  • 5355阅读
  • 7回复
FT-891 三频段参数化麦克风均衡器 你设置过吗? [复制链接]
离线BG2UE
只看楼主 倒序阅读 0楼 发表于: 2020-02-16
春节在家无聊翻说明书里有这个的介绍,各位友台,你的FT-891 这个功能有没有设置过?效果怎么样?
B4/BG2UE
离线BG2UE
只看该作者 1楼 发表于: 2020-02-16
网上找到的资料,抛砖引玉。希望大家一起研究!
Parametric Microphone Equalizer
The FT-2000, FT-950 and FT DX 5000 have a three-band Microphone Equalizer to enable you to adjust and enhance the transmitted audio very precisely. Be sure to read the chapter "Parametric Microphone Equalizer" in your YAESU transceiver operating manual. FT2000RC can help you to better optimize your TX audio settings with a visual equalizer tool.
The low, mid and high (treble) voice ranges can independently be adjusted by changing Center Frequency, Gain and Q (bandwidth). Put your headphones on, press the Moni button to be able to listen to your voice while you transmit and set the equalizer. Use your mouse to adjust any of the nine values or place the cursor into the drowdowns or edit controls and use the Cursor up or Cursor down keys to change values. The changed parameters have an immediate effect, they are immediately updated in the FT-2000 menu and are plotted as curves in the graphic equalizer scope. The red sum curve is the total of the low, mid and high curves (it has a slight positive offset on the Y-axis).
An independent group of parameters for the microphone equalizer can be set and saved when the Speech Processor is on. Be sure to repeat your adjustments for speech processor on.
If you are not happy with the new settings you can restore your old equalizer settings by clicking on the Restore old menu settings button. These are the parameters that were saved when you opened the TX audio settings screen.
You can also adjust the transmitted SSB Bandwidth in this screen by clicking on one of the six bandwidth buttons. The bandwidth is shown with a dark-green background color in the scope. Be sure to read the advices in the chapter "Adjusting the SSB transmitted bandwidth" in your YAESU operating manual!
[ 此帖被BG2UE在2020-02-16 15:17重新编辑 ]
B4/BG2UE
离线BG2UE
只看该作者 2楼 发表于: 2020-02-16
参数麦克风均衡器
FT-2000,FT-950和FT DX 5000具有三频段麦克风均衡器,可让您非常精确地调整和增强传输的音频。请务必阅读YAESU收发器操作手册中的“参数化麦克风均衡器”一章。 FT2000RC可使用可视均衡器工具帮助您更好地优化TX音频设置。
低,中和高(高音)语音范围可以通过更改中心频率,增益和Q(带宽)来独立调整。戴上耳机,按Moni按钮以在传输和设置均衡器时收听您的声音。使用鼠标调整九个值中的任何一个,或将光标置于下拉菜单或编辑控件中,然后使用向上或向下光标键更改值。更改的参数会立即生效,它们会在FT-2000菜单中立即更新,并在图形均衡器范围内绘制为曲线。红色总和曲线是低,中和高曲线的总和(在Y轴上有轻微的正偏移)。
当语音处理器打开时,可以设置和保存麦克风均衡器的一组独立参数。确保对语音处理器重复进行调整。
如果您对新设置不满意,可以通过单击“恢复旧菜单设置”按钮来恢复旧的均衡器设置。这些是打开“ TX音频设置”屏幕时保存的参数。
您还可以通过单击六个带宽按钮之一来在此屏幕中调整传输的SSB带宽。带宽在示波器中以深绿色背景色显示。请务必阅读YAESU操作手册中“调整SSB传输带宽”一章中的建议!
以上是谷歌翻译的!不知道准确吗?
[ 此帖被BG2UE在2020-02-16 15:16重新编辑 ]
B4/BG2UE
离线BG2UE
只看该作者 3楼 发表于: 2020-02-17
PRELIMINARY EQUALIZER SETTINGS.pdf (42 K) 下载次数:15
https://www.k6jrf.com/ft2k_main.html
[ 此帖被BG2UE在2020-02-17 08:28重新编辑 ]
B4/BG2UE
只看该作者 4楼 发表于: 2020-03-24
发射315hz一定要衰,Q可以=1,gain-6或-8dB。
315hz无论音乐还是语言主观感都不好听,而且特别容易各类机器的扬声器机震。并且能量大占据ssb太多功率,又对语言清晰度可懂度没什么大贡献。
至于喜欢hifi ssb感觉,可以把发射带宽加大,低频深于200或100hz,同时还是降衰315,微提升100-200hz这范围。
BD4AQR KF5GSV
离线BD3HY
只看该作者 5楼 发表于: 2020-03-24
FT-891能连接电脑进行操作吗?
地址:内蒙古阿荣旗第三中学
姓名:于海军(呼号:BD3HY)
邮编:162750
电话:13848605018
离线BD6QOQ
只看该作者 6楼 发表于: 2020-03-25
回 BD3HY 的帖子
BD3HY:FT-891能连接电脑进行操作吗? (2020-03-24 17:44)
能。
呼号:BG6UA/方克魁 (BD6QOQ)
PS:谈理想谈人生也谈风月,不谈爱情。。。。。
离线BD3HY
只看该作者 7楼 发表于: 2020-03-26
回 BD6QOQ 的帖子
BD6QOQ:能。
 (2020-03-25 11:32)
麻烦您能给指点一下,需要什么软件,怎样连接吗?谢谢了!
地址:内蒙古阿荣旗第三中学
姓名:于海军(呼号:BD3HY)
邮编:162750
电话:13848605018
