化是时间,是在11月13日各台的本地时间11:00 -- 15:00进行演练,看看经过不同时间、分区的传播,消息是否能够中继下去。
离线BA1RB
只看该作者 7楼 发表于: 2010-11-08
[quote=小小ham]周六我们刚好期中考试结束,看了下规则是所有的电台都可以参加对吧?当主控台我们应该是不行……在力所能及的范围内参加吧。[/quote]
可以参加的,本地时间11:00 -- 15:00。你们做by的主控台应该没问题。有兴趣的话可以试一试。我可以将你们台作为crsa主控台报告给3区灾害通信委员会,你们担任这次crsa主控。请尽快(明天之内)告诉我,谢谢。
离线BG2BHC
只看该作者 8楼 发表于: 2010-11-08
1rb老大,刚才和集体台的其它几个人商量了一下,我们就试试吧,第一次参加这样的活动就做主控台心里还是有点没底,不过我们会努力做好的~
不知还有其他的资料可以提供吗?
离线BA1RB
只看该作者 9楼 发表于: 2010-11-09
[quote=小小ham]1rb老大,刚才和集体台的其它几个人商量了一下,我们就试试吧,第一次参加这样的活动就做主控台心里还是有点没底,不过我们会努力做好的~
不知还有其他的资料可以提供吗?[/quote]
好的,我将报告给iaru r3本次演练中crsa的总部电台为by2hit。
呼叫程序可参考: http://bit.ly/2rrbww
已经报名作为总部电台的r3电台有:9m4cmr, ja1rl, vu2jau, zk6r,在演习过程中注意他们的信号。
另外,到时候可以关注一下dx summit上有没有spot cq globalset的电台。
祝好运。
离线BA1RB
只看该作者 10楼 发表于: 2010-11-09
离线BA1RB
只看该作者 11楼 发表于: 2010-11-09
昨天看到vk4wia也作为wia的hq台加入了。
祝by2hit演练成功。
离线BG2BHC
只看该作者 12楼 发表于: 2010-11-09
谢谢1rb
又仔细看了下规则,我们的任务就是把一或多条message通过直接或间接的方式发送给regional hq电台,同时也为其他电台转信,我的理解正确吗?
另外message的第一行1 routine zs6buu 6 johannesburg 1100 8 apr中的1 routine和6代表什么含义呢?unique message number是由message的来源电台给的编号吗?
离线BG1QXU
只看该作者 13楼 发表于: 2010-11-09
  时间真快,一晃又一年~
离线BG2BHC
只看该作者 14楼 发表于: 2010-11-09
[表情] [表情]   时间真快,一晃又一年~
1qxu您好~上次是by1rx参加的这个活动吧?能否为我们介绍下经验?
离线BG1QXU
只看该作者 15楼 发表于: 2010-11-09
这个还是请1rb 来吧,这几次一直都是和范老师学习的
离线BA1RB
只看该作者 16楼 发表于: 2010-11-09
[quote=小小ham]谢谢1rb
另外message的第一行1 routine zs6buu 6 johannesburg 1100 8 apr中的1 routine和6代表什么含义呢?unique message number是由message的来源电台给的编号吗?[/quote]
理解正确。
这个message是在哪里看到的?
operating procedure参见附件。
附件: emerg-ww.pdf (0 K) 下载次数:31
离线BG2BHC
只看该作者 17楼 发表于: 2010-11-09
理解正确。
这个message是在哪里看到的?
就在这个贴子1楼里~
离线BA1RB
只看该作者 18楼 发表于: 2010-11-09
[quote=小小ham]就在这个贴子1楼里~[/quote]
1应该是message number, 6应该是有6个人在操作。消息格式和以前演练的不一样。
离线张骏
只看该作者 19楼 发表于: 2010-11-09
中国人   咋都用英文呢
