  • 30671阅读
  • 110回复
!我的倒V架设COBRA ANTENNA(眼镜蛇天线)DIY完毕! [复制链接]
离线bd2bh
只看该作者 40楼 发表于: 2008-11-03
眼镜蛇天线与5/8波长的垂直天线在10米段对比
前几天本专栏已有介绍,你也可在google用"wh2t mini loop antenna"搜搜。
k1cod rating: 5/5 aug 19, 2008 07:51 send this review to a friend
5 years and still going strong   time owned: more than 12 months
i've been using this antenna over 5 years now (140' senior model). works great and i get a 1-1 match on all bands 160-6 meters with a tuner ofcourse. the antenna is up at 70' in a flatop configuration. i usually run about 500 - 600 watts output. if i can hear a station i can always be certain they will hear me. my property is surrounded by forest and i could easily put up a full wave 160 meter loop but i just can't bring myself to making any changes. this antenna just performs to well to make any changes. i have been enjoying 10 meters for the past couple months during sporadic e openings. i wanted to compare the cobra to an imax 2000 5/8 wave vertical on 10 meters. after more than 50 contacts and qso's switching between the two antennas the cobra would always receive stations 3-4 s units better than the vertical. i would also receive the same reports on my signal. if you have 140' to get this antenna up 30 ' or more i have no doubt you will be very pleased with this antenna.
k1cod 用它的140feet的眼镜蛇天线,与他的5/8波长的垂直天线在10米段进行了比较,50个电台对方给出的信号报告几乎没有什么变化,但是接收时均比垂直天线高出3-4s;他还提出如果天线假设到30英尺,效率也许会成倍的提高。
离线阿芮
只看该作者 41楼 发表于: 2008-11-03
多谢bd2bh的夸奖,学生我只是想尽我所能挖掘这种天线的潜力。因为经我这两天使用感觉cobra antenna的收发性能和我的原装r8对比没有太大差距。只是cobra接收噪音比r8少了两个s,接收信号的场强与r8相等或还不如r8。发射效果和r8差不多。正好bd7iww提出我的平行引下线的间距问题,经过看上面的图分析我的平行引下线的理论阻抗差不多已到700欧姆,所以我想我如果将平行下线的间距缩短到理论的1.5英寸(3.81mm)或许收发性能能够再上一个台阶。
离线BG3OO
只看该作者 42楼 发表于: 2008-11-05
原来在楼上拍过一个总长小于20米的缩短型三线天线,但间距好象不止10cm,改天贴图.
银行用的,不知具体频点.
离线阿芮
只看该作者 43楼 发表于: 2008-11-05
刚刚上楼把我的cobra antenna的平行引下线间距改为约3.8厘米了,正在测试信号中。
不过感觉引下线间距从10厘米改为3.8厘米后用天调调整7兆驻波没有原来小了。原来基本除了1.8兆和29兆无法完成调谐外,其他各频率均能调到1.1左右,现在7.050兆最低只能调到1.8左右。
离线阿芮
只看该作者 44楼 发表于: 2008-11-05
另外,试验一晚感觉14兆也不如以前了。看来这3.8厘米间距对于我的天馈系统来说不理想。下一步准备试验把平行引下线间距改为6英寸(15.24厘米)看看天馈线的收发情况。
离线BD2RWR
只看该作者 45楼 发表于: 2008-11-06
有一个很关键的问题没看见,你的天调放在什么地方了?用什么天调能介绍一下吗?就是不好用也不用拆,有办法补救,效果会好的。
离线BG1ENB
只看该作者 46楼 发表于: 2008-11-06
常走南4环-角门路,路过一个金润小区,每每都要抬头看那壮观的天线群,莫非是楼主?
离线阿芮
只看该作者 47楼 发表于: 2008-11-06
谢谢您的关注,下面是我天线的示意图,请指教!
离线阿芮
只看该作者 48楼 发表于: 2008-11-06
bg1enb,我家住在南四环公益桥向北一公里的西马金润家园,您看是这里吗?
离线BG1ENB
只看该作者 49楼 发表于: 2008-11-06
60米馈线,不易呀!
目标确认,准备实施精确打击!
离线阿芮
只看该作者 50楼 发表于: 2008-11-06
嘻嘻!看来天线要丢!!抓贼呀!
