  • 4969阅读
  • 10回复
Th-f7繁体中文手册 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2002-07-05
离线DFG
只看该作者 1楼 发表于: 2002-07-05
中文手册打开密码只有在“大王電器廠股份有限公司”买的机器才可以得到密码:( :( :(
f7用的软件我三天了就一直没下来:mad: :mad: :mad:
离线BD3RJ
只看该作者 2楼 发表于: 2002-07-07
我已经有f7写频软件,因要用她挣钱,暂时不提供。
离线BG6AGB
只看该作者 3楼 发表于: 2002-07-08
谁有空,找个破pdf密码的软件算他几天,就不用花钱去买机器得密码了撒。
离线BD3RJ
只看该作者 4楼 发表于: 2002-07-08
我有破pdf密码工具,你试试吧!ba4in已经翻译了大部分,需要的朋友可以找他要.
离线BD4AAF
只看该作者 5楼 发表于: 2002-07-10
kenwood memory control program
mcp-f6/f7 version 0.10 beta
introduction
- this program is for editing "memory channels" and various settings on
the kenwood amateur radio th-f6a/f7e.
- this program runs on windows 95/98/me/2000 (*1).
- about 1.2m bytes of free space on the hard disk is needed to install this
program.
- at least 5mb of memory is required to run this program.
- to write to or read from the th-f6a/f7ea memory, a separate connector
cable pg-4p (option) is required.
- before connecting the th-f6a/f7e to a pc, first turn the
th-f6a/f7e power off.
- the latest version of this program can be obtained over the internet
from http://www.kenwood.net/.
- permission is required if this program is to be redistributed on
individuals' web site.
- any user may not be engaged in the following acts:
  to revise, change, edit, merge, de-compile or reverse engineer the
  software.
- the quality and performance of the products shall not warrant the
applicability to the purpose of any user. kenwood shall not assume
any liability for the defect, or warrant anything other than expressly
provided in the document. the selection and introduction of the products
as well as the results therefrom shall be upon the liability of the users.
- kenwood shall own all copyrights and other intellectual properties
for the products and all manuals and documents attached to the products.
user shall be hereby allowed to use, not sell, the software packed in
the products by kenwood. while the disc in which the software is stored
is possessed by the user, the ownership for the software itself shall be
reserved for kenwood.
installation
1. copy mfx010.exe to the directory in which you want to install the program.
2. execute mfx010.exe. the following programs are automatically created:
  mcp_f6f7.exe
3. start the program by executing mcp_f6f7.exe
uninstallation
1. delete the entire directory to which the following files have been copied:
  mcp_f6f7.exe
2. you can also use short-cut commands to delete the directory if it was made
  using short-cut commands.
3. delete "software" "kenwood" from "hkey_current_user" by regedit command.
  however, delete only "mcp-fx" under "kenwood" when other mcps are
  installed.
  carefully carry out registry operations taking care not to delete other
  registry data. if you are unsure of registry operations, no problems will
  occur if you do not delete files.
(*1) windows are either registered trademarks or trademarks of microsoft
  corporation in the united states and/or other countries.
caution
-a help file is not available with this beta version.
-if you choose wrong country version when starting this program at the first
time, "read" data from the radio corrects the version.
ver. 0.00 first beta release
ver. 0.10 fixes dell laptop, window 2000/me capability
:p
附件: mfx010.zip (0 K) 下载次数:309
离线DFG
只看该作者 6楼 发表于: 2002-07-10
thx!!!!!!!!!!
离线BD4AAF
只看该作者 7楼 发表于: 2002-07-10
f6/f7英文版手册
附件: th-f6a_and_th-f7a_manual.pdf (0 K) 下载次数:238
离线BD4AAF
只看该作者 8楼 发表于: 2002-07-10
f7宣传彩页
附件: th-f7e_sales_brochure.pdf (0 K) 下载次数:185
离线DFG
只看该作者 9楼 发表于: 2002-07-24
中文繁体版的还是没有人知道密码吗?
离线BG2RST
只看该作者 10楼 发表于: 2008-08-17
好东西,收藏了!谢谢3rj
