  • 6022阅读
  • 5回复
我有一台tm-733,可不知道怎样操作! [复制链接]
离线BG4WBI
只看楼主 倒序阅读 0楼 发表于: 2002-08-07
这台机器好象功能特多,不知道怎样使用,只能进行简单的操作,不知有那位高手知道,帮帮我吧。:confused:
离线BD4AAF
只看该作者 1楼 发表于: 2002-08-07
kenwood tm-733a quick reference guide by brad killebrew n5ljv
[#]               press a number, not the pound sign.
[key]             press and release [key]
[key1]+[key2]       press and hold [key1] down, then press [key2]
[key1],[key2]       press [key1] momentarily, then press [key2]
[key]+[pwr]         with power off, press and hold [key] then hit [pwr]
[key1]+[key2]+[pwr]   you get the idea.
[f] (1s)           press and hold [f] for one second. "f" then blinks.
[key] (1s)         press and hold [key] for one seond.
[f],[key] (1s)       press [f] momentarily, then press [key] for one sec.
the following entries are listed in the order as they appear in the manual.
receive audio switching           [f] (1s) [cont sel]
automatic squelch               [mhz] + [pwr]
s-meter squelch                 [f] (1s), [s.qsl]
squelch hang time               [f]+[dim]
rd output squelch control           [tone]+[pwr]
vhf+vhf operation               [f],[cont sel]
uhf+uhf operation               [f],[cont sel]
transmit band lock               [f],[band sel]
blanking a band display           [f] (1s), [band sel]
vfo tuning limits               [f]+[c.in],(l.frq)[mr],(u.frq)[mr]
am/fm mode                     [mhz] (1s)
frequency step size               [vfo],[f],[step]
1 mhz/10 mhz tuning toggle         [vfo],[f]+[mhz]
power output                   [low]
time-out timer                 [f] (1s),[tot]
writing memory (simplex, duplex)     [f],(freq),[mr]
writing memory (odd split)         (rx frq),[f],[mr] (1s),(tx frq)[mr]
memory to vfo transfer             [f],[vfo]
erasing memory channels           [mr],[f]+[mr]
recalling memory call channel       [call]
changing call channel (simplex,duplex) [f],[c.in]
changing call channel (odd split)     (rx fr),[f],[c.in] (1s),(tx fr)[call]
channel display function           [rev]+[prw]
initialize vfo one band           [vfo]+[band sel]+[pwr]
initialize vfo both bands           [vfo]+[pwr]
full reset (minus pm)             [mr]+[pwr],[f],[mr]
full reset (plus pm)             [mr]+[pwr],[mr]
storing programmable memory         [f],[pm],[#]
recalling programmable memory       [pm],[#]
erasing programmable memory         [f]+[pm],[#],[mr]
cancelling automatic offet         [vfo]+[rev]+[pwr]
automatic simplex checker           [rev] (1s)
selecting a ctcss tone frequency     [f] (1s),[t.sel],[up]/[down]
dtmf confirmation tones           [ptt]+[dwn]+[pwr]
storing dtmf in automatic dialer     [f]+[call]+[pwr],{#'s},[pf],[#]
recalling stored dtmf numbers       [f]+[call]+[pwr],[mr],[#]
transmitting stored dtmf numbers     [ptt]+[pf],[#]
scan resume togle (co, to)         [f] (1s),[vfo]
memory scan                   [mr] (1s)
locking out memory channels         [mr],[f] (1s),[mr]
band scan                     [vfo] (1s)
programmable band scan             [f]+[vfo],(l.frq),[mr],(u.frq),[mr]
confirming programmable limits       [f]+[vfo],(l.shown),[mr](u.shown)
call/vfo scan                   [vfo],[call] (1s)
call/memory scan                 [mr],[call] (1s)
programmable memory scan           [pm]+[pwr],[pm] (1s)
automatic band change (a.b.c.)       [f],[a.b.c.]
