  • 9311阅读
  • 15回复
史上最强 APRS 模组 MIM 原始码公告 !!! [复制链接]
离线bv2ac
只看楼主 倒序阅读 0楼 发表于: 2004-06-12
mim : 使用 pic16c73 做的 aprs 晶片, 内码公开!!! 赶紧去抓吧....
http://www.ew.usna.edu/~bruninga/mim2.html
mim module source code released.
subject: [amsat-bb] mim module source code released.
date: thu, 10 jun 2004 2043 -0400
the source code for the mim module has now been
released to encourage further production of this
small tnc aprs transmitter on a chip. this is the
same chip used in the mic-e project and the protocol
was later used in the d7 and d700 radios.
the mim module was developed by wb4apr, n3mim,
and n3xlm and used in many balloon and small
satellite projects over the years.
it provides these tnc transmit functions:
* beacon text
* gps position data
* 5 channels of analog telemetry in aprs format
* up to 8 bits of parallel bit data
* full implementation of the mic-e format
* cw id for balloons
one of these modules is sufficient to provide all
the telemetry as used on pcsat, pcsat2, ande
and raft1 satellte missions. thus, they are
ideal for small satellites such as cubesats
pioneered at stanford.
by releasing the source code, we hope this will
encourage further production of these excellent
telemetry modules for tiny satellites.
de wb4apr, n3xlm and n3mim
离线albert
只看该作者 1楼 发表于: 2004-06-12
打不开站点???????
离线bv2ac
只看该作者 2楼 发表于: 2004-06-12
网页内容 :
the mic-encoder was designed in 1994 by bob bruninga wb4apr and presented at dayton as a means for encoding aprs into a microphone on any radio. carl wick, n3mim at the naval academy finished the ax.25 encoding and we renamed it the mim module. will clement n3xlm tightened up the code and brought it into production as the mim2. this chip was used in the tapr mic-e project and th eprotocol was adopted later by kenwood in its d7 and d700 radios. in recent years, other pic processor projects have brought aprs to just about any mobile application. but only the mim module has flown in space and been used in hundreds of student balloon and satellite projects because of its 5 channels of analog telemetry in aprs format.
we want to see it remain in production for similar student aprs projects and are releasing the source code to give them flexibility in their designs. dozens of these have been used at the naval academy and at stanford small satellite lab.
aprs&reg; mim module features:
complete1200-baud, ax.25, tnc transmit operation.
telemeters 5 analog signals (8-bit resolution) and 8 digital bits of data.
telemeters aprs&reg; compatible gps position if a gps receiver is attached.
transmitsbeacon text and cw id (20 wpm).
user-selectable transmit intervals for each packet type
user-programmable digipeat path containing up to 7 hops.
all user selections (callsign, digipeaters, rates, btext, etc.) stored in eeprom
configuration changeable at any time using the supplied pc software via serial port.
has receiver "hold off" to avoid collisions.
all surface mount except for the pic16c73 for easy firmware upgrades. size: 1.0" x 1.7".
on-board regulator (6.5-40 vdc. less than 15 ma). can source an additional 85 ma.
mic-lite! build a half price mic-encoder! see also my sketches. and details
download the complete mim docs &reg; .
source code has been released to encourage their further development in the amateur satellite service.
download the source code . [we only ask that credit be given to the authors].
bob bruninga, wb4apr
carl wick, n3mim
will clement, n3xlm
离线bd8te
只看该作者 3楼 发表于: 2004-06-12
进不去,能否发到这里。
离线bv2ac
只看该作者 4楼 发表于: 2004-06-13
进不去,能否发到这里。
一步步来, 先看系统说明 mim.zip, 以及原始码 mic107c.zip
附件: mim.zip (0 K) 下载次数:396
附件: mic107c.zip (0 K) 下载次数:338
离线bv2ac
只看该作者 5楼 发表于: 2004-06-13
最后三个.... 这样齐了..
附件: mic-lite.txt (0 K) 下载次数:234
离线bv2ac
只看该作者 6楼 发表于: 2004-06-13
这个模组可以完成 ba1fb 的探空气球, 车位回报, 浮标, 高山气象站, 甚至业余卫星..... 数据传送事宜之技术关键.
离线VR2VJJ
只看该作者 7楼 发表于: 2004-06-13
woow.. size不大, 似乎很好哦? 可是..... 我不懂 pic programming, 也沒有燒錄器, 怎麼辦?! :(
离线BA5DX
只看该作者 8楼 发表于: 2004-06-30
pic 烧写器网上资料很多啊
离线huashao128
只看该作者 9楼 发表于: 2004-07-14
是否就是用来发送gps定位信息用的???
离线wgqaz
只看该作者 10楼 发表于: 2004-07-23
好东西呀.....支持中
离线VR2VJJ
只看该作者 11楼 发表于: 2004-09-12
找不到線路圖哦! :(
离线BD6CR
只看该作者 12楼 发表于: 2004-10-07
通过阅读source code,bd4os说的原板上多一个8pin ic的问题,可能是eeprom 93c66,连接到pic16c73的portc 2 3 4 5四pin。
离线BD4OS
只看该作者 13楼 发表于: 2004-10-07
需要两块93c66吗?电路图中已经有一块93c66,但板子上有两块8pin ic,不知道另外一块是什么?
离线BD6CR
只看该作者 14楼 发表于: 2004-10-07
你能给我看看照片吗?
离线VR2VJJ
只看该作者 15楼 发表于: 2005-03-24
再貼上一個 mim 及 pic-e 的線圖, 以供有興趣的 ham 參考.
(有人在做嗎? 呵呵)
附件: mim_schematics.zip (0 K) 下载次数:223
附件: PIC-E circuit.zip (0 K) 下载次数:285
