  • 3793阅读
  • 12回复
HY-GAIN天线参数 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-02-15
hygain 3 element 10m yagi -- 103ba
hy-gain 103ba, novice/tech setting
28.0 28.4 28.8 28.2 mhz
3 elements, inches
      1.000 0.875   0.625   0.4375
0     3.500 41.125 21.5   45.375
40.625   3.500 21.375 23.5   55.250
91.250   3.500 21.125 23.5   51.125
hy-gain 103ba, low phone setting
28.5 28.75 29.0 28.7 mhz
3 elements, inches
0     3.500 41.125 21.5   43.625
40.625   3.500 21.375 23.5   53.125
91.250   3.500 21.125 23.5   49.625
hy-gain 103ba, mid phone setting
28.8 29.1 29.4 29.1 mhz
3 elements, inches
0     3.500 41.125 21.5   41.375
40.625   3.500 21.375 23.5   51.500
91.250   3.500 21.125 23.5   47.500
离线BD3RJ
只看该作者 1楼 发表于: 2004-02-15
hygain 5 element 10m yagi -- 105ca
hy-gain 105ba, cw setting
28.0 28.3 28.6 28.25 mhz
5 elements, inches
          0.875   0.625   0.4375
  0.000     45.000   21.500   42.500
93.250     25.250   23.500   54.000
150.000     25.000   23.500   52.250
202.750     25.000   23.500   47.000
274.750     25.000   23.500   45.750
hy-gain 105ba, low-phone setting
28.500 28.750 29.000 28.700 mhz
5 elements, inches
      0.8750   0.6250   0.4375
0.000   45.0000   21.5000   41.0000
92.000   25.2500   23.5000   52.0000
148.000   25.0000   23.5000   50.7500
200.000   25.0000   23.5000   45.7500
271.000   25.0000   23.5000   44.5000
hy-gain 105ca cw setting
28.000 28.200 28.400 28.200 mhz
5 elements, inches
      1.0000   0.8750   0.6250   0.4375
0.000   3.5000   41.5000   21.5000   42.2500
58.000   3.7500   21.5000   23.5000   54.3750
103.000   3.5000   21.5000   23.5000   53.5000
186.500   3.5000   21.5000   23.5000   51.7500
286.500   3.5000   21.5000   23.5000   48.0000
this setting of the 105ca is centered on 28.200 mhz
for cw operation. it has a 2:1 vswr band-width of
1100 khz centered on 28.200. maximum gain is 8.20
dbd and maximum f/b is 27 db.
beta rod length= 17 inches (measured from inside
tubing edge to outside edge of clamp).   pigtail
length= 7 inches. balun= hy-gain bn-4000 (current
type)
radiation patterns and vswr were verified in
september 1991. 9-18-91 rc
hy-gain 105ca low phone setting
28.000 28.400 28.800 28.400 mhz
5 elements, inches
0.000   3.5000   41.5000   21.5000   41.5000
58.000   3.7500   21.5000   23.5000   53.3750
103.000   3.5000   21.5000   23.5000   52.7500
186.500   3.5000   21.5000   23.5000   51.0000
286.500   3.5000   21.5000   23.5000   47.2500
this setting of the 105ca is centered on 28.400 mhz
for low phone operation. it has a 2:1 vswr band-
width of 1100 khz centered on 28.400. maximum gain
is 8.22 dbd and maximum f/b is 27 db.
type)
radiation patterns and vswr were verified in september
1991. 9-18-91 rc
hy-gain 105ca mid phone setting
28.400 28.800 29.200 28.800 mhz
5 elements, inches
0.000   3.5000   41.5000   21.5000   40.000
58.000   3.7500   21.5000   23.5000   52.250
103.000   3.5000   21.5000   23.5000   51.375
186.500   3.5000   21.5000   23.5000   49.625
286.500   3.5000   21.5000   23.5000   45.875
this setting of the 105ca is centered on 28.800 mhz
for mid phone operation. it has a 2:1 vswr band-
width of 1100 khz centered on 28.800. maximum gain
is 8.26 dbd and maximum f/b is 27 db.
type)
1991.   9-18-91 rc
hy-gain 105ca oscar/fm setting
29.300 29.500 29.700 29.500 mhz
5 elements, inches
0.000   3.5000   41.5000   21.5000   37.125
58.000   3.7500   21.5000   23.5000   49.500
103.000   3.5000   21.5000   23.5000   48.625
186.500   3.5000   21.5000   23.5000   46.875
286.500   3.5000   21.5000   23.5000   43.250
this setting of the 105ca is centered on 29.500 mhz
for oscar satellite and fm operation. it has a 2:1
vswr band-width of 1000 khz centered on 29.500.