advnaced intercept point (aip)       [f]+[a.b.c.]
mute                         [mute]
tranceiver lock                 [f],[mhz]
all lock                     [f],[mhz],[pwr],[f]+[pwr]
automatic power off (apo)           [f] (1s),[mhz]
beep loudness                   [f] (1s),[beep]
frequency readout by beeps         [f]+[tone]+[pwr],[pf]
display dimmer                 [f],[dim]
auto dimmer change               [f]+[low]+[pwr]
display domonstration mode         [call]+[pwr]
remote control mode               [f]+[cont sel]
ctcss                       [tone],togle till "ct" appears
automatic tone frequency id         [tone] (1s)
dual tone squelch system (dtss)       [f],[dtss]
dual tone squelch system (tone select) [f] (1s),[c.sel],[#],[shift],etc.
tone alert                     [f],[t.alt]
tone alert - change tone           [f]+[shift]+[pwr]
packet baud rate togle             [f]+[step]
离线BD4AAF
只看该作者 2楼 发表于: 2002-08-07
the following entries are in alphabetical order.
automatic offet (cancelling)         [vfo]+[rev]+[pwr]
call channel changing (odd split)     (rx fr),[f],[c.in] (1s),(tx fr)[call]
call channel changing (simplex,duplex) [f],[c.in]
call channel recalling             [call]
ctcss tone frequency (selecting)     [f] (1s),[t.sel],[up]/[down]
dimmer (auto change)             [f]+[low]+[pwr]
dimmer (display)                 [f],[dim]
dtmf in automatic dialer (storing)     [f]+[call]+[pwr],{#'s},[pf],[#]
dtmf numbers (recalling stored)       [f]+[call]+[pwr],[mr],[#]
dtmf numbers (transmitting stored)     [ptt]+[pf],[#]
initialize full reset (minus pm)     [mr]+[pwr],[f],[mr]
initialize full reset (plus pm)       [mr]+[pwr],[mr]
lock (all)                     [f],[mhz],[pwr],[f]+[pwr]
lock (tranceiver)               [f],[mhz]
lock (transmit band)             [f],[band sel]
memory channels (locking out)       [mr],[f] (1s),[mr]
memory erasing channels           [mr],[f]+[mr]
memory recalling call channel       [call]
memory writing (odd split)         (rx frq),[f],[mr] (1s),(tx frq)[mr]
memory writing (simplex, duplex)     [f],(freq),[mr]
mute                         [mute]
power output                   [low]
programmable limits (confirming)     [f]+[vfo],(l.shown),[mr](u.shown)
programmable memory (erasing)       [f]+[pm],[#],[mr]
programmable memory (recalling)       [pm],[#]
programmable memory (storing)       [f],[pm],[#]
scan (band scan)                 [vfo] (1s)
scan (call/memory)               [mr],[call] (1s)
scan (call/vfo)                 [vfo],[call] (1s)
scan (programmable band scan)       [f]+[vfo],(l.frq),[mr],(u.frq),[mr]
scan (programmable memory)         [pm]+[pwr],[pm] (1s)
scan memory                   [mr] (1s)
squelch (automatic)               [mhz] + [pwr]
squelch (rd output control)         [tone]+[pwr]
squelch (s-meter)               [f] (1s), [s.qsl]
离线syslww
只看该作者 3楼 发表于: 2002-08-09
Re: 我有一台tm-733,可不知道怎样操作!
原作者 bg4wbi
请问你的tm-733想出售吗?
离线BG4WBI
只看该作者 4楼 发表于: 2002-08-10
Re: Re: 我有一台tm-733,可不知道怎样操作!
原作者 syslww
请问你的tm-733想出售吗?
我用呀,它各方面都不错,就是功能太多!
离线syslww
只看该作者 5楼 发表于: 2002-08-10
原作者 bg4wbi
我用呀,它各方面都不错,就是功能太多!
我在找这样的机器,很难碰到。要转让的话别忘了通知我;)
