  • 1909阅读
  • 9回复
空气电容是蝶形的好还是普通的好? [复制链接]
离线bi4mhd
只看楼主 倒序阅读 0楼 发表于: 2024-11-11
原来动手做过普通的空气电容。他们有说蝶形的好。具体哪一种好,有没有老师给指教一下?
离线bg3xx
只看该作者 1楼 发表于: 2024-11-11
15兆以内,200瓦以内,普通的就行。15兆以上,300瓦以上的功放调谐电路,就用蝶形空气电容,用普通空气电容频率高端损耗太大,功率调不上去。
离线7600
只看该作者 2楼 发表于: 2024-11-11
两个静片通过一个动片进行串联,可以降低电阻
本人系矮穷挫的屌丝
离线bg7ko
只看该作者 3楼 发表于: 2024-11-11
要看你用在什么场合!
在大功率发射机的末级  要求高的振荡器 ,用蝶状电容没有接触不良的问题,对称性要求高的LC回路如推挽输出电路,平衡天调也是用蝶状电容
                   WHAT  HATH  GOD  WROUGH                                 .
离线大傻
只看该作者 4楼 发表于: 2024-11-12
Butterfly
A butterfly capacitor is a form of rotary variable capacitor with two independent sets of stator
plates opposing each other, and a butterfly-shaped rotor arranged so that turning the rotor will
vary the capacitances between the rotor and either stator equally.
Butterfly capacitors are used in symmetrical tuned circuits, e.g. RF power amplifier stages in
push-pull configuration or symmetrical antenna tuners where the rotor needs to be “cold”, i.e.
connected to RF (but not necessarily DC) ground potential. Since the peak RF current normally
flows from one stator to the other without going through wiper contacts, butterfly capacitors
can handle large resonance RF currents, e.g. in magnetic loop antennas.
In a butterfly capacitor, the stators and each half of the rotor can only cover a maximum angle
of 90° since there must be a position without rotor/stator overlap corresponding to minimum
capacity, therefore a turn of only 90° covers the entire capacitance range.
Split stator
The closely related split stator variable capacitor does not have the limitation of 90° angle
since it uses two separate packs of rotor electrodes arranged axially behind one another. Unlike
in a capacitor with several sections, the rotor plates in a split stator capacitor are mounted on
opposite sides of the rotor axis. While the split stator capacitor benefits from larger electrodes
compared to the butterfly capacitor, as well as a rotation angle of up to 180°, the separation of
rotor plates incurs some losses since RF current has to pass the rotor axis instead of flowing
straight through each rotor vane
离线bi4mhd
只看该作者 5楼 发表于: 2024-11-13
谢谢老师
离线bi4mhd
只看该作者 6楼 发表于: 2024-11-13
谢谢老师
离线bi4mhd
只看该作者 7楼 发表于: 2024-11-13
谢谢老师
离线bi4mhd
只看该作者 8楼 发表于: 2024-11-13
谢谢老师
离线BD6QOQ
只看该作者 9楼 发表于: 2024-11-13
回 bg7ko 的帖子
bg7ko:要看你用在什么场合!
 (2024-11-11 19:44)
我业觉得。蝶形容量变化比普通要快,是不是不好细调?
呼号:BG6UA/方克魁 (BD6QOQ)
PS:谈理想谈人生也谈风月,不谈爱情。。。。。
