  • 2326阅读
  • 0回复
2018cqww报告来了 [复制链接]
离线ba4dl
只看楼主 倒序阅读 0楼 发表于: 2019-04-06
Contest:    2018 CQ WW DX SSB CONTEST
Call:       BA4DL
Category:   Single Op All Band High Power Assisted
Thank you for submitting a log in the 2018 CQ WW DX SSB Contest.
Your log checking report is below. We believe it is helpful for
participants to receive information on how their log was scored.
Log checking details for CQ WW SSB 2018:
    8,524 Logs total
3,151,513 QSOs total
2,752,505 (87.3%) QSO checked against another log
2,660,559 (96.7%) QSO checked good when checked against another log
   54,204 ( 1.6%) Busted calls
    8,206 ( 0.4%) Busted exchange
   26,914 ( 0.6%) Not in log
Average score reduction for all logs: 13.7%
Average Error Rate for all logs: 4.3%
Explanation of the report sections:
Summary - A summary of the log checking results and final score for
your entry.
Results by Band - This is a band-by-band breakdown of the QSOs,
points and multipliers for your entry.
Not In Log - These contacts were not found in the other station's
log. QSO removed with additional penalty of 2x QSO points.
Incorrectly Copied - The call logged for these contacts was
determined to be incorrect. QSO removed with additional penalty
of 2x QSO points.
Incorrect Exchange Information - The information you copied does not
match what was in the other station's log. The QSO was removed
without penalty.
Out of Band - Contacts that were verified to be made on frequencies
that you are not authorized to use. These contacts are removed without
penalty.
Band Change Violations (Multi-One or Multi-Two only) - These contacts
violated the band change rules for the category. The QSO was removed
without penalty.
Unique Calls Worked - These callsigns were not found in any other log.
They have not been removed, but our experience indicates they are
often the result of copying errors.
Lost Multipliers - This section lists the multipliers that were lost
in your log due to callsign, exchange, or other copying errors.
-C indicates lost country and -Z indicates lost zone.
Multipliers by band - This section lists the zones and countries
that were counted as multipliers in your log.
Stations Copying Your Exchange Incorrectly - This is a list of
contacts where the station you worked copied your exchange
incorrectly. You do not lose credit for these contacts.  They
are provided for your information.
Stations Copying Call Incorrectly - This is a list of all contacts we
could identify where the station you worked copied your call incorrectly.
You do not lose credit for these contacts. They are provided for your
information. If you have many similar errors, you should concentrate
on ways to send your call differently that may be easier for others
to correctly copy.
All logs are checked using custom software. Public logs are available at
https://www.cqww.com/publiclogs/2018ph/
Please submit any questions at https://cqww.com/contact/.
The decisions of the CQ WW Contest Committee are final.
73,
CQ WW DX Contest Committee
                       *** PLEASE HELP ***
The IT infrastructure behind the log robot, storage, checking software,
and this report are all provided and managed by volunteers.
The World Wide Radio Operators Foundation ("WWROF") has committed to
reimburse these infrastructure expenses for the CQ family of contests.
