  • 12457阅读
  • 6回复
Radio Modems/TNCs [复制链接]
离线BD1KEY
只看楼主 倒序阅读 0楼 发表于: 2006-04-13
kantronics出品,供大家了解!
呵呵!
啥时候,咱们能diy这个东东?
期待啊!
kam-xl features
operating modes and functions include:
packet (300, 1200 or 9600 bps)
gtor™
pactor 1
amtor (arq, fec, selfec, ccir 476 & 625)
psk31
rtty
navtex / amtex
ascii
wefax
emwin
dual port mailbox
cw
gps nmea-0183 compatible
telemetry
remote control
remote sysop access
kantronics host mode
kiss
location tracking/announcement: with a gps connected to the kam-xl, you can automatically announce your position to others via hf, uhf, or vhf. kantronics kam-xl is engineered to work with aprs® software and supports advanced ui frame digipeating functions
hf and/or vhf/uhf operations: with dual radio ports, the flexible kantronics kam-xl can be used on hf, uhf and vhf bands. the popular kantronics kam "gateway" feature between ports 1 and 2 allows for a local packet to be received on vhf or uhf bands, then transmitted over an hf band.
large capacity internal mailbox: 480k personal mailbox is standard. the kam-xl mailbox can respond to hf on tor modes, as well as packet modes.
versatile operations: the kantronics kam-xl may be used at your base, in the field, or as a mobile. designed for flexibility, the kam-xl will function with mobile, base, or hand-held radios.
kpc-3+ features
"newuser" mode provides a quick start for packet newcomers
large capacity internal mailbox and mail forwarding feature
gps operation mode allows use with aprs® or other geolocation software
remote control and telemetry functions with two a/d inputs and two control line outputs
low power requirements (9 volt battery power capability)
network node functions with standard "ka" node or optional k-net™ firmware
optional k-net node network firmware retains regular tnc functions
bbs, kiss, xkiss, host, terminal, gps and modem operating modes
"online" help feature
upgradeable as new firmware is released
digital control of audio drive level -- set from keyboard or by remote control
motorola® hc11 central processor
128k memory standard; 512k optional
comes with data connector, data wire, coaxial power plug, detailed manual & software
usable with base, mobile or hand-held radios
附件: kamxl_specsheet.pdf (0 K) 下载次数:86
附件: kpc_specsheet.pdf (0 K) 下载次数:71
离线ON6WFO
只看该作者 1楼 发表于: 2006-05-08
pactor协议
pactor是给德国人专利了,不知道其他产品是怎么支持它的。有人熟悉这个协议吗?
离线BD4OS
只看该作者 2楼 发表于: 2006-05-09
pactor-i分发了多个许可证书给tnc生产厂,pactor-ii大概只分发了一两家许可证书一个在瑞士一个就是大名鼎鼎的gw,pactor-iii除了scs还有gln的kiel也有权限分发证书。
全球海运市场的商业短波数据接入现在pactor占有相当大的份额,并且看看以下资料就能知道他的前景很好(提到的gln和gw都采用pactor协议,其中gln采用pactor-iii的pib协议直接在短波数据上应用tcp/ip):
at the next wrc 2007 the gln and gw will be introduced
as follow standard for radio telex inside the gmdss.
this will follow the resolution 351 and the appendix 17.
离线BD7PA
只看该作者 3楼 发表于: 2006-05-12
這款設備的費用是多少呢?
在什麽地方可以購買呢?
离线BD1KEY
只看该作者 4楼 发表于: 2006-05-14
quantity                 unit                 description of merchandise             unit price             total price
  1            kam xl            uhf/vhf/hf dual port controller            $409.00            $409.00
                             schedule b number: 8517.30.0000
                                                     total items            $   409.00
                                                     t/t fees            $   15.00
                                                     total ex-works            $   424.00
                                                     main carriage            $   61.23
                                                     total ex-works            $ 485.23
离线8EE
只看该作者 5楼 发表于: 2006-05-26
這款設備的費用是多少呢?
在什麽地方可以購買呢?
www.chinaham.com
离线李铁柱79
只看该作者 6楼 发表于: 2011-09-13
                                                     t/t fees            $   15.00
才三四千人民币 可以买来玩玩 呵呵
