  • 4529阅读
  • 9回复
为了普及数据模式在BY的操作程度,ARRL RTTY RU比赛前再次提供中文规则参考 [复制链接]
离线hamly
只看楼主 倒序阅读 0楼 发表于: 2019-01-05
总体和上次的FT8 Roundup 大同小异,比赛由ARRL主办
Objective: Amateurs worldwide contact and exchange QSO information with other amateurs using digital modes (Baudot RTTY, PSK, FT8, ASCII, AMTOR, Packet—attended operation only) on 80, 40, 20, 15, and 10 meter bands. Any station may work any other station. Stations may be worked once per band, regardless of mode.
比赛模式  RTTY   PSK 31/64  FT8 等数据模式       FT8模式指定使用WSJT-X 2.0版本,JTDX无法参赛。其他模式可使用N1MM+ 等竞赛软件。
波段   80-10米
时间   北京时间 1月6日 0200 开始
                          1月7日  0759 结束
注意,比赛操作时长不得超过24个小时,30个小时比赛中要有6个小时的关机时间。6个小时的关机时间可以分为两个部分。
功率   Both Single Operator and Multioperator categories have the following power level definitions:High Power: Greater than 150 watts
Low Power: 150 watts or less
There is no QRP category in the RTTY Roundup.
HP高功  大于等于150W小于等于1500W,遵循操作证书的限制,中国1000W以内
LP低功  小于等于150W    B类 100W  C类 100-150W
没有QRP组,没有QRP组,没有QRP组
比赛分组,自由选择  3. Entry Categories:
3.1. Single Operator (单人无辅助,不得使用,发布spot和FT8多信道解码器): The use of spotting assistance or automated, multi-channel decoders is not permitted.
3.1.1. Low Power: 150 watts transmitter output or less.
3.1.2. High Power: Maximum transmitter output of 1500 watts or license limit, whichever is less.
3.2. Single Operator Unlimited(单人有辅助,允许使用节点发布spot和FT8多信道解码器): The use of spotting assistance or automated, multi-channel decoders is permitted.
3.2.1. Low Power: 150 watts transmitter output or less.
3.2.2. High Power: Maximum transmitter output of 1500 watts or license limit, whichever is less.
3.3. Multioperator, Single Transmitter:  多人单机
3.3.1. Low Power: 150 watts transmitter output or less.
3.3.2. High Power: Maximum transmitter output of 1500 watts or license limit, whichever is less.
3.3.3. Includes those that receive assistance with logging or relief operators, etc.
3.3.4. Multioperator stations are limited to 6 band changes (maximum) in any clock hour.
3.3.5. The clock hour is from zero through 59 minutes.
3.3.6. Band changes are defined so that, for example, a change from 20 meters 15 meters and then back to 20 meters constitutes two band changes.
比赛信息交换4. Exchange:
4.1. United States: Signal report and State (except for KH6 and KL7 who  compete as DX Entities and will send serial numbers). 美国台交换RST+所在州名
4.2. Canada: Signal report and Province.       加拿大台交换RST+所在省名
4.3. DX: Signal report and consecutive serial number, starting with 001. 中国电台交换RST+序列号   参见WSJT-X 2.0 及N1MM等竞赛软件相关设置
分数计算5. Scoring:
5.1. QSO Points: Count one point for each completed QSO.            一个双向完整的QSO一分
5.2. Multipliers: Each US state (except KH6 and KL7) plus the District of Columbia (DC), Canadian provinces/territories: NB (VE1, 9), NS (VE1), QC (VE2), ON (VE3), MB (VE4), SK (VE5), AB (VE6), BC (VE7), NWT (VE8), NF (VO1), LB (VO2), NU (VYØ), YT (VY1), PEI (VY2) and each DXCC country. KH6 and KL7 count only as separate DXCC entities.        每个美国和加拿大分区,DXCC分区算一个系数分 ,KH6和KL7前缀作为DXCC实体单独计算。
5.2.1. Multipliers count only once (not once per band).       一个系数分在80-10米上只算一次
5.2.2. The US and Canada do not count as DXCC entities.   美国和加拿大两个国家不作为单独实体计算系数分
提交比赛日志6. Reporting:
6.1. 7-Day Deadline: All entries must be postmarked or uploaded by 2359 UTC January 13, 2019.    截止日期到1月14日  0759
日志格式均以Cabrillo提交,导出方法参考WSJT使用手册和N1MM+使用手册,或咨询各路神仙。
提交日志通过网页在线提交6.2. Logs in Cabrillo format format must be uploaded via the online web app. Once uploaded online via web app, a confirmation email will be sent to you.  You can view the list of electronically-submitted logs at http://contests.arrl.org/logsreceived.php
奖状8. Awards:
8.1. Certificates will be awarded in the following categories (and will be viewable on line at http://contests.arrl.org/certificates.php):
