  • 3729阅读
  • 0回复
关于JARL AJD的申请 [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2004-03-09
最近有ham来信问到日本ajd奖状如何申请,他们有很多种奖状可以申请,详细的信息请参考:
http://www.jarl.or.jp/english/4_library/a-4-2_awards/award_main.htm
general rules(一般性规则)
jarl awards will be issued to amateur stations and swls.
each claim must be accompanied by a qsl card list furnished with the callsigns of stations worked (heard), dates, bands and modes of the contacts (receptions) meeting the requirments of the award concerned. the form of list will be specified, when required, in the rules of each award.
each list must be accompanied by a statement from the applicant's national society or from any two licensed amateurs other than the applicant certifying that the qsl cards of the contacts listed are in the possession of the applicant and that the items of the cards are correctly listed. if such a statement is not available, the applicant must submit all the qsl cards concerned.
foreign non-jarl members will be charged 12 ircs per award. if qsl cards are submitted, sufficient funds for return postage will also be required. stickers for aja and wasa will be 6 ircs regardless of the number of stickers issued per application. stickers for jcc and jcg will be 6ircs per application.
applicants can request for maximum three of the following four endorsements:
bands (only contacts made within the same band): all amateur bands
modes (only contacts made in the same mode): cw, am ssb, fm, sstv, rtty, atv, fax
satellites (only contacts made through amateur satellite)
qrp (only contacts made through transmitters with output of 5 watts or less)
qrpp (only contacts made through transmitters with output of 0.5 watts or less)
only contacts (receptions) made on and after july 29, 1952 will be acceptable.
only contacts with land stations (including mobile stations on a river or lake) will be acceptable. those with maritime and aeronautical stations, however, will be acceptable for the 50mhz-100, 144mhz-100, 430mhz-100, 1200mhz, 2400mhz, 5600mhz, 10ghz, 24ghz, 47ghz, 75ghz and vu-1000 awards.
only contacts with amateur stations authorized by the administration will be acceptable. contacts with the far east military auxiliary stations in japan will not be acceptable.
all contacts must be made on land (river/lake) within the same entity.
all correspondence should be sent to:
japan amateur radio league - award desk
1-14-5 sugamo, toshima, tokyo 170-8073, japan
email: oper@jarl.or.jp
