  • 4292阅读
  • 3回复
求IC-2320资料 [复制链接]
离线bg9ep
只看楼主 倒序阅读 0楼 发表于: 2004-02-03
哪位老大手头有IC-2320的线路图或是操作说明,急需!多谢!
离线bg9ep
只看该作者 1楼 发表于: 2004-02-03
那位E文优秀的同志帮着翻译一下,多谢了~!~!
modifications for the icom ic-2320
19-01-2002 extended rx/tx english language
19-01-2002 add a comment
extended rx/tx
author: marcelo - zz2mwl - yoda2@zipmail.com.br.modification.net
hello radio partner's,
here i expose what got working in the ic2320.
open the radio and remove the front
in her meets the logical plate and it is in her that we will work
remove the diodes marked as d9 and soon below him you will see 3 small diodes, remove only the diode of center marked with "x", doesn't remove other diodes, because in spite of him to be very similar at the ic229 doesn't forget that this is dual
with this you will have an opening of:
rx: 118-174 vhf
tx: 140-150 vhf
rx: 300-399 uhf
rx: 430-440 uhf
tx: 430-440 uhf
rx: 800-950 uhf
is not necessary reset the radio!!!
_________________________________________________________
  r5   r4                               |
          r1                           |
        r2 .   .
          d1   d2
        |   -d3-
        |   -d4-
  ic4   |   -d5-
-----------+   -d6-
          -d7-   .   .. _ _
              d8   d9 _ _
          o   ..   .
          c7       ?x?
  x1                                 |
________________________________________________________|
so long, 73 from brazil
marcelo medrado
zz2mwl
this modification has been read 1977 times.
top of page
add a comment
have you any tips, trick or modifications you can't find here, please send a mail to me.
can't you find a modification, then don't e-mail me please. all mododification that i have, is listed on this site.!
have you problem with www.mods.dk then you can visit the support page.
start page
千万别用翻译软件翻译!
离线bd2rap
只看该作者 2楼 发表于: 2006-11-23
IC-2320 简易操作说明
离线新民bg2qcq
只看该作者 3楼 发表于: 2009-02-13
同求2320资料万分感谢bg2qcq@163.com