WWROF is a non-profit donor-supported organization. Please consider
making a contribution to the WWROF at
http://www.wwrof.org/content/donate
************************** Summary ***************************
    1646 Claimed QSO before checking (does not include duplicates)
    1608 Final   QSO after  checking reductions
    3463 Claimed QSO points
    3235 Final   QSO points
     205 Claimed countries
     204 Final   countries
      94 Claimed zones
      93 Final   zones
     299 Claimed mults
     297 Final   mults
1,035,437 Claimed score
960,795 Final   score
    7.2% Score reduction
    2.3% Error rate based on claimed and final qso counts
      26 (1.6%) calls copied incorrectly
       6 (0.4%) exchanges copied incorrectly
       6 (0.4%) not in log
      26 (1.6%) duplicates (Removed without penalty)
      10 (0.6%) calls unique to this log receiving credit (not removed)
********************** Results By Band ***********************
             Band   QSO  QPts  Zone Cty Mult
   Claimed   160M     0     0     0   0    0
   Final     160M     0     0     0   0    0
   Claimed    80M    13    14     4   4    8
   Final      80M    13    14     4   4    8
   Claimed    40M   340   550    27  48   75
   Final      40M   331   511    26  47   73
   Claimed    20M   688  1606    29  74  103
   Final      20M   668  1480    29  74  103
   Claimed    15M   499  1163    27  71   98
   Final      15M   490  1100    27  71   98
   Claimed    10M   106   130     7   8   15
   Final      10M   106   130     7   8   15
   Claimed    All  1646  3463    94 205  299   1035437
   Final      All  1608  3235    93 204  297    960795
************************* Not In Log *************************
14252 PH 2018-10-27 0548 BA4DL         24 IK2YCW        15
14240 PH 2018-10-27 1125 BA4DL         24 DF3IS         14
21201 PH 2018-10-28 0259 BA4DL         24 JI1LAI        25
14140 PH 2018-10-28 0924 BA4DL         24 DJ0IF         14
7136 PH 2018-10-28 1020 BA4DL         24 JS1BIB        25
7136 PH 2018-10-28 1100 BA4DL         24 JR1EMT        25
*********************** Incorrect Call ***********************
21268 PH 2018-10-27 0005 BA4DL         24 W7TK          03 correct W6TK
21268 PH 2018-10-27 0005 BA4DL         24 JH2VB         25 correct JH2UVB
21227 PH 2018-10-27 0821 BA4DL         24 S52K          15 correct S56K
21226 PH 2018-10-27 0953 BA4DL         24 PA2T          14 correct PC2T
14223 PH 2018-10-27 1129 BA4DL         24 DP6DT         14 correct DP6T
14306 PH 2018-10-27 1142 BA4DL         24 DL2RD         14 correct DL2ARD
7170 PH 2018-10-27 1237 BA4DL         24 N7EPD         03 correct N7EKD
14159 PH 2018-10-27 2313 BA4DL         24 JM1VDM        25 correct JI1VDM
14159 PH 2018-10-27 2322 BA4DL         24 K5KV          04 correct K5KJ
14159 PH 2018-10-27 2340 BA4DL         24 W4BW          05 correct W4KW
