  • 1959阅读
  • 6回复
这个CW比赛邀请,有点儿意思…… [复制链接]
离线bd4lb
只看楼主 倒序阅读 0楼 发表于: 2022-06-01
收到电子邮件,内容如下:
Dear CW fans,
You are welcome to participate in this  "just one hour" CW event on
Friday evening: HA3NS SPRINT MEMORIAL CW CONTEST 2022
- In memoriam of a great CW enthusiast, one of the founder of HACWG -
Date and time of the contest in this year: 03. June 2022. (Friday)
1st period 7MHz ‪19.00-19.29‬ UTC
2nd period 3.5MHz ‪19.30-19.59‬ UTC
Band: ‪7010-7040‬ KHz and ‪3510-3560‬ KHz
Mode: CW only
Categories: Single op (single TX)
Exchange: 599 + membership number for HACWG members, 599 + NM to all other participants
Call for contest: CQ NS
Multiplier: no multipliers
Score: Each valid contact counts 1 point. The final score is the total number of valid contacts.
QSY (Sprint) Rule: If a station makes a QSO after a CQ or QRZ he/she have to QSY at least
1KHz from that frequency to continue the competition.
Awards: downloadable electronic awards will be available
Log: Log must be upload in Cabrillo format to: https://log.mrasz.hu/
Suggested software: DXlog/HSC contest
If you are not able to create Cabrillo or upload your log, please send it via E-mail to ha3kna@tolna.net
Log deadline: not later than 7 days after the contest.
73 Lacy HA3NU
看来,比赛那天,要用闹钟把我叫醒……
但是,很可能没用……
离线bg6gqe
只看该作者 1楼 发表于: 2022-06-01
凌晨3点到4点,时间太晚了,估计国内没几个玩的
离线bd4lb
只看该作者 2楼 发表于: 2022-06-01
@bg6gqe
假如闹钟能把我叫醒,那就听一听……
假如我把闹钟给关了,那就继续睡~
本帖提到的人: @bg6gqe
离线BD6MM
只看该作者 3楼 发表于: 2022-06-01
回 bg6gqe 的帖子
bg6gqe:凌晨3点到4点,时间太晚了,估计国内没几个玩的 (2022-06-01 17:23)
六姥爷不是夜魔吗,可以打打酱油!
离线bg6gqe
只看该作者 4楼 发表于: 2022-06-01
回 BG6IYQ 的帖子
BG6IYQ:六姥爷不是夜魔吗,可以打打酱油![表情] (2022-06-01 18:45)
老了,几天没缓过劲来,搞不动了
离线bd4lb
只看该作者 5楼 发表于: 2022-06-04
用闹钟叫醒……
但是,7兆的底噪S5--S7,没有听到比赛的信号,呼叫十分钟,也无果~~
在80米波段,刚刚呼叫两遍,就有应答的~
也是唯一的~
G90S,20瓦功率,两单元三角形环形天线。
QSO: 3516 CW 2022-06-03 1937 BD4LB         599 001   JF2FIU         599 011
END-OF-LOG:
离线BG0ATE
只看该作者 6楼 发表于: 2022-06-04
想着这事,但喝多睡过时间了。
