  • 3710阅读
  • 6回复
《简氏军事通信》一刊关于XDD-925的内容 [复制链接]
离线张宇锋
只看楼主 倒序阅读 0楼 发表于: 2010-04-20
离线BG2BHC
只看该作者 1楼 发表于: 2010-04-20
[quote=张宇锋]oriole xdd-925 hf/ssb transceiver (china), ground-based communications
description
the oriole xdd-925 is a 25/5 w hf/ssb transceiver for manpack, fixed station, vehicle or shipboard applications in the 2 to 8.999 mhz range. offering medium- and long-distance links through a high-gain double antenna (a whip is used for mobile roles), the transceiver has 7,000 channels. other features are 1 × 10-6 frequency stability; intermodulation distortion of less than 25 db; and sensitivity of less than 1 µv. power is ac or ni/cd dc.
contractor
supplier china national electronics import and export corporation
the complete article appears in the following publication:
publication title jane's military communications
publication date feb 18, 2008
section ground-based communications
publication synopsis jane's military communications provides all the details you need on the latest advances in communications systems and equipment designed for, and fielded by, armed forces around the world. this authoritative resource contains detailed descriptions of each system's development programme, its operating parameters, how it works in battlefield conditions, its capacity to integrate with other systems, plus, frequencies, transmission rates, dimensions, power supply and environmental performance, giving you the most comprehensive military communications information resource available.
the depth and breadth of information covers tactical and ground-based communications
terrestrial microwave and tropospheric scatter
naval, air force and satellite communications systems and equipment
line and transmission systems
data, text, audio and facsimile
surveillance and signal analysis
encryption and security
direction-finding and jamming
laser, optical and video
different sections provide in-depth detail covering air force communications
an numbered communications equipment
analysis
audio
contractors
data and text
designation of radio emissions
direction-finding
facsimile
frequency bands and designations
glossary
jamming and miscellaneous
naval systems and equipment
satellite systems and equipment
systems
tactical communications
原文地址:http://www.janes.com/articles/janes-military-communications/oriole-xdd-925-hf-ssb-transceiver-china.html
希望有人能翻译一下。[/quote]
在俺的执照下来之前,俺是黑龙江唯一的收听台,等小张同学来接班哈~
离线BD6QI
只看该作者 2楼 发表于: 2010-04-20
奥里奥尔xdd - 925短波/单边带收发器(中国),地面通信
描述
黄莺xdd - 925是一个25 / 5瓦的高频/单边带收发manpack,固定站,车辆或船上的2至9.999兆赫范围的应用。提供中期和长途通过高增益天线双(一鞭子是用来移动角色的链接),收发器有7000渠道。其他特点是:1 × 10-6的频率稳定度;互调失真小于25分贝,以及小于1μv的敏感性。电源为交流或镍/镉直流。
承包商
中国供应商全国电子进出口总公司
完整的文章出现在以下出版物:
刊物名称简的军事通信
出版日期2008年2月18日
第地面通信
出版简介简氏军事通信提供了所有的细节您在通信系统和设备设计的最新进展的需要,并派出由世界各地的军队。这个权威资源包含各个系统的发展方案的详细描述,它的操作参数,如何在战场条件下工作,其能力与其他系统集成,加,频率,传输速率,尺寸,电源和环境表现给你,最全面的军事通信信息资源提供。
的深度和广度的信息包括战术和地面通信
地面微波和对流层散射
海军,空军和卫星通信系统及设备
线路和传输系统
数据,文字,声音和传真
监测和信号分析
加密和安全
测向和干扰
激光,光学和视频
不同部分提供深入详细覆盖空军通信
一个编号的通信设备
分析
音频
承建商
数据和文本
指定无线电发射
测向
加密和安全
传真
频带和标志
词汇表
地面通信
干扰及杂项
激光,光学和视频
线路和传输系统
海军系统设备
卫星系统和设备
监视和信号分析
系统
战术通信
地面微波和对流层散射
离线qswc
只看该作者 3楼 发表于: 2010-04-21
英文不会楼上的中文更难懂
离线7600
只看该作者 4楼 发表于: 2010-04-21
没见
离线BG3TIM
只看该作者 5楼 发表于: 2010-04-21
我有一台xdd-925
离线李铁柱79
只看该作者 6楼 发表于: 2010-04-21
我也有一台 功率已扩至65瓦 想搞成全段的 可惜没有很多资料 自己水平又臭 高手们积累的改这台机的经验也少
