  • 9844阅读
  • 20回复
功放欣赏:ACOM-1000 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-05-12
频率范围160-6m,功率1kw。这个功放和icom没有任何关系,估计是设计者喜欢iocm吧!好东西当然是好价格?1599欧元哦!
离线BD3RJ
只看该作者 1楼 发表于: 2004-05-12
离线BD3RJ
只看该作者 2楼 发表于: 2004-05-12
离线BD3RJ
只看该作者 3楼 发表于: 2004-05-12
离线BD3RJ
只看该作者 4楼 发表于: 2004-05-12
离线BD3RJ
只看该作者 5楼 发表于: 2004-05-12
离线BD3RJ
只看该作者 6楼 发表于: 2004-05-12
离线bg7iej
只看该作者 7楼 发表于: 2004-05-13
感觉欧洲那边出的东西个个都象艺术品..
离线bg2raq
只看该作者 8楼 发表于: 2004-05-13
用的什么功放管 这么猛
离线洋蕃芋
只看该作者 9楼 发表于: 2004-05-16
什么价格????????
离线BD3RJ
只看该作者 10楼 发表于: 2004-05-16
[quote=洋蕃芋]什么价格????????[/quote]
已经写上了,请仔细看。
离线BA0BZ
只看该作者 11楼 发表于: 2004-05-18
两只4CX800A/GU74b出力更牛X
acom 2000a amplifier
小图 | 大图 图片
  • 哈罗CQ火腿社区 - HAM软件、HAM网站 - 功放欣赏:ACOM-1000
离线BA0BZ
只看该作者 12楼 发表于: 2004-05-18
技术规格
rf output 1500-2000 w keyed carrier or ssb - no time limit. constant carrier modes 1500w rf output - no time limit with auxiliary cooling fan.
frequency coverage all amateur bands 1.8-24.5 mhz. 28 mhz only with modification by licensed amateurs.
bandchange / tuneup initial output matching process in less than 3 secs (typically 0.5 secs). preset matching process / bandchange takes less than 0.2 second to move to different segment, same band and less than 1 sec for qsy to different band.
tuning memories non-volatile for up to 10 antennas per frequency segment.
drive power typically 50w for 1500w output.
input impedance 50 ohms nominal. vswr <1.5:1.
output tolerance up to 3:1 vswr (2:1 on 160m) at full rated output before swr protection circuit actuates. higher swr's tolerated at lower output.
harmonics at least 50 db below peak output at 1500w.
intermodulation at least 35 db below peak output at 1500w.
t/r and keying vacuum relay: qsk capable.
tubes and circuit 4cx800a/gu74b tetrodes (2); resistive grid, pi-l output with rf negative feedback. regulated screen grid voltage.
alc negative going, grid derived, -11v max, rear panel adjustable.
metering comprehensive. remote control unit provides flexible monitoring of all amplifier operating parameters.
protection grid and screen current limiting, power inrush (soft-start provided), trip to excessive reflected power, rf arcs, password access protection if needed, correct t/r sequencing, tube exhaust overheat, cover interlock and hv crowbar.
fault diagnosis remote control unit display and led's plus "info box" for 12 most recent events. pc interface (rs-232), plus remote phone line interrogation feature.
cooling full cabinet forced-air. rubber isolated blower.
transformer 3.5 kva with strip-wound unisil-h?core.
ac power requirements 100/120/200/220/240 vac nominal. 50-60 hz. 3500va single phase at full power.
physical rf unit: 17-1/4"w x 7"h x 17-3/4"d
(440w x 180h x 450d mm).
rcu: 5-1/4"w x 6-3/4"d x 1" h
(135 x 25h x 170d mm).
shipped in two cartons total weight 80lb (36kg.) plug in transformer for ease of installation and transport.
no controls on rf unit except on/off. rf unit may be located up to 3 metres (10m with optional kit) from rcu.
离线BA0BZ
只看该作者 13楼 发表于: 2004-05-18
价格
http://www.hfpower.com/pricelist.htm
2001年的时候是5.5k美刀
离线VR2LW
只看该作者 14楼 发表于: 2004-05-18
電子管gu74b俄羅斯制造
离线BD3RJ
只看该作者 15楼 发表于: 2004-05-18
国内有替代型号吗       ?
离线BA0BZ
只看该作者 16楼 发表于: 2004-05-18
4CX800A/GU74
没有的…… :p
考虑4cx1000a/fu100f罢,体积大不了多少。
你买到4cx800a管座的难度绝对不亚于diy fu100f管座。
国内有替代型号吗       ?
离线BD3RJ
只看该作者 17楼 发表于: 2004-05-18
没有的…… :p
既然有苏制,国内应该有代换型号吧?
离线BA7IAG
只看该作者 18楼 发表于: 2004-05-18
2001年的时候是5.5k美刀
bz你是不是有一台?
离线BA0BZ
只看该作者 19楼 发表于: 2004-05-19
我有一台……
true legal-limit pwr dummy load
sic材料
bz你是不是有一台?
