  • 2471阅读
  • 2回复
请教FT-51R扩频 [复制链接]
离线bg5gav
只看楼主 倒序阅读 0楼 发表于: 2019-03-24
哪位大神知道FT-51R的扩频方法
离线gdradio
只看该作者 1楼 发表于: 2019-03-31
仅供参考。玩机很快乐,改机有风险。
Locate a set of etched jumpers on the pc board. They are located adjacent to the bend in the ribbon cable. They are not marked, and are situated as follows (o-o indicates closed, o o indicates open):
      JP1001   o-o
                     o o JP1005
      JP1002   o o
                     o o JP1006
      JP1003   o o
                     o-o JP1007
      JP1004   o-o
Using solder wick or your preferred method of solder-removal, carefully remove the jumper for JP1007. This enables the 134-174, 420-470 MHz transmit.
离线VR2KW
只看该作者 2楼 发表于: 2019-04-02
除了楼上所说的硬件要设置,软件上也要设置,要同时按着数个键开机,然后可以选择美欧日版,因为太久忘了怎么操作了。
