the wrth editions give the erroneous impression that t2fd antennas require a 500 ohm resistor and a 10:1 balun transformer, used with 50 ohm coax cable. this is not the case, although these values will work fine if you have the 10:1 balun available (normally hard to come by). a t2fd built with 75 ohm coax (rg­59 or rg­6), a common 4:1 balun, and a 390 ohm terminating resistor is recommended.
t2fd天线一般的情况下负载电阻500欧姆,巴伦需要10:1,但是这种巴伦的制作很难搞;因次如果用75欧姆的同轴电缆馈电的话,巴伦需要4:1,负载电阻为390欧姆。
三线式款待行波天线需要多大的负载电阻、巴伦好像没有公开的数据和资料。