14159 PH 2018-10-28 0030 BA4DL         24 NU7J          03 correct NR7Z
21215 PH 2018-10-28 0237 BA4DL         24 JA1XRA        25 correct JG1XRA
21205 PH 2018-10-28 0653 BA4DL         24 US5U          16 correct UV5U
21310 PH 2018-10-28 0757 BA4DL         24 DF0HC         14 correct DF0HQ
21309 PH 2018-10-28 0818 BA4DL         24 EU6A          16 correct EU1A
14202 PH 2018-10-28 0959 BA4DL         24 M1T           14 correct TM1T
7136 PH 2018-10-28 1052 BA4DL         24 JA2AJF        25 correct JA2IJF
7136 PH 2018-10-28 1128 BA4DL         24 JF2XTY        25 correct JF3XTY
7136 PH 2018-10-28 1139 BA4DL         24 JJ6TBB/6      25 correct JJ3TBB
7136 PH 2018-10-28 1242 BA4DL         24 JA8RWU        25 correct JA2RWU
7133 PH 2018-10-28 1351 BA4DL         24 YC2BAS        28 correct YC0BAS
7120 PH 2018-10-28 2040 BA4DL         24 AU3A          22 correct EU3A
14180 PH 2018-10-28 2218 BA4DL         24 AA6FB         03 correct AA6VB
14180 PH 2018-10-28 2315 BA4DL         24 N7E           03 correct W7E
14270 PH 2018-10-28 2321 BA4DL         24 JA1ZGJ        25 correct JA1ZGP
14322 PH 2018-10-28 2353 BA4DL         24 JA1EAQ        25 correct JH1EAQ
*************** Incorrect Exchange Information ***************
14153 PH 2018-10-27 0129 BA4DL         24 K2PO          06 correct     3
14159 PH 2018-10-27 2317 BA4DL         24 KL7IH         05 correct     1
14159 PH 2018-10-28 0111 BA4DL         24 N5KO          04 correct     3
14180 PH 2018-10-28 2218 BA4DL         24 WA0PFC        04 correct     3
14180 PH 2018-10-28 2234 BA4DL         24 N3EG          05 correct     3
14180 PH 2018-10-28 2242 BA4DL         24 NY9H          04 correct     5
********* Unique Calls Receiving Credit (not removed)*********
14194 PH 2018-10-27 1134 BA4DL         24 DL8YED        14
7169 PH 2018-10-27 1328 BA4DL         24 HL4HCS        25
7169 PH 2018-10-27 2229 BA4DL         24 JF9MSO        25
14159 PH 2018-10-28 0044 BA4DL         24 KB6FB         03
14159 PH 2018-10-28 0113 BA4DL         24 N6RFM         03
28483 PH 2018-10-28 0207 BA4DL         24 JA6PVE        25
7136 PH 2018-10-28 1131 BA4DL         24 JE1ROG        25
7136 PH 2018-10-28 1206 BA4DL         24 JN3WTQ        25
7136 PH 2018-10-28 1211 BA4DL         24 JG3LET        25
7135 PH 2018-10-28 1421 BA4DL         24 DS4GA         25
********************** Lost Multipliers **********************
7120 PH 2018-10-28 2040 BA4DL         24 AU3A          22 correct EU3A   -C
7120 PH 2018-10-28 2040 BA4DL         24 AU3A          22 correct EU3A   -Z
*******************  Multipliers by Band  ********************
80M multiplier total 8
BY    JA    KH6   UA9
19 24 25 31
40M multiplier total 73
5B    9K    BV    BY    CN    D4    DL    DU    EA    EA8
ER    ES    F     HA    HL    HS    I     IT9   JA    JW
K     KH2   KH6   LU    LY    LZ    OH    OH0   OZ    PY
SM    SP    TA    UA    UA2   UA9   UN    UR    VE    VK
