  • 5288阅读
  • 6回复
最高可用传播频率(MUF)__北美(东海岸)至中国 [复制链接]
离线行者Z
只看楼主 倒序阅读 0楼 发表于: 2004-05-08
北美 至 中国 最高可用传播频率
maximum usable frequency
传播。。。传播。。。传播
may 2004
eastern to china
utc >>> 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23   (hour)
china (p) 19 19 18 17 16 16 15 15 14 14 15 16 17 17 17 18 18 19 18 17 16 16 19 20   (mhz ) 最高可用传播频率
离线FBI
只看该作者 1楼 发表于: 2004-05-08
传播。。。传播。。。传播
离线行者Z
只看该作者 2楼 发表于: 2004-05-17
http://www.spacew.com/www/realtime.html
near-real-time muf map
internet space weather and radio propagation forecasting course. we are accepting enrollments for this class now. the next class will commence on 16 june 2003.
the following image is a recent high-resolution map of maximum usable frequencies (mufs) for 3,000 kilometer radio signal paths. it is also a map showing the current location of the auroral ovals, the sunrise/sunset terminator and the regions of the world where the sun is 12 degrees below the horizon (which estimates the gray-line corridor where hf propagation is usually enhanced). this is map is similar to the plethora of constructable maps that is produced by proplab-pro version 2.0, a very powerful radio propagation software package for ibm or compatible computers, ideal for amateur or professional radio communicators. instructions on how to use this map follow below.
(this map is updated every 5 minutes.)
click on proplab-pro version 2.0 for additional map samples.
using this map
this is a highly informative map that can be used by amateur and professional radio communicators to determine maximum usable frequencies for any world-wide path at the indicated utc (zulu) time.
red contour lines will appear superimposed on the muf map if x-rays reach levels capable of producing short wave fadeouts on sunlit paths. when this occurs, the red contour lines represent the highest frequency (in mhz) that may be absorbed by the enhanced solar flare x-rays. use this information together with our new x-ray absorption map to determine what frequencies and paths may avoid affects of radio signal absorption during x-ray flares.
the muf for any 3,000 kilometer path can be determined by finding the midpoint (or half-way point) of the path and examining the muf at that midpoint on the map by finding the labelled muf contour value. all contours are given in mhz.
for 4,000 kilometer paths, multiply the given contoured muf values by 1.1. the muf for the given 4,000 km path is then determined at the midpoint of the desired path.
for longer path lengths, divide the path into equal 3,000 or 4,000 km segments and compute the mufs corresponding to the two midpoints that are 1,500 or 2,000 km from each end of the path. then select the lower of these two mufs.
the map shows the radio auroral zones as green bands near the northern and southern poles. the area within the green bands is known as the auroral zone. radio signals passing through these auroral zones will experience increased signal degradation in the form of fading, multipathing and absorption.
the radio auroral zones are typically displaced equatorward from the optical auroral zones (or the regions where visible auroral activity can be seen with the eye).
the great-circle signal path from the eastern united states to tokyo japan is shown along with the distance of the path (in km) and the great-circle bearing from the u.s. to tokyo (in degrees from north).
if this signal path crosses through the green lines indicating the position and width of the radio auroral zones, propagation will be less stable and degraded compared to if the signal never crossed through the auroral zones. using your mouse, proplab-pro will let you plot the great-circle paths and azimuths between any two points while this display is continually updated.
the yellow sun symbol near the equator indicates the location where the sun is directly overhead.
the regions of the world where the sun is exactly rising or setting is known as the grayline and is shown as the solid gray-colored line that is closest to the sun symbol.
the second solid gray-colored line defines the regions of the world where the sun is exactly 12 degrees below the horizon. this line defines the end of evening twilight. everything inside of this second line is experiencing night-time conditions.
the area between the two lines (shaded a lighter shade than the night-time sector) is known as the grayline and has special significance to radio communicators. signals which travel inside the grayline region often experience significant improvements in propagation because of the loss of ionization in the d-region as the sun sets. however, because the higher f-regions of the ionosphere remain strongly ionized for longer periods of time, signals with higher frequencies are able to travel to greater distances with less attenuation when they are within the grayline.
the great-circle path from the eastern u.s. to japan is also shown with the accompanying distance (in kilometers) and bearing (clockwise from north). notice how this path may occassionally pass into the influential auroral zones if geomagnetic activity increases or during the night-times.
return back to the main page
离线BG6QAM
只看该作者 3楼 发表于: 2004-05-17
弄个中文版本的好不好?弄个中文版本的好不好?
