  • 3673阅读
  • 6回复
常用发射三级管资料 [复制链接]
离线bd1hp
只看楼主 正序阅读 0楼 发表于: 2002-07-27
常用发射三级管资料
型号   功率 增益 电压   频率   工作状态     封装   123脚
2n3375   10w   5db   28v   400mhz fm/am/ssb     to-60
2n3553   2,5w 10db 28v   175mhz fm/am       to-39   c b e
2n3632   20w   7db   28v   175mhz fm         to-60
2n3866   5w   10db 28v   400mhz wintransceiver to-39   c b e
2n3924   4w   6db 13,6v 175mhz wintransceiver to-39
2n4427   2w   10db 12v   175mhz wintransceiver to-39
2n5108   1w   5db   24v   1200mhz wintransceiver to-39
2n5109 3,5w   11db 15v   200mhz wintransceiver to-39
2n5421   3w   9db 13,5v 175mhz wintransceiver to-39
2n5913   2w   7db 12,5v 175mhz wintransceiver to-39
2n5943   1w   8db   15v   400mhz fm         to-39
2sc730   0,8w 10db 13,5v 175mhz fm         to-39   c b e
2sc1096 10w  60mhz           fm         to-220
2sc1173 10w  100mhz         fm/am/ssb     to-220
2sc1306 16w  30mhz           fm/am/ssb     to-220 b c e
2sc1307 16w   12db 12v   30mhz   fm/am/ssb     to-220 b c e
2sc1590 5w   10db 12,5v 136-174mhz fm       to-220 b e c
2sc1591 14w 7,5db 12,5v 136-174mhz fm       to-220 b e c
2sc1678 5w   30mhz           wintransceiver to-220 b c e
2sc1728 8w   80mhz           wintransceiver to-202 e b c
2sc1729 14w   10db 13,5v 175mhz   fm         t-31e
2sc1909 10w 14,5db 13,5v 50mhz   fm/am/ssb   to-220 b c e
2sc1944 13w 11,1db 12v   30mhz   wintransceiver to-220 b c e
2sc1945 16w 14,5db 12v   30mhz   fm/am/ssb     to-220 b e c
2sc1946 25w 6,7db 13,5v 175mhz   fm         t-31e
2sc1946a 30w 10db 13,5v 175mhz   fm         t-31e
2sc1947 3w   10db 13,5v 175mhz   fm         to-39   c b e
2sc1957 1,8w 17db   12v 30mhz   wintransceiver to-126 e c b
2sc1966 3w   7,8db 13,5v 470mhz   fm         t-31e
2sc1967 7w   6,7db 13,5v 470mhz   fm         t-31e
2sc1968 14w 3,7db 13,5v 470mhz   fm         t-31e
2sc1968a 14w 5,4db 13,5v 470mhz   fm         t-31e
2sc1969 18w   12db 12v   30mhz   fm/am/ssb   to-220 b c e
2sc1970 1,5w   10db 13,5v 175mhz   wintransceiver to-220 b e c
2sc1971 7w   10db 13,5v 175mhz   wintransceiver to-220 b e c
2sc1972 14w   10db 13,5v 175mhz   wintransceiver to-220 b e c
2sc1973 1w           50mhz   wintransceiver to-92l b c e
2sc1974 13w   10db 13,5v 30mhz   wintransceiver to-220 b c e
2sc1975 4w   10db 13,5v 30mhz   wintransceiver to-220 b c e
2sc2028 1,8w         30mhz   wintransceiver to-126 e c b
2sc2029   6w         30mhz   wintransceiver to-220 b c e
2sc2036a 1,4w               wintransceiver to-202 b c e
2sc2050 10w   12db 13,5v 30mhz   fm/am/ssb     to-220 b c e
2sc2053 0,2w 15,7db 12v 175mhz   fm/am       to-92l b c e
2sc2055 0,25w 15,3db 12v 175mhz   fm/am       to-92l b c e
2sc2056 1,5w   9db   12v 175mhz   fm         to-39   c b e
2sc2075   4w     13,5v 27mhz   wintransceiver to-220 b c e
2sc2078   4w   13db 12v 100mhz   fm/am       to-220 b c e
2sc2086   0,45w 13db 12v 175mhz   fm/am       to-92l b c e
2sc2092   4w   13db 12v 100mhz   fm/am/ssb     to-220 b c e
2sc2094   15w 8,8db 13,5v 175mhz fm/am/ssb     t-31e
2sc2166   6w 13,8db 12v   30mhz   fm/am/ssb     to-220 b c e
2sc2207   16w               wintransceiver to-220 b c e
2sc2237   6w 13,8db 13,5v 175mhz fm         t-31e