VR    XE    XX9   YB    YO    YU    ZL
  3  4  5  6 11 13 14 15 16 17 18 19 20 21 23 24 25 26 27 28
30 31 32 33 35 40
20M multiplier total 103
3W    4U1V  5B    9A    9M2   9M6   BV    BY    CN    CT
CT3   D4    DL    DU    E7    EA    EA8   EA9   EI    ER
ES    EU    F     G     GD    HA    HB    HL    HS    HZ
I     JA    JT    K     KH2   KH6   KL    LU    LX    LY
LZ    OE    OH    OH0   OK    OM    ON    OZ    PA    PY
PY0F  S5    SM    SP    SV    TG    UA    UA9   UN    UR
V8    VE    VK    VK9X  VR    XE    XX9   YB    YL    YO
YU    YV    ZL    ZP
  1  3  4  5  6  7  9 11 13 14 15 16 17 18 19 20 21 23 24 25
26 27 28 29 30 31 32 33 35
15M multiplier total 98
4U1V  4X    5B    9A    9K    9M6   9X    A4    A7    BY
CN    CT    CT3   CX    D4    DL    DU    E7    EA    EA8
EA9   ER    ES    EU    F     FK    G     GM    HA    HB
HL    HS    HZ    I     IT9   JA    K     KH2   KH6   KL
LX    LY    LZ    OE    OH    OH0   OK    OM    ON    OZ
PA    PY    S5    SP    SV    TA    UA    UA2   UA9   UN
UR    VK    VK9X  VR    VU    XE    XX9   YB    YL    YO
YU
  1  3  6 11 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
29 30 31 32 33 35 36
10M multiplier total 15
9M6   BY    DU    JA    KH2   KL    UA9   VK
  1 19 24 25 27 28 30
************* Stations Copying BA4DL Incorrectly *************
14153 PH 2018-10-27 0136 WU6X           3 BO4DL         24
14330 PH 2018-10-27 0209 JA8COE        25 A4DL          24
14157 PH 2018-10-27 0409 RC0CB         19 B4GDL         24
21000 PH 2018-10-27 0655 E27AZ         26 BG4DL         24
14150 PH 2018-10-27 0858 OE2E          15 JA4DL         25
7167 PH 2018-10-27 2244 YC7TUU        28 B4DL          24
21000 PH 2018-10-28 0453 RA0UJ         18 PA4DL         24
14306 PH 2018-10-28 0818 TM2T          14 SP4DL         15
21362 PH 2018-10-28 0843 RZ4Z          16 BA5DL         24
21362 PH 2018-10-28 0901 HB2S          14 BA4DA         24
7136 PH 2018-10-28 1126 JA1CJP        25 BAA4DL        24
7000 PH 2018-10-28 1354 JA1GLE        25 BA4AL         24
********** Stations Receiving Not In Log From BA4DL **********
21000 PH 2018-10-27 0321 VR2EH         24 BA4DL         24
21282 PH 2018-10-27 0621 YB8ROP        28 BA4DL         24
21000 PH 2018-10-27 0649 RA0UJ         18 BA4DL         23
21227 PH 2018-10-27 0749 II9L          15 BA4DL         24
21000 PH 2018-10-27 0801 US6IKF        16 BA4DL         24
14145 PH 2018-10-27 0859 IK6QON        15 BA4DL         24
14149 PH 2018-10-27 0923 DP6T          14 BA4DL         24
21225 PH 2018-10-27 1005 R4AC          16 BA4DL         24
7170 PH 2018-10-27 1208 KA6BIM         3 BA4DL         24
7169 PH 2018-10-27 1323 BD3QF         24 BA4DL         24
7000 PH 2018-10-27 1403 YD9VIZ        28 BA4DL         24
7170 PH 2018-10-27 1548 RO2E          16 BA4DL         24
7169 PH 2018-10-27 2232 RW4W          16 BA4DL         24