离线行者Z
只看该作者 4楼 发表于: 2004-05-18
美国频谱分布图
us spectrum file 美国频谱分布图 :) very detailed chart of all radio services, from dc to daylight
http://rtpnet.org/~rars/freqchrt.pdf
附件: USA.pdf (0 K) 下载次数:163
离线行者Z
只看该作者 5楼 发表于: 2004-05-25
Antenna Tuner
antenna tuner operation
i'm a little confused about how antenna tuners function in terms of reducing antenna system swr. is it true that an antenna tuner does not really 'tune' the antenna? and if an antenna is cut to resonance already, what good is a tuner?
yes, it's true-an antenna tuner doesn't really tune your antenna in the strict sense of the word. it does not, for example, adjust the lengths of your antenna elements, their heights above ground and so on. what an antenna tuner or transmatch does do, however, is transform the impedance at the feed line input to a value that your transceiver can handle (typically 50 ohm-see figure 1). when thinking about antenna tuners and swr, it's important to remember that the tuner has no effect whatsoever on the swr between itself and the antenna. it's the swr between the tuner and the transceiver that changes.
in practical terms, all a tuner does is act as a kind of adjustable impedance transformer between the antenna system and the radio. it takes whatever impedance the antenna system presents and attempts to convert it to 50 ohm--or something reasonably close to that value--for the transceiver. when the transceiver "sees" a 50 ohm impedance, it is able to load its maximum rf output into the system. that power is transferred through the antenna tuner, to the feed line and, ultimately, to the antenna--minus any losses incurred along the way.
these losses are the reason that the highest efficiency feed-line for each individual case is desirable and why some amateurs use ladder line.
(figure) (qst february 2000, p. 49)
what is the correct way to tune an antenna tuner?
most antenna tuners have an inductance rotary switch and two capacitors. the capacitors are often labeled antenna and transmitter. in some antenna tuners the inductance switch is replaced with a continuously variable inductance, popularly known as a roller inductor.
let's assume you're using a tuner with an inductance switch, because they are the most common. place both capacitor controls at their mid-range positions. don't trust the knob markers if this is your first experience with the tuner; remove the cover and turn the knobs until the moving capacitor plates are only half meshed with the stationary plates. if the knobs are pointing to half scale, consider yourself lucky. if not, loosen their allen nuts and rotate the knobs so that they point to mid scale. replace the tuner cover and you're ready to go.
turn the radio on and, with the antenna and transmitter controls at mid scale, crank the inductance switch until you hear the loudest noise or signals coming into your radio. then, rotate the antenna and transmitter controls until you get to the absolutely loudest noise or signal level on the radio. this should be close to your best tuning spot.
with your rig set to low power, send an id then transmit a continuous carrier while you tweak the antenna and transmitter controls for the lowest reflected power reading with the highest output power as read on the swr meter. you may find that you have to vary the position of the inductance switch a position or two to get your best match. be gentle to your radio; keep the key-down periods as short as possible.
depending on the impedance at the antenna input (and the overall design of the tuner) you may not be able to obtain a flat 1:1 swr on all frequencies and bands.
page last modified: 10:08 am, 23 apr 2001 et
page author: tis@arrl.org
copyright © 2001, american radio relay league, inc. all rights reserved.
离线BD2ALB
只看该作者 6楼 发表于: 2009-12-12
有没有中国全境内的实时传播预测!
