  • 4308阅读
  • 6回复
设备欣赏:CommanderⅡ VHF 1KW 功放 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-08-13
离线BD3RJ
只看该作者 1楼 发表于: 2004-08-13
离线BD3RJ
只看该作者 2楼 发表于: 2004-08-13
1000w适合vhf长距dx通讯. . features: reduced ratio (6 to1) on all tuning controls for smooth and easy tune-up. front panel input tuning control allowing a higher circuit "q" for excellent linearity and a very low input vswr all across the two meter band. a switched multimeter for monitoring plate voltage, plate current, and grid current. unique stripline design provides high output power within a compact space. piston tuning capacitor delivers high output power even into extremely high vswr. all internal r.f. components silver plated. one eimac? 3cx800a7 ceramic metal triode. unique stripline tank circuit. master of two meter dx. moonbounce, tropo, aurora, meteor scatter, e skip. -------------------------------------------------------------------------------- specifications: frequency range: 144 - 148 mhz. modes: usb, lsb, rtty, fm, cw. power requirements: 117/234 vac with 234 vac recommended. rf drive power: 10 - 15 watts nominal 25 watts maximum. rf output: up to 1000 watts ssb. input impedance: 50 ohms. output impedance: 50 ohms nominal. antenna load: 2:1 maximum. harmonic suppression: down 60db @ rated output. intermodulation distortion: down 30db minimum. weight: 56 lbs. tube: 3cx800a7 ceramic/metal triode. pressurized chassis forced air cooling.
离线洋蕃芋
只看该作者 3楼 发表于: 2004-08-31
什么价格???????
离线BD3RJ
只看该作者 4楼 发表于: 2004-08-31
[quote=洋蕃芋]什么价格???????[/quote]
不清楚,是从拍卖网站看到的。
离线BA5SBA
只看该作者 5楼 发表于: 2004-09-27
从结构上看有点像微波炉!!
离线BA5SBA
只看该作者 6楼 发表于: 2004-09-27
从结构上看有点像微波炉!!
