  • 4374阅读
  • 7回复
国内Diyer的十年前的"电子管AM/CW发信机"(组图),大饱眼福 [复制链接]
离线BG1CHZ
只看楼主 倒序阅读 0楼 发表于: 2002-09-18
http://ba4in.chinaham.com/homemadecwtx/album.htm
还有其他好多diy的东西,养眼呀
离线BG7IBQ
只看该作者 1楼 发表于: 2002-09-19
Re: 国内Diyer的十年前的"电子管AM/CW发信机"(组图),大饱眼福
原作者 bg1chz
还有其他好多diy的东西,养眼呀
正点!!!!!!!
离线BA7BK
只看该作者 2楼 发表于: 2002-09-21
不错
做得真不错
只看该作者 3楼 发表于: 2002-09-22
Re: 不错!
:p :p
离线yake10
只看该作者 4楼 发表于: 2006-04-06
单边带晶体滤波器
collection of quartz crystal ladder filters
in my designs i mostly use 6 pole crystal ladder filters built with standard available quartz crystals. since the price of standard available crystal units is relatively low and since the tests show, that 6 quartz crystal are just the right number to effectively and radically filter out the opposite side band in a ssb receiver, i don't see any reason why to built filters with less crystal units. 6-pole crystal filter is also not to sensitive regarding component parameter variations. i use 5% np0 (cgo) ceramic capacitors and an f-meter with 10 hz resolution + simple quartz oscillator to select the crystal units with resonant frequencies as close to each other as possible. the resonant frequency deviation between the units should not be bigger than 20 .. 30 hz to get best results. the units with bigger deviation could still be used in bfo oscillator.
离线午夜大雨
只看该作者 5楼 发表于: 2007-02-14
那个几有电路图吗?
离线Lily-Xuan
只看该作者 6楼 发表于: 2007-02-18
厉害啊!老兄
离线wangchun
只看该作者 7楼 发表于: 2007-02-18
套件???