maximum gain is 8.35 dbd and maximum f/b is 27 db.
type)
1991. 9-18-91 rc
hy-gain 105ca broad-band setting
28.000 28.800 29.700 28.800 mhz
5 elements, inches
0.000   3.5000   41.5000   21.5000   42.0000
58.000   3.7500   21.5000   23.5000   51.5000
103.000   3.5000   21.5000   23.5000   49.0000
186.500   3.5000   21.5000   23.5000   48.0000
286.500   3.5000   21.5000   23.5000   43.5000
this setting of the 105ca is suitable for operation
anywhere in the 10 meter band. it has a 2:1 vswr
band-width of 1700 khz centered on 28.800 mhz.
maximum gain is 8.20 dbd and maximum f/b is 24 db.
beta rod length= 28.375 inches (measured from inside
type).
1991. 9-18-91 rc
hy-gain 105ca max f/b setting
28.200 28.500 28.800 mhz
5 elements, inches
58.000   3.7500   21.5000   23.5000   54.250
103.000   3.5000   21.5000   23.5000   52.500
186.500   3.5000   21.5000   23.5000   45.875
286.500   3.5000   21.5000   23.5000   38.250
this setting of the 105ca is centered on 28.500 mhz
for phone operation. it features an extremely high
front-to-back ratio. 2:1 vswr band-width is 600 khz,
maximum gain is 7.56 dbd, and maximum f/b is 36 db.
beta rod length= 10.375 inches (measured from inside
type).
1991. 9-18-91 rc
hy-gain 105ca max gain setting
28.300 28.500 28.700 mhz
5 elements, inches
0.000   3.5000   41.5000   21.5000   40.625
58.000   3.7500   21.5000   23.5000   51.250
103.000   3.5000   21.5000   23.5000   49.375
186.500   3.5000   21.5000   23.5000   50.625
286.500   3.5000   21.5000   23.5000   49.125
for phone operation. it features higher gain than
the normal settings. 2:1 vswr band-width is 400 khz,
maximum gain is 8.60 dbd, and maximum f/b is 23 db.
beta rod length= 13.875 inches (measured from inside
type).
1991. 9-18-91 rc
离线BD3RJ
只看该作者 2楼 发表于: 2004-02-15
hygain 3 element 15m yagi -- 153ba
hy-gain 153ba cw setting
21.0 21.2 21.4 mhz
3 elements, inches
    1.000   0.875   0.500   0.4375
0.0   3.625   78.125   3.250   64.625
64.0   3.625   66.125   3.250   66.000
138.875 3.625   66.125   3.250   60.250
hy-gain 153ba phone setting
21.0 21.2 21.4 mhz
3 elements, inches
0.0   3.625   78.125   3.250   63.125
64.0   3.625   66.125   3.250   64.500
138.875 3.625   66.125   3.250   58.750
离线BD3RJ
只看该作者 3楼 发表于: 2004-02-15
hygain 5 element 15m yagi -- 155ca
hy-gain 155ca cw setting
21.050 21.150 21.250 21.150 mhz
5 elements, inches
      1.0000   0.8750   0.5000   0.4375
0.000   3.6250   78.1250   3.2500   65.6250
73.000   3.6250   66.1250   3.2500   66.7500
130.000   3.6250   66.1250   3.2500   64.3750
203.000   3.6250   66.1250   3.2500   56.3750
309.000   3.6250   66.1250   3.2500   55.7500
this setting of the 155ca is centered on 21.150 mhz
400 khz centered on 21.150. maximum gain is 7.5 dbd
and maximum f/b is 25 db.
beta rod length= 11.625 inches (measured from tubing
center to inside edge of clamp). pigtail length= 7
inches. balun= hy-gain bn-86 (voltage type).