28483 PH 2018-10-28 0152 7K3DPL        25 BA4DL         24
14261 PH 2018-10-28 0522 VK9XG         29 BA4DL         24
21000 PH 2018-10-28 0714 SP1II         15 BA4DL         24
21205 PH 2018-10-28 0719 DX3H          27 BA4DL         24
7136 PH 2018-10-28 1044 HL2DBP        25 BA4DL         24
7137 PH 2018-10-28 1100 W0GJ           4 BA4DL         24
7136 PH 2018-10-28 1145 BY1CY         24 BA4DL         24
7173 PH 2018-10-28 2030 ED7B          14 BA4DL         24
14180 PH 2018-10-28 2219 W8FJ           5 BA4DL         24
14000 PH 2018-10-28 2239 WX0Z           4 BA4DL         24
14180 PH 2018-10-28 2303 W6BVB          3 BA4DL         24
14180 PH 2018-10-28 2304 AG9S           4 BA4DL         24
14180 PH 2018-10-28 2305 N4BCD          4 BA4DL         24
******** Stations Copying BA4DL Exchange Incorrectly *********
14000 PH 2018-10-27 0853 OK1GTH        15 BA4DL         23 correct 24
14204 PH 2018-10-27 1148 ED3M          14 BA4DL         16 correct 24
21205 PH 2018-10-28 0500 UT5LO         16 BA4DL         23 correct 24
21000 PH 2018-10-28 0906 SP3LD         15 BA4DL         28 correct 24
14347 PH 2018-10-28 0930 IQ4FA         15 BA4DL         20 correct 24
google的翻译
比赛:2018年CQ WW DX SSB比赛
致电:BA4DL
类别:单声道全频段高功率辅助
感谢您提交2018年CQ WW DX SSB竞赛的日志。
您的日志检查报告如下。我们相信这对你有所帮助
参与者接收有关他们的日志评分的信息。
记录CQ WW SSB 2018的详细信息:
    总共8,524个日志
总共3,151,513个QSO
2,752,505(87.3%)QSO检查另一个日志
2,660,559(96.7%)QSO在检查另一个日志时检查良好
   54,204(1.6%)被打电话
    8,206(0.4%)Busted exchange
   26,914(0.6%)不在日志中
所有日志的平均得分降低:13.7%
所有日志的平均错误率:4.3%
报告部分的说明:
摘要 - 日志检查结果和最终得分的摘要
你的参赛作品
带的结果 - 这是QSO的逐带分解,
您的参赛作品的积分和乘数。
不在日志中 - 在其他电台中找不到这些联系人
登录。QSO被删除,额外罚款2倍QSO点。
错误复制 - 为这些联系人记录的呼叫是
确定是不正确的。QSO被删除并带来额外处罚
2次QSO点数。
Exchange信息不正确 - 您复制的信息不是
匹配其他站的日志中的内容。QSO被删除了
没有罚款。
带外 - 经验证可在频率上制作的触点
您无权使用。这些联系人没有删除
罚款。
频段更改违规(仅限多人或多人) - 这些联系人
违反了该类别的乐队变更规则。QSO被删除了
没有罚款。
工作的唯一呼叫 - 在任何其他日志中找不到这些呼号。
他们没有被删除,但我们的经验表明他们是
通常是复制错误的结果。
丢失乘数 - 此部分列出了丢失的乘数
由于呼号,交换或其他复制错误而在您的日​​志中。
-C表示丢失的国家,-Z表示丢失的区域。
按频段乘数 - 本节列出了区域和国家/地区
在您的日志中被计为乘数。
站点错误地复制您的Exchange  - 这是一个列表
您工作的电台的联系人复制了您的交换
不正确。您不会因这些联系人而失去信誉。他们
是为了您的信息。
电台错误地复制呼叫 - 这是我们所有联系人的列表
可以识别你工作的电台在哪里复制你的电话不正确。
您不会因这些联系人而失去信誉。它们是为您提供的
信息。如果你有很多类似的错误,你应该集中注意力
关于以不同方式发送呼叫的方式,对其他人来说可能更容易
正确复制。
使用自定义软件检查所有日志。公共日志可在
请通过https://cqww.com/contact/提交任何问题。
CQ WW竞赛委员会的决定是最终决定。
73,
CQ WW DX竞赛委员会
                       *** 请帮忙 ***
日志机器人,存储,检查软件背后的IT基础设施,
这份报告全部由志愿者提供和管理。
世界无线电运营商基金会(“WWROF”)已承诺
偿还CQ系列竞赛的基础设施费用。
WWROF是一个非营利性捐助者支持的组织。请考虑
为WWROF做出贡献
**************************摘要*********************** ****
    1646在检查之前声明了QSO(不包括重复)
    1608检查减少后的最终QSO
    3463声称QSO点
    3235最终QSO点
     205声称的国家
     204最终国家
      94个声明的区域
      93最后区域
     299声称是邪恶的
     297最后的邪教
1,035,437声称得分
960,795最终得分
    分数减少7.2%
    2.3%基于声明的和最终的qso计数的错误率
      26(1.6%)次呼叫复制不正确
       6(0.4%)次交换错误复制
       6(0.4%)不在日志中
      26(1.6%)重复(删除未经处罚)
      此日志接收信用的10个(0.6%)呼叫唯一(未删除)
