  • 7833阅读
  • 20回复
急求FT-100扩频资料 [复制链接]
离线bg2pv
只看楼主 倒序阅读 0楼 发表于: 2003-11-26
哪位能提供ft-1oo的扩频资料,现在只能在业余段发射。谢了!!!
离线BG2VO
只看该作者 1楼 发表于: 2003-11-27
去看www.mods.dk
离线bg7ipo
只看该作者 2楼 发表于: 2003-11-28
老朋友请看!这是www.mods.dk上的原文
be careful not to transmit outside the amateur bands.
rx: 30khz-824mhz, 849mhz-859mhz, 894mhz-961mhz.
tx: 1.8mhz-30mhz, 50mhz-54mhz, 140mhz-174mhz, 420mhz-470mhz.
remove front panel from radio and open the rear cover from the front panel unit. be careful, a cable connects them together.
locate and remove r6035 (1) and r6036 (2) on the display board.
note: the factory removed r6035 on my radio so i only had to remove r6036. you should end up like the picture below.
  _____________________________________________________
/   _ =
|   _ = ! ! ! !   ! ! ! !
|   = 1 2 3 4
back of front panel. top left corner.remove jumpers 1 & 2, leave 3 & 4.
reassemble and install the front panel on the radio.
press and hold [dwn] and [step] keys; while holding them in, press and hold in the [pwr] switch for 1/2 second to turn the tranceiver on. now let go of all keys.
the display will read "r on" for a 1/2 second or less (it may be so quick that you don't see it but continue with the mod).
set the dial frequency to 375.72727mhz and turn the power off.
note: you may need to use lsb, usb, or cw to get the last digit.
the display will read "hf on" for a 1/2 second or less (it may be so quick that you don't see it but continue with the mod).
set the dial frequency to 549.61163mhz and turn the power off.
the display will read "vu on" for a 1/2 secondor less (it may be so quick that you don't see it but continue with the mod).
the modification is complete. turn the radio off and back on tocontinue.
离线bg5qao
只看该作者 3楼 发表于: 2007-04-03
同求ft-100扩频资料
离线bd7oi
只看该作者 4楼 发表于: 2007-04-03
还求什么?上面的图就是扩频资料了
离线bg5qao
只看该作者 5楼 发表于: 2007-04-03
还是开不了呜呜。。。。。。。。。
离线bd7oi
只看该作者 6楼 发表于: 2007-04-03
焊下一个二极管能使ft-100d全段发射
离线bg5qao
只看该作者 7楼 发表于: 2007-04-04
bd7oi 你好我怎么找不到二级管只有电阻r6035 r6036 r6037 r6038
r6035,r6036机器到我手上就已经没有了
ft100开频(翻译版)
1、将机器前面板从主机上拆下,打开后板盖,露出电路板。
2、剪断 r6035和r6036两个电阻(注: 有些机器在出厂时已经拆下了r6035,仅仅剪断r6036即可)。这两个小东西应该是站着的!
3、在电路板的左上角,找到跳线1、2、3、4,断开1、2,留着3、4
4、将后盖上好,拧紧螺丝呦。之后安好话筒,将面板归原位。
5、开接收频啦:
按住[dwn ]和[step] 键同时按住power电源开关1/2 秒后松开所有按键。这时显示屏会快速显示一个“r on”(很快啦)。把dial刻度盘频率设置成375.72727mhz,转换模式为lsb、usb或cw(随便哪个),调准频率后转换模式为fm方式,关机!!!
6、开hf频啦:
按住[dwn ]和[step] 键同时按住power电源开关1/2 秒后松开所有按键。这时显示屏会快速显示一个“hf on”(很快啦)。把dial刻度盘频率设置成549.61163mhz,转换模式为cw或ssb(随便哪个),调准频率后转换模式为fm方式,关机!!!
7、开u/v段啦:
按住[dwn ]和[step] 键同时按住power电源开关1/2 秒后松开所有按键。这时显示屏会快速显示一个“vu on”(很快啦)。
8、关机,再开,哈哈,全段收发啦!!
请不要在业余频段以外hjb发射
rx: 30khz-824mhz,849mhz-859mhz,894mhz-961mhz
tx: 1.8mhz-30mhz,50mhz-54mhz,140mhz-174mhz,420mhz-470mhz
离线随风
只看该作者 8楼 发表于: 2007-04-05
这个机器听说不错,什么时候有机会搞个来玩玩。
离线bd7oi
只看该作者 9楼 发表于: 2007-04-05
能不能告诉我,你想在哪个频率发射呢?
离线BD7JAC
只看该作者 10楼 发表于: 2007-04-05
我也想不出楼主还要在哪里发射,八重洲的机器u段最低只能到420
离线bg5qao
只看该作者 11楼 发表于: 2007-04-07
我的意思是我用上叙的方法没办法扩到140mhz-174mhz,420mhz-470mhz只能在144-146,430-440。呵呵让您误解了
离线bg5qao
只看该作者 12楼 发表于: 2007-04-10
为什么我的机器只能在144-146,430-440
离线bg5qao
只看该作者 13楼 发表于: 2007-09-24
诚心请教啊,救急啊
离线bg5qao
只看该作者 14楼 发表于: 2007-09-24
显示屏没有什么   r on     hfon   vuon
vu段只能在144-146,430-440发射
我是要把vu段扩到140mhz-174mhz,420mhz-470mhz
请赐教
离线bg5qao
只看该作者 15楼 发表于: 2007-09-24
离线勇敢的心
只看该作者 16楼 发表于: 2011-06-09
留记号一个。
离线无电线
只看该作者 17楼 发表于: 2016-08-16
回去试一试
新疆乌鲁木齐-BDOah
金刚经偈颂
若以色见我  以音声求我
是人行邪道  不能见如来
离线bg7fpz
只看该作者 18楼 发表于: 2020-01-16
支持,顶!
离线bg7fpz
只看该作者 19楼 发表于: 2020-01-16
支持,顶!
