  • 14984阅读
  • 33回复
KENWOOD机器复位方法 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2004-02-15
1. tm-201a/401a/211a/411a - depress the reset switch with a non conductive rod
through the reset opening on the bottom cover.
2. tm-221a/321a/421a/521a ? with the power off press the vfo/m, & m.in keys,
and turn the radio on.
3. tm-231a/331a/431a/531a ? with the power off press the mr key, and turn the
power on.
4. tm-241a/441a/541a ? with the power off press the mr/m key, and turn the
power on.
5. tm-2530a/2550a/2570a/3530a ? with the power off press the ps key, and turn
the power on.
6. tm-701a ? with the power off press the mr key, and turn the radio on.
7. tm-621a/721a ? with the power off press the f key, and turn the radio on.
8. tm-631a/731a ? with the power off press the mr key, and turn the radio on.
9. tm-641a/741a/941a ? with the power off
a. vfo reset individual band: press the vfo key, & the band sel, and turn the
radio on.
b. all band vfo reset: press the vfo key, and turn the radio on.
c. all band memory reset: press the mr key, and turn the radio on.
d. individual memory band reset: press the f key, & band sel key, and turn
the power on.
10. tm-642a/742a/942a ? with the power off
the radio on.
turn the radio on.
11. tm-251a/451a ? with the radio off
a. partial reset press the vfo key, and turn the radio on.
b. full reset press the mr key, and turn the radio on.
12. tm-732a ? vfo reset with the power off press the vfo key, and turn the radio
on. memory reset with the power off press the mr key, and turn the radio on.
13. tm-733a ? partial reset ? single band press the vfo, & band sel key, and
turn the radio on. partial reset both bands press the vfo key, and turn the
radio on. tm-733a full reset with the radio off press the mr key, and turn the
radio on. the ok-mr-key flashes in the display, now press the mr again to
complete the reset procedure.
14. tm-255a/455a ? partial reset with the power off press the a/b key, and turn
turn the radio on. full reset press the mr key, and turn the radio on.
15. tr-7930/7950 ? to reset the radio turn the radio upside down, there is a hole in
the bottom cover near the front , press the microswitch for reset.
16. tw-4000a ? turn on power and set the transceiver in receive mode. short the
2p terminal once for the microprocessor reset. used a non conductive object.
there is a small hole in the bottom cover close to the front panel, and centered
in the middle of the radio. (when resetting be sure not to short
any pins other than 2p terminal to prevent the microprocessor
from being damaged)
17. tw-4100a ? with the power off press the m key, and turn the power on.
18. tr-50 ? with the power on use a non conductive object to reset the radio
through a small hole in the bottom cover.
19. tr-751a/851a ? with the power off press the m key, and turn the radio on.
20. tr-2600a/3600a ? with the power on insert a non-metallic rod into the small
hole in the backside of the case close to the battery to reset.
21. tr-2500a/3500a ? with the power on insert a non-metallic rod into the small
22. rz-1 ? with the power off press the enter key, and turn the radio on.
this will reset everything but your memories. for a full reset press the m key,
23. r-2000 ? disconnect the power cable with the power switch on. remove the
receiver top cover ( 8 screws). ground pin 40 of the ic-12 on the pll unit for
about 5 seconds. reconnect power, keep the m.in switch depressed and ground
pin 29 of ic-12 for a few seconds. remove and then reinsert the power cable.
24. r-5000 - with the radio off press the a=b button, and turn the radio on. the
display will show 14.000 mhz.
25. th-215a/315a/415a/225a ? with the radio off press the f, & enter key, and
turn the radio on.
26. th-25a/45a/55a ? with the radio off press the m key, and turn the radio on.
27. th-26a/46a ? with the power off press the vfo key, and turn the radio on for
a vfo reset. for a full reset press the f key, and turn the radio on.
28. th-27a/47a ? with the power off press the m key, and turn the radio on for
memory reset. for vfo reset press the vfo key, and turn the radio on.
29. th-28a/48a ? with the power off press the m key, and turn the radio on for
memory reset. for vfo reset press the f key, and turn the radio on.
