  • 6991阅读
  • 27回复
AO-40 [复制链接]
离线VR2XMT
只看楼主 倒序阅读 0楼 发表于: 2004-01-12
dear all,
any station in by qrv on ao-40 , mode u/s ??
i would like to make schedule with him and make possible qso !!!
my working equipment is :
4 x 12 eleements on 70 cm.
b-b-q dish with 2.4 ghz down-converter from ssb electronics.
kind regards,
charlie
vr2xmt
离线BD4OS
只看该作者 1楼 发表于: 2004-01-12
我一直想玩ao-40,只是设备没法解决,真是遗憾啊!
离线admin
只看该作者 2楼 发表于: 2004-01-28
hello xmt,
i wanna purchase a down-convertor for shf->vhf, i found the hams mostly use s.s.b. and downeast, which is best? the new modal of s.s.b is uek 3000, his mast mounted modal need 460usd, and downeast 2400-144rx only 225usd, double!!! :(
离线VR2XMT
只看该作者 3楼 发表于: 2004-01-28
i would suggest the converter from kuhne electronic
http://www.kuhne-electronic.de/english/oscar40.htm
the performance should be better than uek3000.
i do not have experience with downeast microwave converter, but definitely it is not my choice.
73 charlie
vr2xmt
离线admin
只看该作者 4楼 发表于: 2004-01-28
ok! charlie, many thanks, i will try the mku 24 tm oscar 2, hope meet you in oscar 40 soon. :)
离线BD7CE
只看该作者 5楼 发表于: 2004-01-28
7kw的变频器出不来了吗??? :(
离线BA7NQ
只看该作者 6楼 发表于: 2004-01-28
最初由 bd7ce 发表
7kw的变频器出不来了吗??? :(
等他的出来,中国已经登陆火星了。:d
离线BD3RJ
只看该作者 7楼 发表于: 2004-01-29
最初由 bd4os 发表
有钱就能解决
离线VR2XMT
只看该作者 8楼 发表于: 2004-01-29
ao-40 has some problem, hope the command team can work it out.
pse read this.
http://www.amsat-dl.org/journal/adlj-p3d.htm
good luck,
charlie
vr2xmt
离线BG4REB
只看该作者 9楼 发表于: 2004-01-31
图中的这种变频器那里有卖,多少钱?
这种变频器那里有卖,多少钱?
离线BA7NQ
只看该作者 10楼 发表于: 2004-01-31
上面vr2xmt给出的网站上就可以订购,包含运费,大概280欧元。
离线VR2XMT
只看该作者 11楼 发表于: 2004-02-01
this one is much cheaper. a complete plug n play setup is us$175
http://www.k5gna.com/
if you really want to order, please make sure the ao40 is still alive. now the command team try very hard to recover.
73 charlie
vr2xmt
离线BD4OS
只看该作者 12楼 发表于: 2004-02-01
感觉太阳风暴实在厉害,好多航天器都失效了,从业余卫星,商业卫星,间谍卫星,甚至是火星勇气号都没有躲过。。。
离线BD3RJ
只看该作者 13楼 发表于: 2004-02-01
老高打算放弃吗?
离线BD4OS
只看该作者 14楼 发表于: 2004-02-01
就是要搞也要像vr2xmt建议的那样,等ao-40修好了再说,否则买回来也用不起来啊。。。
离线BA7NQ
只看该作者 15楼 发表于: 2004-02-02
最初由 bd4os 发表
现在ao-40的电压有些问题,看报告还需要很长一段时间去修复。不过,不玩ao-40还有其他可以玩啊!
离线BA1RB
只看该作者 16楼 发表于: 2004-02-02
大佬还要玩什么?
to:bd4os,
我用tnc能正确收到、解调到信号,用beacon命令也能往外发,但输入连接命令如: c ji3zag-2 或 c yb4bx/h 等命令时收发信机不往外发射(静噪已调到适当位置)。不知有什么地方没有设置好。我记得以前用别的tnc时不是这样的。
顺便问一下,现在的tnc是老掉牙的kam,有双端口,设置值时有两个,如beacon 30/60,不知哪个参数是hf,哪个参数是vhf的,谢谢。
离线BD4OS
只看该作者 17楼 发表于: 2004-02-04
beacon指令的格式为:
beacon [every|after] n (n=0-255)
every参数是指n分钟发射一个packet,after参数是指在没有通道有效持续n分钟发射一次packet。
首先键入beacon查看一下现在的状态:
cmd:beacon
beacon   every 1/every 0 (1 min/0 min)
这说明在hf端口每分钟发射一次packet,在vhf端口没有应用信标。
你的问题原因可能出在没有正确分配开机端口,kam在开机的时候会缺省落在vhf端口,这样你的指令就应用在vhf端口,而不是你希望的hf端口,信标正常是因为你在两个端口都应用了信标,所以能够通过beacon发射信标。
解决的方法很简单:
cmd:port hf (需要重启)
这样就会在开机的时候缺省为hf端口。
离线BA1RB
只看该作者 18楼 发表于: 2004-02-04
谢谢4os。
我已经将端口设置成hf了。用的就是port hf,另外默认的参数中还有abaud,默认是1200,我设置成300了,解调正常,信标发射也正常(收发信机on air灯亮)。
但connect命令状态下不发射。 :-(
我看kam的tnc中好像没有电池,重启以后又回复成原样了,不知如何存住设置?谢谢。
离线BD4OS
只看该作者 19楼 发表于: 2004-02-04
abaud参数是指你的tnc跟你的计算机的串口速度,最好设置成1200以上,比如9600,不要设成300,可能有问题。
存不住可能就是内部电池没有电了,这个只能换电池了,不过不排除存储器损坏的可能,我的一台kpc-4就是主存储器坏了,还是先换电池试一下吧。
还有一个呼号命令(mycall),看看你的是否已经设置正确?
