  • 6256阅读
  • 23回复
SSB 75 Meter Transceiver [复制链接]
离线bg8am
只看楼主 倒序阅读 0楼 发表于: 2003-07-11
图传不上来,大家自己看了
http://www.qrp.pops.net/idaho.htm
the 75 meter qrp ssb transceiver theory of operation     6-30-03
in general, the transceiver switches the 4-element 1500 ohm xtal bpf ends between the inputs and outputs of the two sa602s to reverse the signal flow for r/t operation. since no if amplifier is used in the design, 20 db of additional receiver gain is produced by the 2n2222 receiver rf amplifier, while automatic gain control (agc) is produced by the peak dc swing of the lm386 output passed through a rectifier and filtered by a capacitor and fed to the gate of a bs170 enhancement mode fet acting as a variable resistor across the input of the lm386.
both receive and transmit bandpass filtering are done by the same half-pi bpf. the diode pair in the mic circuit reduce the "chirp" that occurs during the r/t transition. additional bs170s could easily be used to mute both the mic and audio instead of the r/t switch directly. these bs170s would be controlled by the +r and +t voltages on their gates while their drains would be tied to 1) the mic circuit between the two coupling capacitors and 2) pin number 1 (audio in) of the lm386 (bs170 sources to ground). additional power output (perhaps 60 mw) could also be attained by connecting the rf output transistor's collector choke (10 uh) to a 9 v supply instead of the 5 v. additional biasing current might also be required for this change.
the r/t switches are from radio shack and are of the slider-type with silver plated brass connectors. i removed the detent springs from two of them and weakened the third. i then drilled holes through the switches' handles to connect them with a piece of tempered copper-plated steel wire. the switches are marked on their sides with the word "alpha." low current-drain type dpdt relays (10 to 12 ma @ 12 v) could also be used in place of the switches. i used switches to reduce transmit current, and they work very smoothly.
the intent of this design was to minimize the parts count (about 85) and size, reduce power consumption (17 ma receive and 40 ma transmit), run on a 9 v battery, be self contained (except for antenna), have good rejection of unwanted signals, have good sensitivity and selectivity, and have automatic gain control (agc)--with enough parts left over to build another rig. finally, the variable tuning capacitor of the local oscillator (lo) could be replaced with a varactor diode circuit.
the homebrewer should be able to build this transceiver in a "week of evenings," if all of the parts are available. should a commercial circuit board version be developed, the circuit could easily be completed in one evening! good luck with your project.
receive: 50 ohm antenna feeds half-pi bandpass filter (bpf, element q=5) which feeds receive-transmit (r/t) switch which feeds 2n2222 receive rf amplifier which feeds 1st sa602 which feeds r/t switch which feeds 4-element 1500 ohm xtal bpf which feeds r/t switch which feeds 2nd sa602 which feeds lm386 which feeds 1) diode which feeds capacitor which feeds gate of bs170 which produces audio automatic gain control (agc) and 2) speaker attenuator which feeds speaker.
transmit: mic feeds 2nd sa602 which feeds r/t switch which feeds 4-element 1500 ohm xtal bpf which feeds r/t switch which feeds 1st sa602 which feeds lc bpf (q=15) which feeds emitter follower (2n2222) which feeds final (2n2222) which feeds half-pi bpf (element q=5) which feeds 50 ohm antenna.
离线bg8am
只看该作者 1楼 发表于: 2003-07-11
离线bg2abr
只看该作者 2楼 发表于: 2003-07-12
漂亮,我们就要这样的工艺,一定会做出来
离线bg8am
只看该作者 3楼 发表于: 2003-07-13
好像是面包板做的,看打的孔就知道
离线bg2ey
只看该作者 4楼 发表于: 2003-07-13
工艺的确不错,佩服!
离线bg8am
只看该作者 5楼 发表于: 2003-07-13
离线bg8am
只看该作者 6楼 发表于: 2003-07-13
图2
离线bg2ey
只看该作者 7楼 发表于: 2003-07-13
感谢您的贴图,这样看起来更方便!
只看该作者 8楼 发表于: 2003-07-13
这样的机器我喜欢,请问要怎样才能够得到?
只看该作者 9楼 发表于: 2003-07-13
可不可以把他翻译出来啊?我的英语还没有过四级呢!
离线bg6iat
只看该作者 10楼 发表于: 2003-08-17
离线yujing
只看该作者 11楼 发表于: 2003-08-17
我觉得用开关更简单可靠一些,diy的精髓就在于这里
离线BD6CR
只看该作者 12楼 发表于: 2003-10-14
顶一下这个设计。
离线硅两瓦
只看该作者 13楼 发表于: 2003-10-14
图中的那个小空气我可是找了很久了。
离线liu4ic
只看该作者 14楼 发表于: 2003-10-14
回复: !!
最初由 硅两瓦 发表
图中的那个小空气我可是找了很久了。
我有一大箱,估计几千吧放房顶上两年了,估计雨水淋的差不多了!
bd4ic/刘茂松
免费提供dds960 dds频率合成控制器,联系电话:0632-5911592
离线硅两瓦
只看该作者 15楼 发表于: 2003-10-14
回复: 回复: !!
最初由 liu4ic 发表
bd4ic/刘茂松
赶快看看有没有幸存的.
离线硅两瓦
只看该作者 16楼 发表于: 2003-10-14
请有识之事翻译一下吧,让我们了解更多些.
我就是佩服外国ham,国内ham界唯"知识产权论"在这里显得苍白无力.
离线BD6CR
只看该作者 17楼 发表于: 2003-10-14
回复: !
看电路图就明白了啊,就是两片ne602,收发转换用手动的开关切换,低频部分带agc,发射功率很小,好象只有几百mw.75米波段的.
最初由 硅两瓦 发表
离线硅两瓦
只看该作者 18楼 发表于: 2003-10-14
回复: 回复: !
最初由 bd6cr 发表
非常感谢,不过听完你的介绍我就对它失去兴趣了,功率太少了点,收发用手动太麻烦了点.
离线BD6CR
只看该作者 19楼 发表于: 2003-10-14
原作者说这是一个实验机,实际上功率只有20mw.给出的连接上有一个500mw的功放电路,可以接上使用.
