  • 6704阅读
  • 17回复
IC-V100全部资料 [复制链接]
离线BD4EQ
只看楼主 倒序阅读 0楼 发表于: 2003-12-08
最近出现一批ic-v100的机器。看来看去觉得是个好机器。
我觉得好的理由:
1、icom业务机所特有的优异的接收性能,特别是抗干扰性能
2、带有ctcss
3、功率巨大,标称50w,实际可以出90w,甚至100w以上
特把我知道的统统贴出来
离线BD4EQ
只看该作者 1楼 发表于: 2003-12-08
ic-v100 - mobile vhf radio
quick specs
mobile vhf transceiver
rx/tx: 136-155 mhz or 146-174 mhz (two versions)
output power: 50 w
modes: fm
receiver sensitivity: 0.35 礦 (fm, 12 db sinad)
ctcss standard
2-tone optional (see detailed specifications)
general
frequency coverage:
136-155 mhz (low-band version)
146-174 mhz (high-band version)
mode: fm (16k0f3e)
number of memory channels: 16 (transmit, receive and ctcss frequencies are programmable)
channel spacing: 25 khz
antenna impedance: 50 ohms (unbalanced)
power supply requirement: 13.8 v dc 15% (negative ground)
current drain (at 13.8 v dc):
transmit: 12.0 a
receive (squelched): 500 ma
receive (max. audio power): 1.2 a
usable temperature range: -30癈 ~ +60癈; -22癋 ~ +140癋
frequency stability: 0.0005% (-30癈 ~ +60癈)
dimensions (projections not included):
both remote controller and main body: 170(w) x 50(h) x 260(d) mm; 6.7(w) x 2.0(h) x 10.2(d) in
remote controller only: 170(w) x 50(h) x 40(d) mm; 6.7(w) x 2.0(h) x 1.6(d) in
weight:
both remote controller and main body: 2.6 kg; 5.7 lb
remote controller only: 380 g; 13.4 oz
transmitter
output power: 50 w
max. frequency deviation: 5.0 khz
spurious emissions: -70 db
harmonic emissions: -70 db
fm hum and noise: -40 db
max. frequency separation:
low-band version: 8 mhz
high-band version: 26 mhz
receiver
modulation acceptance: 7 khz
sensitivity (for 12 db sinad): 0.35 礦
squelch sensitivity (threshold): 0.3 礦
adjacent channel selectivity: -70 db
intermodulation rejection: -70 db
spurious and image rejection: -80 db
audio output power: 5 w with a 4 ohms load.
ic-v100 options
ck-12 remote cable kit: allows you 6 m (19.7 ft) separate installation of your ic-v100 front panel and main body in the vehicle.
hg-10 microphone hanger box: provides monitoring when operating with the tone squelch function even if the microphone is left hanging on the microphone hanger.
hm-37 dtmf microphone: heavy-duty hand microphone with dtmf keyboard.
hm-38 hand microphone: heavy-duty hand microphone.
ic-ps30 ac power supply: allows you to use the ic-v100 through ac power source. equipped with a dc power cable and 3 extra dc output connectors. output voltage: 13.8 v; max. current drain: 25 a
sp-5 external speaker: can be easily installed in any part of your vehicle. the same type as supplied with the ic-v100. input impedance: 4 ohms. max. input power: 5 w
sp-10 external speaker: compact and easy-to-install. input impedance: 4 ohms. max. input power: 5 w
ut-26 2-tone decoder unit: a 2-tone system receives only specific stations and provides a "personalized" squelch.
ut-27 2805 hz tone decoder unit: allows you to receive only specific stations using 2805 hz tones.
离线BD4EQ
只看该作者 2楼 发表于: 2003-12-08
离线BD4EQ
只看该作者 3楼 发表于: 2003-12-08
电路图,里面缺少cpu板的电路图
http://www.cqham.ru/ftp/sch_ic-v100.zip
离线BD4EQ
只看该作者 4楼 发表于: 2003-12-08
该机器不能通过面板上的按键输入接收发射参数,必须通过专用的置频器输入。
对于业务机而言,是非常正常的
置频器图
离线BD4EQ
只看该作者 5楼 发表于: 2003-12-08
置频器的10针接口与v100的连接处
注意,这是机器的面板拆下来的图,里面的标注可以看清吧
离线BD4EQ
只看该作者 6楼 发表于: 2003-12-08
由于置频器的使用说明较大,等我整理后发出
先说明如何进入置频模式:
按下func,再按 1, 5, 9, 3, 5,7,松开func。
下面的方法,大家可以先试一试,风险自负:)
离线BG1BFZ
只看该作者 7楼 发表于: 2003-12-10
谢谢提供!
我也有这样的一台机器,苦于无法写频!!
离线BD4EQ
只看该作者 8楼 发表于: 2003-12-10
结束编程状态,回到信道操作模式
两种方法:
1、func + clr
2、关闭电台,再开机
离线bg2th
只看该作者 9楼 发表于: 2003-12-11
谢谢bd4eq提供的置频方法。
离线BD7IS
只看该作者 10楼 发表于: 2003-12-14
那么u400的频率是多小啊,有高低分吗
离线bg2tr
只看该作者 11楼 发表于: 2006-06-14
up............
离线bg7ipy
只看该作者 12楼 发表于: 2006-06-27
ding ding ding ding ding ding
离线bd7oi
只看该作者 13楼 发表于: 2006-08-19
学习了~~
离线新民bg2qcq
只看该作者 14楼 发表于: 2007-06-23
学习了由于置频器的使用说明较大,等我整理后发出
能发一份说明书到我邮箱里吗先谢谢您了
离线BG4BSE
只看该作者 15楼 发表于: 2007-12-11
eq 03年发的贴,顶一把!
离线wangchun
只看该作者 16楼 发表于: 2008-04-01
捡来一台,研究中。
离线BD5FNA
只看该作者 17楼 发表于: 2008-04-03
我记得也有二台u400.但一直没有时间搞.