radiation patterns and vswr were verified in october
1990. 9-20-91 rc
hy-gain 155ca mid setting
21.150 21.250 21.350 21.250 mhz
5 elements, inches
0.000   3.6250   78.1250   3.2500   65.0000
73.000   3.6250   66.1250   3.2500   66.0000
130.000   3.6250   66.1250   3.2500   63.6250
203.000   3.6250   66.1250   3.2500   55.7500
309.000   3.6250   66.1250   3.2500   55.1250
this setting of the 155ca is centered on 21.250 mhz
for phone operation. it has a 2:1 vswr band-width of
400 khz centered on 21.250. maximum gain is 7.6 dbd
1990. 9-20-91 rc
hy-gain 155ca phone setting
21.250 21.350 21.450 21.350 mhz
5 elements, inches
0.000   3.6250   78.1250   3.2500   64.2500
73.000   3.6250   66.1250   3.2500   65.2500
130.000   3.6250   66.1250   3.2500   63.0000
203.000   3.6250   66.1250   3.2500   55.1250
309.000   3.6250   66.1250   3.2500   54.5000
this setting of the 155ca is centered on 21.350 mhz
400 khz centered on 21.350. maximum gain is 7.6 dbd
1990. 9-20-91 rc
hy-gain 155ca, max f/b setting
21.000 21.250 21.500 21.260 mhz
5 elements, inches
0.000   3.6250   78.1250   3.2500   60.6250
130.000   3.6250   66.1250   3.2500   63.8750
203.000   3.6250   66.1250   3.2500   45.8750
309.000   3.6250   66.1250   3.2500   48.0000
and is optimized for extremely high front-to-back
ratios. it has a 2:1 vswr band-width of 400 khz
centered on 21.250. maximum gain is 7.1 dbd and
maximum f/b is 40 db.
1990. 9-20-91 rc
离线BD3RJ
只看该作者 4楼 发表于: 2004-02-15
hygain 3 element 20m yagi -- 203ba
hy-gain 203ba, cw setting
14.000 14.100 14.200 mhz
3 elements, inches
      4.0000   1.2500   0.8750   0.4375
0.000   3.6250   69.3750   81.0000   68.5000
86.0000   3.6250   69.8750   69.0000   69.5000
189.250   3.6250   57.3750   69.0000   66.2500
  effects of the element-to-boom clamp and boom
have been modeled here by a cylindrical taper
section 3.625" long and 4.0" diameter. the clamp is
7.25" long by 3.25" wide and passes the element
through a 2"-diameter boom.
hy-gain 203ba, phone setting
14.150 14.250 14.350 mhz
3 elements, inches
86.0000   3.6250   69.8750   69.0000   67.0000
离线BD3RJ
只看该作者 5楼 发表于: 2004-02-15
hygain 4 element 20m yagi -- 204ba
hy-gain 204ba, cw setting
4 elements, inches
      4.0000   1.2500   1.1250   0.8750   0.6250   0.4375
0.000   3.6250   41.8750   46.0000   50.5000   24.0000   53.0000
122.875   3.6250   32.3750   46.0000   50.5000   24.0000   53.0000
211.625   3.6250   18.3750   46.0000   50.5000   24.0000   53.0000
307.250   3.6250   14.1250   46.0000   50.5000   24.0000   53.0000
hy-gain 204ba, phone setting
4 elements, inches
0.000   3.6250   41.8750   46.0000   50.5000   24.0000   50.0000
122.875   3.6250   32.3750   46.0000   50.5000   24.0000   50.0000
211.625   3.6250   18.3750   46.0000   50.5000   24.0000   51.0000
307.250   3.6250   14.1250   46.0000   50.5000   24.0000   49.0000
离线BD3RJ
只看该作者 6楼 发表于: 2004-02-15
hygain 5 element 20m yagi -- 205ca
hy-gain 205ca, cw setting
14.050 14.150 14.250 14.160 mhz
5 elements, inches
0.000   3.6250   41.8750   46.0000   50.5000   24.0000   55.7500
100.000   3.6250   32.3750   46.0000   50.5000   24.0000   53.7500
175.000   3.6250   32.3750   46.0000   50.5000   24.0000   49.7500
270.000   3.6250   14.1250   46.0000   50.5000   24.0000   49.3750
408.000   3.6250   14.1250   46.0000   50.5000   24.0000   36.7500
this setting of the 205ca is centered on 14.150 mhz
400 khz centered on 14.125. maximum gain is 6.5 dbd
and maximum f/b is 30 db.
tubing edge to outside edge of clamp). pigtail length=
7 inches. balun= hy-gain bn-86 (voltage type).
