  • 3791阅读
  • 6回复
寻求YAESU 8900扩频方法? [复制链接]
离线蛙仔
只看楼主 倒序阅读 0楼 发表于: 2003-06-04
那位火腿能帮忙???????????????
离线topgun
只看该作者 1楼 发表于: 2003-06-04
remove top cover of radio by removing all 8 screws.
disconnect speaker and move top aside.
locate the cpu on the radio, it has a crystal glued to the top of it and is located in the front left corner of the radio, it's the largest ic in the radio.
to the extreme left of the radio, you will see a row of pads, all empty except for a diode to the front, and one to the back. there are about 6 or 7 spots for diodes, but only 2 installed.
remove the front (closest to head of radio) diode with a small soldering iron or other tool.
turn the radio back on, it will automatically reset.
you now have ext coverage eg. tx 450-470, tx 150-170, etc...
离线vr2yrv
只看该作者 2楼 发表于: 2003-06-05
8900
离线he8zh
只看该作者 3楼 发表于: 2003-06-05
有人搞过吗?嘿嘿。。。我不想当白鼠。
离线九九
只看该作者 4楼 发表于: 2003-10-17
那是h的 不是r的 r的本来就扩开了
离线BG2VO
只看该作者 5楼 发表于: 2003-10-21
我的8900r买来就扩开了的
离线草原之夜
只看该作者 6楼 发表于: 2007-01-27
我的8900r买来就扩开了的
420兆一下不能发射的
看看下面对楼主有帮助吗
