  • 8209阅读
  • 31回复
GP天线地网摘录 [复制链接]
离线bi1epu
只看楼主 倒序阅读 0楼 发表于: 2022-02-08
年前从端馈转到了GP,因为端馈在家里架不起来,在野外也架不起来。
此帖意在收集和尝试更多的地网对性能的影响。(特别是14M段)
摘自K8MSH2021年3月的一篇文章
https://www.onallbands.com/how-many-how-long-advice-for-installing-ground-or-above-ground-radials%EF%BB%BF/#:~:text=The%20shorter%20your%20antenna%2C%20the,radials%20over%20fewer%20long%20ones.
作者的建议
* 地网埋地里和扔地上没什么区别
* 地网越多,对土壤导电率的依赖越小
* 放在地上的地网线不需要共振(地网扔地上不需要1/4波长)
* 天线越短,地网越多
* 离地地网电气长度应该为1/4波长
* 地网4根够用,越多越好
* 地网总长度固定,优先选则短而多,而不是长而少。(前文提到长度为电气长度1/4波,这里的短而多是否要比1/4更短?)两者间有最佳数量比。(但是并没有各频率,各长度的具体数值)
* 裸铜线或者带皮铜线最佳,带皮铜线用得久。粗线没有必要,性能提升不及成本提升。(但是粗线好整理)
* 如果空间有限,地网也是越多越好,能放哪就放哪。
  • There is little difference in performance between buried radials and radials laid directly on the ground.
  • The efficiency of the antenna system relies less on soil conductivity as the number of radials increases—something we can control.
  • Ground radials do not need to be resonant.
  • The shorter your antenna, the more you need radials.
  • Elevated radials should be electrically 1/4λ long.
  • Four elevated radials can perform as well as an extensive ground radial system, but a greater number is likely to work even better.
  • For a given length of wire, choose more short radials over fewer long ones. There is a relationship between the two and an optimum number-to-length ratio.
  • Bare or insulated copper radials are the best choice, with insulated wire being more durable. Using thick wire doesn’t change ground loss enough to justify the higher cost.
  • If you have limited space for ground radials, put down as many as you can wherever they’ll fit.
  • https://www.onallbands.com/how-many-how-long-advice-for-installing-ground-or-above-ground-radials%EF%BB%BF/#:~:text=The%20shorter%20your%20antenna%2C%20the,radials%20over%20fewer%20long%20ones.
这篇文章讲到把整个GP系统抬离地0.4米时,4根地网的作用相当于埋在地里的90-120根地网,只是辐射方向失真,用6根即可修正。
此时理论阻值为DP的一半,即36欧左右。这时将地网斜向下拉,可增加阻值,降低驻波。
https://rsars.files.wordpress.com/2013/01/study-of-20m-quarterwave-vertical-elevated-ground-plane-antenna-1-31.pdf
[ 此帖被bi1epu在2022-02-09 08:45重新编辑 ]
将在每个帖子下方显示,不限字数
离线电离层
只看该作者 1楼 发表于: 2022-02-08
有一定的参考价值!还得是老外!
BG2ALB
离线bi1epu
只看该作者 2楼 发表于: 2022-02-08
地网和阻值的关系
首先,这篇有一个反直觉的建议,地网长度越短需要的数量越少; 长度越长需要的数量越多。
其中两个数据比较是16根0.1波长地网和120根0.4波长地网。
文章数据,在16根0.1波的地网,阻值50欧,完美匹配发射机,SWR1.0, 而120根0.4波的地网,阻值35欧,SWR 1.43.
前者驻波匹配好,但是是发射的效率差在3DB以上。
ref PJ4DX
https://www.radioenthusiast.co.uk/news/radials-for-quarter-wave-verticals-an-overview/
将在每个帖子下方显示,不限字数
离线bi1epu
只看该作者 3楼 发表于: 2022-02-08
这张表的引用量非常之高,但是地网的长度数量比一直没明白。之前好多文章里都有一个地网总长的概念,比如14M人个波长的地网就是20*2 = 40米,然后这40米线怎么分的问题。
刚看了对这个的表的解释才比较明白,地网长度和数量的匹配是一个正相关的,
越长就得根数越多,低角辐射越好,阻值也越小;
越短则需要根数少,低角幅射越差, 阴值也越大。
(图中给的是个损失量,db值越大,幅射越小)
这里个人觉得这个Low-Angle Loss这个值主要是DX考虑,短地网功率也是实打实出去了,只不过辐射角更高,都上天了。
那么问题来了,SWR在1.5时,发射机满功发射发不会影响元件,元件寿命?影响的话,八重洲的机器修一次贵吗?或者底座附近盘个电感?
附表:
Length of Radials     0.4λ    0.25λ     0.2λ     0.15λ     0.125λ    0.1λ
Number of Radials    120       90         60        36          24         16
Impedance                   35Ω     37Ω      40Ω     43Ω       46Ω       52Ω
Low-Angle Loss          0      0.5dB      1dB    1.5dB      2dB       3dB
将在每个帖子下方显示,不限字数
离线张景玉
只看该作者 4楼 发表于: 2022-02-08
不错的资料!希望看到更多介绍以及前辈们的经验分享。
离线bd4lb
只看该作者 5楼 发表于: 2022-02-08
感谢楼主分享资料!
我的体会和测试:
使用GP天线,发射的时候,地网上高频信号的辐射强度很大。(地网部分,也参与电磁辐射了。)
GP天线适合安装在楼顶,或者,户外的地面上。
天线周围避免靠近:人员,或者,金属物体。(特别是大功率发射的时候!)
