  • 9362阅读
  • 14回复
请教,kenwood Tm461 (现在为400-430),的扩频方法??谢谢! [复制链接]
离线疯狂10M
只看楼主 倒序阅读 0楼 发表于: 2002-09-01
谢谢各位高手了!
离线BG7IMJ
只看该作者 1楼 发表于: 2002-09-05
我也想知擴頻方法﹖﹖:confused: :confused: :rolleyes:
离线BG4RFF
只看该作者 2楼 发表于: 2002-09-07
自己翻译吧!
tm-461 expand the tx to 420 to 450mhz
1.take top cover off.
2.locate the green wire called w2.
3.cut and insulate both ends.
4.do a full re-set of the radio.
离线BG2UK
只看该作者 3楼 发表于: 2002-09-09
Re: 自己翻译吧!
原作者 bg4319208
这位仁兄在什么地方找到上述言论的啊?我想知道alinco 的dr-41扩频资料和使用说明。帮帮忙,告诉一下
谢谢
vy 73 !
离线aione
只看该作者 4楼 发表于: 2002-09-09
求< STANDARD C120手台> 说明书或请介绍使用方法
别人给我两台standard c120 150.00-159.99mhz,可以用的,每次我调乱了就只好用复位按钮,
离线aione
只看该作者 5楼 发表于: 2002-09-09
离线BG4RFF
只看该作者 6楼 发表于: 2002-09-09
Re: Re: 自己翻译吧!
原作者 bg2uk
谢谢
vy 73 !
给你dr140和dr430的dr41应该差不多,参照着试试吧!
1. open the top of the case by removing the three screws.
2. locate the blue loop of wire near the display, facing toward you.
3. cut the blue loop of wire, and tape up the ends.
4. replace cover of the radio.
5. reset the radio by holding the function key down and turning on the power.
dr430
1.unscrew the 3 small screws on the top cover.
2.gently remove the top cover.
3.cut the little loop wire (blue) that's located just behind the display, 2" left from the power button.
4.reassemble the radio.
5.reset the radio's cpu by turning power on while pressing the f key.
还是要自己翻译的,就算学学e文吧!
离线BG4RFF
只看该作者 7楼 发表于: 2002-09-09
还有DR110的
extended tx and rx for dr-110
find the yellow wire at the front left corner (next to the tuning knob)it makes a loop about 1 1/2
inches long.
clip the wire in two and insulate.
replace top cover.
reset the radio as per the manual. ( i.e. hold f and vfo/m button down while turning the radio on.
to change bands, press funtion followed by mhz button.
rig will change bands each time you do so.
this should allow reception from 130 - 169.995 mhz
te rig will also transmit from 103 - 169.995 mhz
just wanted to let you know about something that the mod does, that i didn't know at first....
130-170 receive and xmit
340-380 receive only
870-890 receive only
after you make the mod on the yellow wire, you reset the rig as per the mod. then to go from 130-170
to 340-380, you hit the f and mhz key. to go from 340-380, to the cellular 870-890, you hit the f and
mhz key again. to go from 870-890 back to 130-170, you hit the f and mhz again.
pretty neat.
just thought that you might to know what it will do......
this modification has been read 2017 times.
top of page
add a comment
到这网站看看http://www.mods.dk
离线chen-qingwei
只看该作者 8楼 发表于: 2002-09-10
Re: 请教,kenwood Tm461 (现在为400-430),的扩频方法??谢谢!
原作者 疯狂10m
谢谢各位高手了!
找bg4ien试试看!!!:d :d :d
离线aione
只看该作者 9楼 发表于: 2002-09-10
Re: Re: 请教,kenwood Tm461 (现在为400-430),的扩频方法??谢谢!
我用的机器是定做的tm-461a(400-470mhz)
离线BG7IMJ
只看该作者 10楼 发表于: 2002-09-11
Re: Re: Re: 请教,kenwood Tm461 (现在为400-430),的扩频方法??谢谢!
原作者 aione
aione ﹕你好﹗
請問你的機器是如何定做的﹖你有打開機器看過嗎﹖﹖﹖:confused: :confused: :confused:
离线BG7IMJ
只看该作者 11楼 发表于: 2002-09-12
461原400-430經改動可顯示400-470但無法發射﹗﹗﹗
461機器內找不到綠色線﹗﹗﹗:eek: :eek: :( :( :(
离线bd4vuf
只看该作者 12楼 发表于: 2002-09-30
Re: 求< STANDARD C120手台> 说明书或请介绍使用方法
原作者 aione
本人也有一台,和c412使用方法一样如需要发信给我!
离线bd4vuf
只看该作者 13楼 发表于: 2002-09-30
Re: Re: 求< STANDARD C120手台> 说明书或请介绍使用方法
原作者 bd4vuf
本人也有一台,和c420使用方法一样如需要发信给我!
离线台风
只看该作者 14楼 发表于: 2002-10-01
原作者 疯狂10m
谢谢各位高手了!
我建议你不要扩频,因扩频后接收显示频率与实际接收频率不一样(程序原因),使用不方便(可能的话改中频)
        台风   bg4idf