30. th-235a ? with the power off press the f key, and turn the radio on for
31. th-22at/42at -with the power off press the f key for memory reset, and turn
the radio on. for vfo reset with the power off press the vfo key, and turn the
radio on.
32. th-g71a - with the power off press the f key for (memory reset), and turn the
radio on. for vfo reset with the power off press the vfo key, and then turn
the radio on.
33. th-79a/ad/akss - with the power off press the f key for (memory reset),
and turn the radio on. for vfo reset with the power off press the vfo key,
and then turn the radio on.
34. th-d7a, th-d7a(g) ? with the power off press the f key, and turn the radio
on. reset appears in the screen, now press up or down on the jog cursor to
select either vfo or full reset, now press ok. now press up or down, and
select yes or no now press ok.
35. th-75a ? with the power off press the m key, and turn the radio on.
36. th-77a - with the power off press the m key, and turn the radio on for
memory reset. for vfo reset press the ent key, and turn the radio on.
37. th-78a - with the power off press the m key, and turn the radio on for
38. ts-670 ? with the power off press the hold key, and turn the radio on.
39. ts-430s/440s/140s/450s/680s/\690s/711a/790a/811a/850s/940s/950s,sd,sdx/
ts -50s/60s/570d/s/ 870s with the power off press the a=b key, & power on.
40. ts-2000/ts-2000x/ts-b2000 with the power off (partial reset), press the a/b
and turn the radio on. with the power off (full reset), press the a=b key and
turn the power on.
41. tm-261a / tm-461a ? with the radio off press the mr key (memory reset),
and turn the radio on. for a vfo reset with the radio off press the vfo key,
42. tm-g707a ? with the radio off press the mr key (memory reset), and turn
the radio on, next step press ok. for a vfo reset with the radio off press the
vfo key, and then turn the radio on, next step press ok.
43. tm-v7a ? with the radio off press the mr key (memory reset), and turn the
the radio on, then press the mr key again. vfo reset with the radio off press
the vfo key, and turn the radio on, then press the vfo again.
44. tm-d700a ? with the radio off press the mr key (memory reset), and turn
the radio on, now press ok. vfo reset with the radio off press the vfo key,
and turn the radio on, now press ok.
离线BG4IIU
只看该作者 1楼 发表于: 2004-03-08
有中文的吗
离线bg7oo
只看该作者 2楼 发表于: 2004-03-08
kenwood机器复位方法
power on.
power on.
the power on.
radio on.
the power on.
the radio on.
turn the radio on.
from being damaged)
turn the radio on.
radio on.
the radio on.
turn the power on.
离线bg3mdz
只看该作者 3楼 发表于: 2004-03-08
回复: KENWOOD机器复位方法
[英语学的还是不好啊.下决心学.quote]最初由 bg3rj 发表
power on.
power on.
the power on.
7. tm-621a/721a ? with the power off press the f key, and turn the radio on.英语学的还是不啊.下决心学.
radio on.
the power on.
the radio on.
turn the radio on.
from being damaged)
turn the radio on.
radio on.
the radio on.
turn the power on.
[/quote]
离线京海淀
只看该作者 4楼 发表于: 2004-03-13
给个中文的
离线BD6AS
只看该作者 5楼 发表于: 2004-03-13
最初由 京海淀 发表
给个中文的
试试?弄坏了自己负责.别说我没提醒.
73!