2sc2312   18,5w         27mhz   fm/am/ssb     to-220 b c e
2sc2314   1,8w 17db 12v   180mhz fm/am       to-126 e c b
2sc2509   13w   14db     30mhz   wintransceiver to-220 b c e
2sc2527   60w               wintransceiver to-220
2sc2538   0,6w 10db 12v   175mhz fm/am       to-92l b c e
2sc2539   14w 14,5db 13,5v 175mhz fm         t-31e
2sc2660   30w         30mhz   wintransceiver to-220
2sc2695   23w 1,9db 13,5v 520mhz fm         t-31e
2sc3001   6w 13db   7,2v 175mhz fm         t-31e
2sc3017   1w 11db   13,5v 175mhz fm         to-39   c b e
2sc3018   3w 13db   7,2v 175mhz fm         t-31e
2sc3020   3w 10db   12,5v 520mhz fm         t-31e
2sc3021   7w 7,7db 12,5v 520mhz fm         t-31e
2sc3022   18w 4,8db 12,5v 520mhz fm         t-31e
2sc3103   2,8w 6,7db 7,2v 520mhz fm         t-31e
2sc3104   6w 4,8db 7,2v 520mhz fm         t-31e
2sc3133   13w 14db   12v 1,5-30mhz fm/am/ssb   to-220   b e c
2sc3297   15w         100mhz wintransceiver to-220
2sc3299   20w               wintransceiver to-220
2sc3668   1w               100mhz wintransceiver
2sc3807   15w         260mhz wintransceiver to-126
2sc4137   4w           400mhz wintransceiver to-126
2sc4693                   fm/am       to-92l   b c e
ktc1006   1w           100mhz fm/am       to-92l   e c b
ktc1969   16w 12db   12v 100mhz fm/am       to-220   b c e
ktc2078   4w 11db   12v 100mhz fm/am       to-220   b c e
mrf161   5w 13,5db 12,5v 225-500mhz fm/am     to-220   b e c
mrf162   15w 13,5db 12,5v 225-500mhz fm/am     to-220   b e c
mrf163   25w 12db   12,5v 225-500mhz fm/am     to-220   b e c
mrf237   4w 12db   18v   175mhz wintransceiver to-39
mrf260   5w 10db   12,5v 136-174mhz fm       to-220   b e c
mrf261   10w 5,2db 12,5v 136-174mhz fm       to-220   b e c
mrf262   14w 7,5db 12,5v 136-174mhz fm       to-220   b e c
mrf264   30w 5,2db 12,5v 136-174mhz wintransceiver to-220 b e c
mrf340   8w 13db   28v 70mhz     wintransceiver to-220 b e c
mrf342   24w 11db   28v 70mhz wintransceiver     to-220 b e c
mrf344   60w 6db   28v 70mhz wintransceiver     to-220
mrf454   80w 12db   12,5v 1,5-30mhz fm/am/ssb
mrf455   60w 13db   12,5v 1,5-30mhz fm/am/ssb
mrf475   12w 10db   13,5v 1,5-30mhz fm/am/ssb     to-220 b c e
mrf476   3w 15db   13,5v 1,5-30mhz fm/am/ssb     to-220 b c e
mrf477   40w 15db   13,5v 1,5-30mhz fm/am/ssb     to-220 b e c
mrf479   15w 10db   13,5v 1,5-30mhz fm/am/ssb     to-220
mrf485   15w 10db   28v   1,5-30mhz wintransceiver to-220
mrf486   40w 15db   28v   1,5-30mhz wintransceiver to-220
mrf496   40w 15db   13,5v 1,5-30mhz wintransceiver to-220
mrf497   60w 10db   13,5v 27-50mhz   wintransceiver to-220 b e c
mrf517 0,75w 10db   20v   1000mhz   wintransceiver to-39
mrf607 1,75w 11,5db 16v   175mhz   wintransceiver to-39
mrf660   7w 5,4db 12,5v 400-512mhz wintransceiver to-220
ms1226   30w 18db   28v   30mhz fm/am/ssb
ms1227   20w 15db   12,5v 30mhz fm/am/ssb
离线bg1iwk
只看该作者 6楼 发表于: 2010-06-17
顶起来。。。。。。
离线BG3FB
只看该作者 5楼 发表于: 2010-06-17
感谢楼主,收藏中。。。。。。。。
离线费力刻丝
只看该作者 4楼 发表于: 2010-06-17
顶起来~~~
离线bd1hp
只看该作者 3楼 发表于: 2002-07-30
报欠!
目前只找到这些,以后再找找。
离线aaaa
只看该作者 2楼 发表于: 2002-07-29
有除三菱以外的原装的data sheet吗?俺需要,付费也中。
离线bd8ai
只看该作者 1楼 发表于: 2002-07-29
好!
快捷、方便!
谢谢了!