离线BG1ENB
只看该作者 51楼 发表于: 2008-11-06
用力拉馈线,争取把设备们全拉出来
离线bd2bh
只看该作者 52楼 发表于: 2008-11-07
银行用的,不知具体频点.
您贴的这款澳大利亚的三线式宽带行波天线(含终端吸收电阻的),阿芮diy的是宽带驻波/谐振天线,原理不同吧。
离线bd2bh
只看该作者 53楼 发表于: 2008-11-07
[quote=阿芮]谢谢您的关注,下面是我天线的示意图,请指教![/quote]
不如你把自动天调的控制线(4芯)延长点,把天调直接放在450 ohm的馈线端(没有条件放在室外的话,至少要放在窗口,距离天线最近的位置),当然天调输出端要接4:1不平衡--平衡的balun. 这样会大大提高天线的效率。
除了专门的台式自动天调外,自通天调本来就是放在室外用全天候工作的。60多米的50 ohm馈线损耗太大了!相反450 ohm的损耗只有同轴电缆的不到1/4。宽带谐振天线,其阻抗对频率变化非常敏感,50欧同轴电缆不适合做宽带天线的直接馈线,因此,天调到平衡馈线ladder lines的距离尽量缩短为好。
p.s 很多人喜欢用天调,试想如果自动天调直接放在天线的根部,那么集中参数匹配网络,就是调整天线的谐振,相当于给天线串入电感、电容组合,自动调整天线的电气长度,从而达到阻抗匹配的目的,这样效率当然高了许多。(虽然我们还没有办法人工或者机械地自动调整天线的物理长度,如果可行,这即为天线最为理想的调谐方式了)
离线BD2RWR
只看该作者 54楼 发表于: 2008-11-07
[quote=阿芮]嘻嘻!看来天线要丢!!抓贼呀! [/quote]
你的天线问题很明显,这种天线的天调要放在巴仑的位置才行,巴仑以上的平行线可以长一些,如果不具这个条件按照现在的天调和电缆连接方法用什么天线效果也不会很好的,除非把天调去掉用分段天线(7m、14m、21m、29m)的方式。
国外的一些资料很有参考价值,效果究竟如何有待于研究,楼主既然实验了可以在现有基础上根据国内常用的笼形天线原理改造一下,对比一下效果,如果能达到可以使用的程度是最好的结局,否则为国内ham的天线的diy提供一些数据吧!
离线fuyunfan
只看该作者 55楼 发表于: 2008-11-07
不错~!!!
离线fuyunfan
只看该作者 56楼 发表于: 2008-11-07
bg1lnk 你的x510用了多少米馈线????效果怎么样??
离线阿芮
只看该作者 57楼 发表于: 2008-11-07
bd2bh和bg2rwr,您们好!按照您们说的,我准备找个长线室外型天调,例如icom的at-120放置于我diy的眼镜蛇天线的平行引下线的末端。平行引下线一根线接在at-120的磁柱上,一根线接在at-120的接地端上。您们看是不是这样即可?
是否需要将at-120的接地端再与实际接地(楼顶的避雷网)进行连接?谢谢!
离线阿芮
只看该作者 58楼 发表于: 2008-11-07
您好!我的x510m也用了60米长的7/8馈管,为的是将损耗降至最低。实际使用通联全北京市没啥问题。赶上例如前年北京下完第一场雪的那晚,我用这套天馈+ft8900h机器直发通联到了山东滨州,直线距离约350公里!!
离线bd2bh
只看该作者 59楼 发表于: 2008-11-08
[quote=阿芮]bd2bh和bg2rwr,您们好!按照您们说的,我准备找个长线室外型天调,例如icom的at-120放置于我diy的眼镜蛇天线的平行引下线的末端。平行引下线一根线接在at-120的磁柱上,一根线接在at-120的接地端上。您们看是不是这样即可?
是否需要将at-120的接地端再与实际接地(楼顶的避雷网)进行连接?谢谢![/quote]
at-120输出端还是需要4:1巴伦的,天调不需要再接地了。巴伦的输入端一侧接天调输出端(带绝缘陶瓷的输出端),另一端接天调地。如果想接地在室内将电源、发射机共同接一个好的地线。
附:4:1巴伦绕制方法,磁环使用 t106-2或者其他的。