使用端馈天线,需要使用阻抗匹配器和平衡地线,发射的时候,平衡地线上高频信号的辐射强度很小。
比较适合安装在阳台内,只是把端馈的天线振子,拉到室外。
离线bi1epu
只看该作者 6楼 发表于: 2022-02-08
回 bd4lb 的帖子
bd4lb:感谢楼主分享资料!
我的体会和测试:
....... (2022-02-08 11:18)
地网辐射会打火吗?如果在干草地上铺地网,会不会。。?
我现在14M段用的是8根6米左右的地网,测试阻抗接近50,倒没有测试过辐射。
[ 此帖被bi1epu在2022-02-08 11:30重新编辑 ]
将在每个帖子下方显示,不限字数
离线bd4lb
只看该作者 7楼 发表于: 2022-02-08
地网线上的电磁辐射强度,可以用简易的场强计测量。
简易场强计:50微安的表头,1N60(或者,2AP9)组成。
把1N60的两端,接在微安表头的接线柱上。1N60接反了的话,表头指针会反向指示。
(微安表头的+端,接一根50厘米的电线当做天线。)
用场强计,分别靠近天线和地网线,测量电磁辐射强度,看看差别大不大。
使用GP天线,天线振子和地网之间,是绝缘的,发射的时候,不会产生火花。
离线bd4lb
只看该作者 8楼 发表于: 2022-02-08
电磁辐射对人的身体健康,或多或少,总是有伤害的。(有些与电磁辐射相关的工作,有特殊的防护服,工种补贴。)
注意防护……
离线bd4lb
只看该作者 9楼 发表于: 2022-02-08
调整短波天线的时候,我的手指,接触了天线振子的末端,高频电流灼伤手指皮肤,是很疼的。
离线bi1epu
只看该作者 10楼 发表于: 2022-02-08
回 bd4lb 的帖子
bd4lb:电磁辐射对人的身体健康,或多或少,总是有伤害的。(有些与电磁辐射相关的工作,有特殊的防护服,工种补贴。)
注意防护……
 (2022-02-08 12:39)
主要怕地网有高压把野外的草啊什么给点着了,辐射的话电台本身功率小,频率低,主要也是守听追台为主,喊不了几下。
将在每个帖子下方显示,不限字数
离线bg6tpy
只看该作者 11楼 发表于: 2022-02-08
回 bd4lb 的帖子
bd4lb:感谢楼主分享资料!
我的体会和测试:
怎么测试出 地网上有辐射?  测试过地网数量对收发增益得加减吗?
离线bd4lb
只看该作者 12楼 发表于: 2022-02-08
@bg6tpy
您把场强计,靠近GP天线的地网,发射的时候,测量一下,就明白了。
本帖提到的人: @bg6tpy
离线bi1epu
只看该作者 13楼 发表于: 2022-02-09
早上又重读了老美的文章,发看昨天理解的不对。
文章关于GP天线中地网是否离地分了两种来讨论。
1. 如果地网在地上,那么1935年之前的结论是越长越好,越多越好,标准是1/2波长120根, 后来大家倾向于使用1/4波长的地网,但是地网只要在地上,是否谐振没有多大关系
2. 地网抬起来在空间,则需要1/4电气波长諧振
而且而且,地网的离地不只是靠振子那侧,末端也要用拉线绝缘开。这么看,还得搞几根地钉,把地网也架起来。
[ 此帖被bi1epu在2022-02-09 08:56重新编辑 ]
将在每个帖子下方显示,不限字数
离线电离层
只看该作者 14楼 发表于: 2022-02-09
地网越长就得根数越多,低角辐射越好,阻值也越小;
就是说地波越强呗!
BG2ALB
离线bi1epu
只看该作者 15楼 发表于: 2022-02-09
回 电离层 的帖子
电离层:地网越长就得根数越多,低角辐射越好,阻值也越小;
就是说地波越强呗! (2022-02-09 12:42)
走地波那部分的能量应该都出不了省吧。
好多天线论坛都讨论把地网架起来,架空的地网需要谐振,普遍认为架空4根线的低角辐射等于地上铺上百根。
将在每个帖子下方显示,不限字数
离线ba4dl
只看该作者 16楼 发表于: 2022-02-09
地网铺地面,地网和地球电容耦合,短而多或长而少增加电容。短而多之所以比长而少好,因为长了线上电流分布不同是不希望的。悬空地网相当于dp垂直放,需要1/4波长地网参与谐振,此时天线越高地球影响越小,越和接地没有关系,越成为偶极天线而非单极天线。
离线bi1epu
只看该作者 17楼 发表于: 2022-02-09
回 ba4dl 的帖子
ba4dl:地网铺地面,地网和地球电容耦合,短而多或长而少增加电容。短而多之所以比长而少好,因为长了线上电流分布不同是不希望的。悬空地网相当于dp垂直放,需要1/4波长地网参与谐振,此时天线 .. (2022-02-09 15:06)
感谢
悬空地网的末端是否也要做绝缘离地?如果离地面太近,是不是也影响谐振频率?
将在每个帖子下方显示,不限字数
离线bi1epu
只看该作者 18楼 发表于: 2022-02-10
回 ba4dl 的帖子
假设把天线升高到自由空间,此时地网参与谐振,但是是馈线传输的信号是不平衡的,多根地网是不是也起到了把信号从不平衡转于是平衡的作,类似1:1巴伦?
将在每个帖子下方显示,不限字数
离线ba4dl
只看该作者 19楼 发表于: 2022-02-11
平衡时对于参考电位天线的两极电位大小相等方向相反。如果天线两级物理尺寸不同(或数量不同),就不能满足上述条件。应该是不平衡的
