  • 5290阅读
  • 15回复
网站推荐:RTTY.com [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 1楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 2楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 3楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 4楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 5楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 6楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 7楼 发表于: 2004-09-22
3620      w2qfr      170      45.45r      0200      amateur bulletins      bulletin mon/wed/fri
3625      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
4233      fuf      850      75r      0345      french navy      test tape
4269      cfh      850      75      0145      canadian forces      weather
4293      fue      850      75      0415      french navy      calling faaa, ry marker
4583      ddk2      425      50      0350      hamburg meteo      weather
6387      ctp      850      75      0400      nato      naws marker
6495      cfh      850      75      0045      canadian forces      weather
7095      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
7644      ddh7      425      50      0355      hamburg meteo      weather
7782      kawn      850      75      2200      usaf      aviation weather
8439      pbc      850      75      0425      dutch navy      zkn watch groups
8451      fug      850      75      0430      french navy      calling faaa, ry marker
8461      ckn      850      75      0225      canadian forces      naws, weather
8477      fuf      850      75r      0435      french navy      ry, test marker
9039      5ye      850      100      0025      nairobi meteo      aviation weather
10099      ddk9      425      50      0150      hamburg meteo      weather
10217      hzn      850      100r      0325      jeddah meteo      weather
10536      cfh      850      75      2135      canadian forces      aviation weather
10943      cfh      850      75      2130      canadian forces      naws marker
11037      ddh9      425      50      0450      hamburg meteo      cq/ry marker
11123      hzn      850      100r      0050      jeddah meteo      weather
12663      rfhje      850      75r      0135      french forces      calling faaa, znr marker
12700      ckn      850      75r      1810      canadian forces      freq watch list
12709      pwz33      850      75      0430      brazilian navy      navarea broadcast (portgse)
12822      ctp      850      75      0130      nato      naws marker, freq groups
12839      pbc      850      75      0125      dutch navy      listening groups
12855      6ww      850      75      2145      french navy      calling faaa, ry marker
13029      fuf      850      75r      2140      french navy      testing, ry marker
13048      udk2      170      50r      0350      murmansk radio      traffic to ships, also 6393
13508      cfh      850      75      2125      canadian forces      aviation weather
13528      kawn      850      75      1850      usaf      aviation weather
14095      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
14095      w2qfr      170      45.45r      1615      amateur bulletins      bulletin sat and sunday
14466      ddh8      425      50      0455      hamburg meteo      cq/ry marker, wx at 0500
15918      cfh      850      75      2120      canadian forces      naws marker
16798      udk2      170      50r      2035      murmansk radio      weather report, tfc
16802      udk2      170      50r      0030      murmansk radio      weather report, tfc
16903      rfqpme      850      75      2345      french forces      calling faaa, ry marker
16950      6ww      850      75      0055      french navy      calling faaa, ry marker
16958      rfhje      850      75      0300      french forces      znr/zui marker, testing
16960      fuf      850      75      2340      french navy      calling faaa, ry marker
17116      pbc      850      75      1900      dutch navy      listening groups
17178      fug      850      75      1905      french navy      calling faaa, ry marker
18104      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
21095      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
22535      fuf      850      75      1915      french navy      testing, ry marker
28095      w1aw      170      45.45r      2200      arrl amateur      bulletin m-f, also 0100 utc
all frequencies are dial readings in usb. r = reverse shift.
contributed by jim andrew, k5ui
离线BD3RJ
只看该作者 8楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 9楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 10楼 发表于: 2004-09-22
this is the component's list:
afsk (tx) side
c1 - 100 nf capacitor
p1 - 4k7 ohm potentiometer
t1 - audio transformer (1:1)
fsk (tx) side
r2 - 560 ohm 1/4 watt resistor
ok2 - 4n32 optocoupler
led2 - led diode
a/fsk (rx) + ptt side
t2 - audio transformer (5:1)
r1 - 560 ohm 1/4 watt resistor
ok1 - 4n32 optocoupler
led1 - led diode
pin's list
diagram's pin      on generic radio      on ts940
a      mic      pin 1 (mic)
b      gnd (mic)      pin 7 (mic)
c      radio data output      pin 3 (acc2)
d      ptt      pin 13 (acc2)
e      gnd      pin 4+12 (acc2)
f      fsk      (fsk)
g      fsk      (fsk)
diagram's pin      on pc (sound card)
h      line in
i      line in
j      line out
k      line out
diagram's pin      on pc (com db9)
l      pin 7 (rts)
m      pin 5 (gnd)
n      pin 3 (txd)
离线BD3RJ
只看该作者 11楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 12楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 13楼 发表于: 2004-09-22
离线BD3RJ
只看该作者 14楼 发表于: 2004-09-22
common rtty frequencies
contests      usa (khz)      usa (khz)      europe/africa (khz)      japan (khz)
common      common      dx freq.      common      common
1800 - 1840      1800 - 1840      1830 - 1840
3570 - 3630      3580 - 3600      3590      3580 - 3620      3520 - 35350
7025 - 7100
7025-7050
7080 - 7100
7040      7035 - 7045
     10120 - 10150            10140 - 10150
14060 - 14120      14080 - 14100            14080 - 14100
     18100 - 18110            18100 - 18110
21060 - 21150      21080 - 21100            21080 - 21120
     24910 - 24930            24920 - 24930
28060 - 28150      28080 - 28100            28050 - 28150
离线BD3RJ
只看该作者 15楼 发表于: 2004-09-23