kenwood机器复位方法
1. tm-201a/401a/211a/411a :
用一个非金属棒通过底盖的复位开关孔按下复位开关即可
2. tm-221a/321a/421a/521a ?:
在电源关断的状态下,同时按下vfo/m,和 m.in键,开机。
3. tm-231a/331a/431a/531a ? :
在电源关断的状态下,按下mr键,开机。
4. tm-241a/441a/541a ? :
在电源关断的状态下,按下mr/m键,开机。
5. tm-2530a/2550a/2570a/3530a ? :
在电源关断的状态下,按下ps键,开机。
6. tm-701a ? :
在电源关断的状态下,按下mr键,开机。
7. tm-621a/721a ?:
在电源关断的状态下,按下f键,开机。
8. tm-631a/731a ? :
在电源关断的状态下,按下mr键,开机。
9. tm-641a/741a/941a ? :
在电源关断的状态下:
a. vfo 复位单段: 同时按下vfo键和sel频段选择键,开机。b.全段vfo复位: 同时按下vfo键,开机。c.全段memory复位:按下mr键,开机。d.单memory段复位:同时按下f键和sel频段选择键,开机。
10. tm-642a/742a/942a ? :
在电源关断的状态下:
a.vfo 复位单段:同时按下vfo键和sel频段选择键,开机。b.全段vfo复位:按下vfo键,开机。c. 全段memory复位:按下mr键,开机。d.单memory段复位:同时按下f键和sel频段选择键,开机。
11. tm-251a/451a ?:
在电源关断的状态下:
a.部分复位,按下vfo 键,开机。b.全部复位,按下mr键,开机。
12. tm-732a ?:
a. vfo 复位:在电源关断的状态下,按下vfo键,开机。 b. memory复位:在电源关断的状态下,按下mr键,开机。
13. tm-733a ? :
a.部分复位单段?:同时按下vfo 键, 和频段band sel键,开机。b.部分复位双段:按下vfo 键,开机。c.tm-733a全部复位:在电源关断的状态下,按下mr键,开机。
显示屏上闪动“ok-mr-key”此时再按一下mr键完成复位过程。
14. tm-255a/455a ? :
a.部分复位:按下a/b 键, 开机。b.全部复位:在电源关断的状态下,按下mr键,开机。
15. tr-7930/7950 ? 复位机器:
将电台反转向上,在前面板旁底板处有一小孔,按下微动开关,复位机器。
16. tw-4000a ? :
打开电源,将机器设置在接收状态,用非金属棒将终端的两针短路一下,复位cpu。在机器底部位于中央靠近前面板的位置上有一小孔。当复位完毕后,除2p终端可以短路外,请勿短路其他任何针脚。
17. tw-4100a ? :
在电源关断的状态下,按下mr键,开机。
18. tr-50 ? :
在电源接通的状态下,用一个非金属棒,通过机器底部的一个小孔复位电台。
19. tr-751a/851a ?
在电源关断的状态下,按下m键,开机。
20. tr-2600a/3600a ? :
在电源接通的状态下,将一个非金属棒塞入在机箱后面靠近电池处的一个小孔中按一下即可复位。
21. tr-2500a/3500a ? :
22. rz-1 ?:
在电源关断的状态下,按一下enter键,开机。这将会复位除了所存储的频道以外的所有数据。对于全部复位,按着m键,开机即可。
23. r-2000 ?:
在电源开关位于“通”的状态下,拔下电源线。拆去接收机上盖板(8个螺丝)。将频率合成器单元上的ic-12的第40脚对地短路大约5秒钟左右。重接上电源,按下m.in 开关,同时将频率合成器单元上的ic-12的第29脚对地短路大约几秒钟左右。拔下电源线,然后重新接通电源即可。
24. r-5000:
在电源关断的状态下,按下a=b键,开机。显示屏将会出现“14.000 mhz”。
25. th-215a/315a/415a/225a ? :
在电源关断的状态下,按下f键,开机。
26. th-25a/45a/55a ?:
在电源关断的状态下,按下m键,开机。
27. th-26a/46a ? :
在电源关断的状态下: 对于vfo复位,按下vfo键,开机。对于全部复位说来,在电源关断的状态下,按下f键,开机即可。
28. th-27a/47a ? :
在电源关断的状态下,按下m键,开机,可以复位存储频道数据。对于vfo说来,在电源关断的状态下,按下vfo键,开机即可。
29. th-28a/48a ? :
在电源关断的状态下,按下m键,开机可以复位存储频道数据到出厂模式。在电源关断的状态下,按下f键,开机可以复位vfo数据到出厂模式。
30. th-235a ? :
在电源关断的状态下,按下f键,开机可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键,开机可以复位vfo数据到出厂模式。
31. th-22at/42at:
32. th-g71a -在电源关断的状态下,按下f键,开机可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键,开机可以复位vfo数据到出厂模式。
33. th-79a/ad/akss:
34. th-d7a, th-d7a(g) ?:
  在电源关断的状态下,按下f键,开机,屏幕显示复位,按上下键确认是复位vfo数据到出厂模式还是全部复位数据到出厂模式,选中后接着按下ok键确认。然后用上下键选择yes或者no ,最后按下ok键结束.
