  • 1481阅读
  • 1回复
FCC的ULS重开(个人新申请和更新仍然待恢复) [复制链接]
离线BA1AJ
只看楼主 倒序阅读 0楼 发表于: 2023-06-27
06/22/2023
On Wednesday morning, June 21, 2023, the FCC had reopened the Universal Licensing System (ULS) and supporting systems, according to an email distributed to VEC organizations. However, as of 4:00 PM on Wednesday, the Electronic Batch Filing (EBF) system, used by VEC organizations for filing exam sessions, individual applications, and club license applications, was still not available as promised. Unfortunately, this means applications for new and upgraded licenses, and individual and club license filings still cannot be uploaded in the system for issuance.
When the EBF system becomes available, the Commission is requesting VECs to limit submissions into the filing system. In an email sent by the FCC, all EBF filers were asked to adhere to a restricted upload schedule in order to keep the EBF system stable and to avoid any potential technical problems. The FCC will be monitoring to ensure the EBF system is stable during this reopening period. If they assess that the upload volume is too high, they will send out another notice with directions to reduce the amount of uploads per hour.
ARRL VEC will comply with the FCC directive, limiting our transmissions but sending as many backlogged sessions as possible without overloading their system. The files will be submitted to the FCC in the order in which they were received, starting with the files from Monday, June 12, and moving forward from there. ARRL VEC will begin submitting the backlogged applications as soon as the EBF system becomes available, and assuming all FCC systems remain stable.
In an FCC notice published on June 21, 2023 (https://www.fcc.gov/document/uls-tcns-e-106-and-asr-available), the Commission provided a deadline extension for filings in the ULS and the Antenna Structure Registration (ASR) system, explaining, “Because parties could not make electronic filings or view the contents of the affected systems while they were unavailable, we are extending the deadlines for all regulatory filings that were due in the affected systems between June 9, 2023, and June 29, 2023, until Friday, June 30, 2023. We note that we have provided for a longer extension for these filings than initially contemplated in the June 13 Public Notice in anticipation of high traffic volumes on these systems in the coming days. In that regard, we encourage filers to consider deferring discretionary filings this week, and we encourage filers preparing large submissions to coordinate in advance with [the] staff of the Bureaus.”
[ 此帖被BA1AJ在2023-06-27 17:51重新编辑 ]
离线bd2dd
只看该作者 1楼 发表于: 2023-06-30
网上翻译;
2023年6月21日星期三上午,根据分发给VEC组织的电子邮件,FCC已经重新开放了通用许可系统(ULS)和支持系统。然而,截至周三下午4点,VEC组织用于提交考试课程、个人申请和俱乐部执照申请的电子批量申报(EBF)系统仍未按承诺使用。不幸的是,这意味着新的和升级的许可证申请,以及个人和俱乐部的许可证申报仍然不能在系统中上传,以进行发放。
当EBF系统可用时,委员会要求VEC限制提交到申报系统中。在FCC发出的电子邮件中,要求所有EBF申请者遵守限制性的上传时间表,以保持EBF系统的稳定,避免任何潜在的技术问题。FCC将进行监测,以确保EBF系统在此重新开放期间保持稳定。如果他们评估认为上传量过高,他们将再次发出通知,指示减少每小时的上传量。
ARRL VEC将遵守FCC的指示,限制我们的传输量,但在不使他们的系统过载的情况下尽可能多地发送积压的会话。这些文件将按照收到的顺序提交给FCC,从6月12日(星期一)的文件开始,依次递进。ARRL VEC将在EBF系统可用后立即开始提交积压的申请,并假设所有FCC系统保持稳定。
在2023年6月21日发布的FCC通知(https://www.fcc.gov/document/uls-tcns-e-106-and-asr-available)中,委员会为ULS和天线结构注册(ASR)系统中的申请提供了截止日期的延长,并解释说:"由于各方在受影响系统不可用时无法进行电子申请或查看其内容,我们将2023年6月9日至2023年6月29日期间受影响系统中应提交的所有监管文件的截止日期延长至2023年6月30日星期五。我们注意到,我们为这些申报提供了比6月13日公告中最初设想的更长的延期时间,因为预计这些系统在未来几天会有大量的流量。在这方面,我们鼓励申报者考虑在本周推迟酌情申报,我们鼓励准备提交大量材料的申报者提前与各局的工作人员协调。"