8.1.1. Top high power and low power Single Operator and Multioperator scorers in each ARRL/RAC Section.
8.1.2. Top high power and low power Single Operator and Multioperator scorers in each DXCC country (other than W/VE).
8.2. Plaques, if sponsored, will be awarded to the top scoring low and high power entrant in each category overall, each ARRL Division, and Canada.
8.2.1. Unsponsored plaques may be purchased from the ARRL.
BY,VR2,XX9,BV中各取每个参赛组最高得分为优胜者并颁发奖状。
如果比赛有足够的资金赞助,在整个比赛组别中最高优胜者奖被颁发奖牌。
以上规则来自http://www.arrl.org/rtty-roundup
GL&73
BH6KWC
DE BH6KWC OM64
离线hamly
只看该作者 1楼 发表于: 2019-01-05
Re:为了普及数据模式在BY的操作程度,ARRL RTTY RU比赛前再次提供中文规则 ..
January 2019 QST - Taylor - FT8.pdf (291 K) 下载次数:54
附FT8创造者K1JT博士对FT8比赛的软件设置和建议
DE BH6KWC OM64
离线BI1EIH
只看该作者 2楼 发表于: 2019-01-05
4小时倒计时
de BI1EIH (ex. B1/BG6ICN)
https://radiopi.club/
离线BD7TBP
只看该作者 3楼 发表于: 2019-01-06
回 hamly 的帖子
hamly:[图片]
 (2019-01-05 20:39)
   按提示进入special operating activity  提示  ROUNDUP EXCHANGE 号怎样填写?
人不可有傲气,但不可无傲骨...........
中国---越南 / 老挝 / 缅甸 / 柬埔寨 专业出口贸易商
离线BG8SRK
只看该作者 4楼 发表于: 2019-01-06
回 BD7TBP 的帖子
BD7TBP:   按提示进入special operating activity  提示  ROUNDUP EXCHANGE 号怎样填写? (2019-01-06 01:24)
EXCH    :DX
张刚
QQ :80152272
13908782852
楚雄州业余无线电协会(CXARA)
集体电台 : BY8SCX
APRS DIGI:  BR8SCX-3 144.640
离线岛上闲人
只看该作者 5楼 发表于: 2019-01-06
7点开机什么都没有啊!
BD3PGZ
离线hamly
只看该作者 6楼 发表于: 2019-01-06
回 岛上闲人 的帖子
岛上闲人:7点开机什么都没有啊!
 (2019-01-06 10:20)
现在呢?
DE BH6KWC OM64
离线岛上闲人
只看该作者 7楼 发表于: 2019-01-06
下午,晚上都没收到,FT8模式可以的
BD3PGZ
离线VR2UPU
只看该作者 8楼 发表于: 2019-01-07
QQ 群 : 308532243  FT8 数据通信俱乐部
离线BD6CR
只看该作者 9楼 发表于: 2019-01-12
感谢,刚刚提交日志
73 de BD6CR/4 上海浦东