35. th-75a ?:
在电源关断的状态下,按下m键,开机可以复位数据到出厂模式。
36. th-77a:
在电源关断的状态下,按下m键,开机可以复位存储频道数据到出厂模式。在电源关断的状态下,按下ent键,开机可以复位vfo数据到出厂模式。
37. th-78a :
38. ts-670 ? :
在电源关断的状态下,按下hold键,开机可以复位数据到出厂模式。
ts -50s/60s/570d/s/ 870s :
在电源关断的状态下,按下a/b键,开机可以复位。
40. ts-2000/ts-2000x/ts-b2000 :
在电源关断的状态下,(部分复位)按下a/b键,开机可以复位。在电源关断的状态下,(全部复位)按下a=b键,开机可以复位数据到出厂模式。
41. tm-261a / tm-461a ? :
在电源关断的状态下,按下mr键,开机可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键,开机可以复位vfo数据到出厂模式。
42. tm-g707a ? :
在电源关断的状态下,按下mr键,开机,接着按ok键,可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键,开机,然后按ok键,可以复位vfo数据到出厂模式。
43. tm-v7a ?:
在电源关断的状态下,按下mr键,开机,接着再按一下mr键,可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键开机,接着再按一下vfo键就可以复位vfo数据到出厂模式。
44. tm-d700a ? :
在电源关断的状态下,按下mr键,开机,接着按下ok键,可以复位存储频道数据到出厂模式。在电源关断的状态下,按下vfo键开机,然后按下ok键,可以复位vfo数据到出厂模式。
离线BD6AS
只看该作者 6楼 发表于: 2004-03-13
希望对朋友们有用.
离线bd8bq
只看该作者 7楼 发表于: 2004-03-22
有没有tk378的复位方法?
离线zhangyi
只看该作者 8楼 发表于: 2004-03-29
非常好的资料,谢谢楼上的
离线BG4VOE
只看该作者 9楼 发表于: 2004-03-29
先做个记号,以后会用到的。
离线lub530
只看该作者 10楼 发表于: 2004-04-05
资料真好,我有一台健伍的机器,原以为有问题,朋友看了说机器没问题,可能设置错了,但不知如何恢复,几乎搁置了一年多,刚才看到帖子,按其程序一试,哇!一秒钟搞惦,机器全部正常,一年的心病好了.在此再一次向bg3rj和bd6as两位老师表示感谢!
离线文竹
只看该作者 11楼 发表于: 2004-04-14
非常不错         !
离线BG4WOW
只看该作者 12楼 发表于: 2004-05-15
是啊,怎么没有tk-378的呢?
离线BG6TSM
只看该作者 13楼 发表于: 2004-05-28
378很简单,坛子上以前介绍过
离线xjhjlwsh
只看该作者 14楼 发表于: 2004-05-31
哈哈哈哈啊哈哈哈哈哈哈哈好好好,丁个位置,以后再看
离线小嘟嘟嘴
只看该作者 15楼 发表于: 2004-07-16
3rj有没有830h的复位方法啊
离线bd4icm
只看该作者 16楼 发表于: 2004-07-16
作个记号。。。。。。。。。。。。。。。。。。。。。。。
离线BD3RJ
只看该作者 17楼 发表于: 2004-07-16
[quote=小嘟嘟嘴]3rj有没有830h的复位方法啊[/quote]
写频时4eq没教你?
离线BD4EQ
只看该作者 18楼 发表于: 2004-07-17
写频时4eq没教你?
可笑,真是可笑
离线BG4IJL
只看该作者 19楼 发表于: 2004-08-09
是啊,怎么没有tk-378的呢?
按住lamp和ta键打开电源,屏幕显示fesf,按low时显示频段设置代码 x ,按ptt键后全机复位——初始化。