radiation patterns and vswr were verified in july
1990. 9-23-91 rc
hy-gain 205ca, phone setting
14.150 14.250 14.350 14.260 mhz
5 elements, inches
0.000   3.6250   41.8750   46.0000   50.5000   24.0000   54.1875
100.000   3.6250   32.3750   46.0000   50.5000   24.0000   52.2500
175.000   3.6250   32.3750   46.0000   50.5000   24.0000   48.2500
270.000   3.6250   14.1250   46.0000   50.5000   24.0000   48.0000
408.000   3.6250   14.1250   46.0000   50.5000   24.0000   35.5000
this setting of the 205ca is centered on 14.250 mhz
400 khz centered on 14.200. maximum gain is 6.5 dbd
1990. 9-23-91 rc
hy-gain 205ca, max gain setting
14.100 14.200 14.300 mhz
5 elements, inches
0.000   3.6250   41.8750   46.0000   50.5000   24.0000   60.5000
79.000   3.6250   32.3750   46.0000   50.5000   24.0000   54.5000
149.000   3.6250   32.3750   46.0000   50.5000   24.0000   51.7500
259.000   3.6250   32.3750   46.0000   50.5000   24.0000   45.7500
408.250   3.6250   14.1250   46.0000   50.5000   24.0000   59.0000
radiation patterns and vswr have not been verified yet.
9-23-91 rc
离线BD3RJ
只看该作者 7楼 发表于: 2004-02-15
hygain 3 element 17m yagi -- 173ba
hy-gain 173ba rev 1.0
18.125   mhz
3 elements, inches
0.000   3.6250 69.3750 55.0000 44.6250
86.000   3.6250 69.3750 47.0000 42.1250
189.250   3.6250 57.3750 47.0000 50.5000
this design is a modification of the hg203ba.
it was developed by hy-gain using
yo 4.0. vswr only verified. rc 9-8-93
离线BD3RJ
只看该作者 8楼 发表于: 2004-02-15
hygain 4 element 17m yagi -- 174ba
hy-gain 174ba
18.100   mhz
4 elements, inches
      3.5000   1.2500   1.1250   0.8750   0.6250   0.4375
0.000   3.6250 41.8750 46.0000 25.0000 24.0000 30.7500
97.500   3.6250 32.3750 46.0000 25.0000 24.0000 29.5000
168.000   3.6250 18.3750 46.0000 25.0000 24.0000 36.5000
244.000   3.6250 14.1250 46.0000 25.0000 24.0000 35.7500
  this design is a modification of the hg204ba.
it was developed by hy-gain engineer roger cox using
yo 3.0 (mininec calibration).
离线BD3RJ
只看该作者 9楼 发表于: 2004-02-15
hygain 5 element 17m yagi -- 175ca
hy-gain 175ca
18.000 18.100 18.200 mhz
5 elements, inches
        5.0000   1.2500   1.1250   0.8750   0.6250   0.4375
0.0000   3.6250   41.8750   46.0000   25.0000   24.0000   35.8750
88.6250   3.6250   32.3750   46.0000   25.0000   24.0000   31.2500
167.2500   3.6250   32.3750   46.0000   25.0000   24.0000   28.0000
249.1250   3.6250   14.1250   46.0000   25.0000   24.0000   37.2500
407.3750   3.6250   14.1250   46.0000   25.0000   24.0000   31.7500
  the pattern of this model comes within a couple
db of actual range measurements from 17.0 through
18.6 mhz.
离线BD3RJ
只看该作者 10楼 发表于: 2004-02-15
hygain 5 element 12m yagi -- 125ca
hy-gain 125ca
24.800 24.900 25.000 24.940 mhz
5 elements, inches
0.000   3.6250   78.1250   3.2500   40.1250
73.000   3.6250   66.1250   3.2500   43.8750
130.000   3.6250   66.1250   3.2500   42.0000
203.000   3.6250   66.1250   3.2500   36.0000
309.000   3.6250   66.1250   3.2500   32.1250
the 125ca is an optional setting for the 155ca yagi.
it is centered on 24.940 mhz for cw and phone
operation. vswr is less than 1.5 over the entire
band. maximum gain is 7.8 dbd and maximum f/b is
28 db.
1990. 9-20-91 rc
离线cnnets
只看该作者 11楼 发表于: 2004-05-16
这个如何用?e文不太明,谢了。
离线bg4adm
只看该作者 12楼 发表于: 2004-05-21
3rj是高手中的高手,情报搜集官哦,呵呵,佩服佩服...
不过只能当作参考啦...
