  • 3764阅读
  • 0回复
2004 ARRL RTTY Round-Up Rules [复制链接]
离线BA3CE
只看楼主 倒序阅读 0楼 发表于: 2004-01-02
1. object: amateurs worldwide contact and exchange qso information with other amateurs using digital modes (baudot rtty, ascii, amtor, psk31, and packet--attended operation only) on 80, 40, 20, 15, and 10 meter bands. any station may work any other station.
2. date and contest period: first full weekend of january, but never on january 1. begins 1800 utc saturday, ends 2400 utc sunday (january 3-4, 2004).
2.1. operate no more than 24 hours.
the six hours of off time must be taken in no more than two blocks.
3. entry categories:
3.1. single operator:
3.1.1. low power.
3.1.2. high power.
3.2. multioperator, single transmitter:
3.2.1. power.
3.2.1.1 low power
3.2.1.2. high power
3.2.2. stations are allowed only one transmitted signal at any given time.
3.2.3. includes those single operators that use any form of spotting assistance such as from nets or packet.
3.2.4. includes those that receive assistance with logging or relief operators, etc.
3.2.5. limited to 6 band changes (maximum) in any clock hour.
3.2.6. the clock hour is from zero through 59 minutes.
3.2.7. band changes are defined so that, for example, a change from 20 meters to 15 meters and then back to 20 meters constitutes two band changes.
4. exchange:
4.1. united states: signal report and state.
4.2. canada: signal report and province.
4.3. dx: signal report and consecutive serial number, starting with 001.
5. scoring:
5.1. qso points: count one point for each completed qso.
5.2. multipliers: each us state (except kh6 and kl7) plus the district of columbia (dc), canadian provinces/territories: nb (ve1, 9), ns (ve1), qc (ve2), on (ve3), mb (ve4), sk (ve5), ab (ve6), bc (ve7), nwt (ve8), nf (vo1), lb (vo2), nu (vy), yt (vy1), pei (vy2) and each dxcc country. kh6 and kl7 count only as separate dxcc countries.
5.2.1. count only once (not once per band).
5.2.2. the us and canada do not count as dxcc countries.
6. reporting:
6.1. all entries are must be postmarked or emailed by february 3, 2004.
6.2. entries in electronic format may be submitted to rttyru@arrl.org or submitted on 3.5" diskette to rtty round-up, arrl, 225 main st, newington, ct 06111.
6.3. all logs that are created electronically are required to submit their electronic log file in cabrillo file format. a print out of an electronically generated log is not an acceptable substitute. a hand written log that is later entered into a logging or other electronic program is considered an electronically generated log and must meet electronic file requirements.
6.4. the cabrillo entries include the header and the complete qso list.
6.5. hand-logged entries may be submitted to rtty round-up, arrl, 225 main st, newington, ct 06111.
7. miscellaneous:
7.1. packet radio contacts made through digipeaters or gateways are not permitted.
7.2. all arrl contest rules and forms may be downloaded from the arrl contest web page at: http://www.arrl.org/contests/forms or obtained from the contest branch by sending an sase with 2 units of postage.
7.3. for contest information contact contests@arrl.org or (860) 594-0232
8. awards:
8.1 certificates will be awarded to:
8.1.1. top high power and low power single operator and multioperator scorers in each arrl/rac section.
8.1.2. top high power and low power single operator and multioperator scorers in each dxcc country (other than w/ve).
8.2. plaques, if sponsored, will be awarded to the top scoring low and high power entrant in each category overall, each arrl division, and canada.
8.2.1. unsponsored plaques may be purchased from the arrl.
9. other: see "general rules for all arrl contests" and "general rules for arrl contests on bands below 30 mhz (hf)" november 2001 qst.
recommended hf digital operating frequencies (mhz) north and south america
europe/africa
3.590 rtty dx
3.605 - 3.645
3.580 - 3.620
7.040 rtty dx
7.080 - 7.100
7.035 - 7.045
14.070 - 14.099.5
14.080 - 14.099
21.070 - 21.100
28.050 - 28.150
21.080 - 21.120
recommended novice digital operating frequencies (mhz)
10 meters 28.100-28.150*
suggested simplex packet-radio frequencies
28.102.3
28.104.3
*authorized power output 200-watts maximum for novices / tech plus only in the 10-meter novice sub-band.
