  • 2684阅读
  • 3回复
FCC将开始向业余无线电爱好者收费 [复制链接]
离线BA1AJ
只看楼主 倒序阅读 0楼 发表于: 2020-09-02
根据8月28日ARRL报道
FCC Proposes to Reinstate Amateur Radio Service Fees
(UPDATED 2020-09-01 @1845 UTC)Amateur radio licensees would pay a $50 fee for each amateur radio license application if the FCC adopts rules it proposed this week. Included in the FCC’s fee proposal are applications for new licenses, renewal and upgrades to existing licenses, and vanity call sign requests. Excluded are applications for administrative updates, such as changes of address, and annual regulatory fees.
The FCC proposal is contained in a Notice of Proposed Rulemaking (NPRM) in MD Docket 20-270, which was adopted to implement portions of the “Repack Airwaves Yielding Better Access for Users of Modern Services Act” of 2018 — the so-called “Ray Baum’s Act.”
The Act requires that the FCC switch from a Congressionally-mandated fee structure to a cost-based system of assessment. In its NPRM, the FCC proposed application fees for a broad range of services that use the FCC’s Universal Licensing System (ULS), including the Amateur Radio Service that had been excluded by an earlier statute. The 2018 statute excludes the Amateur Service from annual regulatory fees, but not from application fees.
“Applications for personal licenses are mostly automated and do not have individualized staff costs for data input or review,” the FCC said in its NPRM. “For these automated processes — new/major modifications, renewal, and minor modifications — we propose a nominal application fee of $50 due to automating the processes, routine ULS maintenance, and limited instances where staff input is required.”
The same $50 fee would apply to all Amateur Service applications, including those for vanity call signs. “Although there is currently no fee for vanity call signs in the Amateur Radio Service, we find that such applications impose similar costs in aggregate on Commission resources as new applications and therefore propose a $50 fee,” the FCC said.
The FCC is not proposing to charge for administrative updates, such as mailing address changes for amateur applications, and amateur radio will remain exempt from annual regulatory fees. “For administrative updates [and] modifications, which also are highly automated, we find that it is in the public interest to encourage licensees to update their [own] information without a charge,” the FCC said.
The FCC also proposes to assess a $50 fee for individuals who want a printed copy of their license. “The Commission has proposed to eliminate these services — but to the extent the Commission does not do so, we propose a fee of $50 to cover the costs of these services,” the FCC said.
The Ray Baum’s Act does not exempt filing fees in the Amateur Radio Service. The FCC dropped assessment of fees for vanity call signs several years ago.
Deadlines for comments and reply comments will be determined once the NPRM appears in the Federal Register. Interested parties may file comments by using the FCC’s Electronic Comment Filing System (ECFS), posting to MD Docket No. 20-270. This docket is already open to accept comments, even though deadlines have not yet been set.
[ 此帖被BA1AJ在2020-09-02 14:15重新编辑 ]
离线BD7IS
只看该作者 1楼 发表于: 2020-09-03
离线bg8srq
只看该作者 2楼 发表于: 2020-09-06
我记得美国的短呼号是收费使用的,申请者按年交纳一笔费用可得到一个个人4-5位的短呼号。
RIG:K3 ANT:K4GP
只看该作者 3楼 发表于: 2020-09-06
回 bg8srq 的帖子
bg8srq:我记得美国的短呼号是收费使用的,申请者按年交纳一笔费用可得到一个个人4-5位的短呼号。 (2020-09-06 20:59)
早就不收钱了。
呼号:BI8CKU/VA3CKU/W5LUS
设备:八重洲FT-991A
天线:自制HexBeam
DXCC, IOTA100, WPX, WAC, WAE, IARU R3, AJD, AKA
来卡必回,内地来卡一律挂号回复。
若无法或不愿回卡,请您一定在QRZ.COM或.CN注明,以免浪费资源。
