  • 4132阅读
  • 11回复
设备欣赏:VINTAGE SHORT WAVE HAM RADIO SARGENT WAC 44 1940 ERA [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-06-05
this is a great old e.m. sargent co 212 oakland ca. radio. ham radio,shortwave,vintage tube radio,tube radio receiver. communication receiver. they produced communications receivers from 1933 - 1940. this is the model wac - 44. production years 1940. bands/5, -- /.54 - 31 mhz if: 456 khz filter crystal/ tubes = 11, 2 6k7 rf , 6l7 mix, 6j7 hfo ,6k7 if1 ,6f7 1f2/mtr amp ,6h6 det/avc.6f7 af1/bfo/calib, 6f6 af out, vr-150 vr,80 rect////internal speaker ,panel trimmers for the two rf stages. radio is in great condition we used variac to power up..turns on and gets signal,,may need cleaning but seems to work well. case is in all original order no major damage at all,just some scratches and slight nicks. original issue headphones wiring schematic and instructions also come with this item. aprox dimensions are a follows 20.0"in wide 12.0"in wide 11.0"in deep. item weighs aprox 60.0 pounds. ser no # 6153 radio is being sold as is condition. buyer pays $78.00 fed ex - ground 5 day freight,ins,packing incl. --thank you and good luck bidding
离线BD3RJ
只看该作者 1楼 发表于: 2004-06-05
离线BD3RJ
只看该作者 2楼 发表于: 2004-06-05
离线BD3RJ
只看该作者 3楼 发表于: 2004-06-05
离线BD3RJ
只看该作者 4楼 发表于: 2004-06-05
离线BD3RJ
只看该作者 5楼 发表于: 2004-06-05
离线BD3RJ
只看该作者 6楼 发表于: 2004-06-05
离线BD7IWW
只看该作者 7楼 发表于: 2004-06-05
HAM的经典与古董
它和我同龄,哈哈!
目前它所用的管子中只是6l7(七极混频管)和6f7(三极/五极管)比较难找。
离线BD3RJ
只看该作者 8楼 发表于: 2004-06-05
它和我同龄,哈哈!
嘿嘿,该大修了吧? :d
离线BG7JYX
只看该作者 9楼 发表于: 2004-06-05
嘿嘿,该大修了吧? :d
看不到图的,3rj您这张帖要大修了 :d :d :d
离线BD3RJ
只看该作者 10楼 发表于: 2004-06-05
没问题的,国外网站就是慢。建议您晚上看。
离线bd5ik
只看该作者 11楼 发表于: 2005-12-13
图图.......图.看不到图:(