**********************乐队结果***********************
             乐队QSO QPts Zone Cty Mult
   声称160M 0 0 0 0 0
   最终160M 0 0 0 0 0
   声称80M 13 14 4 4 8
   决赛80M 13 14 4 4 8
   声称40M 340 550 27 48 75
   决赛40M 331 511 26 47 73
   声称20M 688 1606 29 74 103
   决赛20M 668 1480 29 74 103
   声称15M 499 1163 27 71 98
   决赛15M 490 1100 27 71 98
   声称10M 106 130 7 8 15
   决赛10M 106 130 7 8 15
   声明全部1646 3463 94 205 299 1035437
*************************不在日志********************** ***
***********************电话不正确***********************
21268 PH 2018-10-27 0005 BA4DL 24 W7TK 03正确W6TK
21268 PH 2018-10-27 0005 BA4DL 24 JH2VB 25正确JH2UVB
21227 PH 2018-10-27 0821 BA4DL 24 S52K 15正确S56K
21226 PH 2018-10-27 0953 BA4DL 24 PA2T 14正确的PC2T
14223 PH 2018-10-27 1129 BA4DL 24 DP6DT 14正确的D​​P6T
14306 PH 2018-10-27 1142 BA4DL 24 DL2RD 14正确的D​​L2ARD
7170 PH 2018-10-27 1237 BA4DL 24 N7EPD 03正确N7EKD
14159 PH 2018-10-27 2313 BA4DL 24 JM1VDM 25校正JI1VDM
14159 PH 2018-10-27 2322 BA4DL 24 K5KV 04正确K5KJ
14159 PH 2018-10-27 2340 BA4DL 24 W4BW 05正确W4KW
14159 PH 2018-10-28 0030 BA4DL 24 NU7J 03正确NR7Z
21215 PH 2018-10-28 0237 BA4DL 24 JA1XRA 25正确JG1XRA
21205 PH 2018-10-28 0653 BA4DL 24 US5U 16校正UV5U
21310 PH 2018-10-28 0757 BA4DL 24 DF0HC 14正确DF0HQ
21309 PH 2018-10-28 0818 BA4DL 24 EU6A 16正确的EU1A
14202 PH 2018-10-28 0959 BA4DL 24 M1T 14纠正TM1T
7136 PH 2018-10-28 1052 BA4DL 24 JA2AJF 25正确的JA2IJF
7136 PH 2018-10-28 1128 BA4DL 24 JF2XTY 25更正JF3XTY
7136 PH 2018-10-28 1139 BA4DL 24 JJ6TBB / 6 25正确JJ3TBB
7136 PH 2018-10-28 1242 BA4DL 24 JA8RWU 25正确JA2RWU
7133 PH 2018-10-28 1351 BA4DL 24 YC2BAS 28纠正YC0BAS
7120 PH 2018-10-28 2040 BA4DL 24 AU3A 22正确的EU3A
14180 PH 2018-10-28 2218 BA4DL 24 AA6FB 03正确AA6VB
14180 PH 2018-10-28 2315 BA4DL 24 N7E 03正确W7E
14270 PH 2018-10-28 2321 BA4DL 24 JA1ZGJ 25正确的JA1ZGP
14322 PH 2018-10-28 2353 BA4DL 24 JA1EAQ 25更正JH1EAQ
***************交换信息不正确***************
14153 PH 2018-10-27 0129 BA4DL 24 K2PO 06正确3
14159 PH 2018-10-27 2317 BA4DL 24 KL7IH 05正确1
14159 PH 2018-10-28 0111 BA4DL 24 N5KO 04正确3
14180 PH 2018-10-28 2218 BA4DL 24 WA0PFC 04正确3
14180 PH 2018-10-28 2234 BA4DL 24 N3EG 05正确3
14180 PH 2018-10-28 2242 BA4DL 24 NY9H 04正确5
*********唯一电话接收信用(未删除)*********
**********************失去的乘数**********************
7120 PH 2018-10-28 2040 BA4DL 24 AU3A 22正确的EU3A -C
7120 PH 2018-10-28 2040 BA4DL 24 AU3A 22正确的EU3A -Z
*******************乐队乘数********************
80M乘数总计8
作者:JA KH6 UA9
19 24 25 31
40M乘数总计73
30 31 32 33 35 40
20M乘数总计103
ES EU FG GD HA HB HL HS HZ
YU YV ZL ZP
15M乘数总计98
PA PY S5 SP SV UA UA2 UA9 UN
YU
10M乘数总计15
  1 19 24 25 27 28 30
*************电台BA4DL错误地复制*************
**********从BA4DL收到不在日志中的电台**********
********站点错误地复制BA4DL交换*********
14000 PH 2018-10-27 0853 OK1GTH 15 BA4DL 23正确24
14204 PH 2018-10-27 1148 ED3M 14 BA4DL 16正确24
21205 PH 2018-10-28 0500 UT5LO 16 BA4DL 23正确24
21000 PH 2018-10-28 0906 SP3LD 15 BA4DL 28正确24
14347 PH 2018-10-28 0930 IQ4FA 15 BA4DL 20正确24
