  • 7367阅读
  • 27回复
谁给发一个wsjt-x2.0?玩玩老头乐 [复制链接]
离线bg9cjh
只看楼主 倒序阅读 0楼 发表于: 2018-11-14
官方网站下不下来,哪位给发个玩玩。v1.8 /1.9也行,win32
19663519@qq.com
呼 号:BD9CJH
地 址:陕西.西安
QQ:19663519(非HAM勿加)
只看该作者 1楼 发表于: 2018-11-14
离线BI1EIH
只看该作者 2楼 发表于: 2018-11-14
2.0没出正式版呢。现阶段还是 1.9.1 是主流。
de BI1EIH (ex. B1/BG6ICN)
https://radiopi.club/
离线BG8FT
只看该作者 3楼 发表于: 2018-11-14
QQ:1914358
18908210888
离线bh1xle
只看该作者 4楼 发表于: 2018-11-14
目前2.0还是公测版本,可能有bug,正式版之后测试版就不支持了,建议楼主明年初去官网上看看正式版出没出
呼号9V1HY/BH1XLE,QTH新加坡/北京。
【宅台长】属于年轻火腿的业余无线电频道
B站:https://space.bilibili.com/343784870/
Youtube:https://www.youtube.com/channel/UC4T2IhnAkxRn87ckFZZXimQ
微信公众号:OurRadioShack
微博:@火腿宅台长
欢迎大家订阅关注!!!
只看该作者 5楼 发表于: 2018-11-14
RC4群里有
900兆:要奇奇陆吧三铃摇摇就散
离线VR2UPU
只看该作者 6楼 发表于: 2018-11-14
WSJT-X 2.0 RC4 祗支持新77位元的FT8,已往在用的FT8不支持,所以下载RC4亦没几个人用。
要用还是用RC3吧或JTDX JTDX-18.1.100
Release: WSJT-X 2.0-rc4
                November 12, 2018
Changes from WSJT-X Version 2.0.0-rc3 include the following:
-  Fix the "cannot open file fort.81" bug
-  Avoid too many redirect loops related to openSSL support
-  Fix the auto-generated messages for nonstandard callsigns
------>   Remove all support for the legacy FT8 protocol
-  Disallow selecting MSK144 with RTTY or Field Day messages active
-  Correct and expand support for color highlighting decoded messages
-  ESC key aborts a QSO, clears DX Call, and selects Tx6
-  Disable "nextCall" procedure for RTTY contest; it still needs work
-  Correct a flaw in handling MSK144 Sh messages
-  Prevent Fox from inadvertently toggling Tx 1st/Even
-  Re-organize the Fox/Hound/Contest selection boxes
-  Improve the validators for contest exchange boxes
-  Disable Tx after 5 minutes of no mouse movement
-  Remove end-of-line AP info when using contest messages
-  Fix forwarding of Sent and Rcvd exchanges to N1MM+ and ADIF log
-  Don't auto-log a QSO with incomplete exchange info
-  Fix two sequencing flaws after double-clicks on a decoded msg
-  New facilities for Contest and Fox-mode logging
[ 此帖被VR2UPU在2018-11-14 19:25重新编辑 ]
QQ 群 : 308532243  FT8 数据通信俱乐部
离线bg4csp
只看该作者 7楼 发表于: 2018-11-15
有没有FT8的教程呢?
离线BD7OXR
只看该作者 8楼 发表于: 2018-11-16
欢迎加入老头乐 有问题就找 VR2UPU
呼号:BD7OXR (EX  BH7OXR)
电话:幺山漆幺幺山山吾林吾酒
地址:QRZ.cn qrz.com
Q Q:1885639
WX:BD7OXR
邮箱:bd7oxr@126.com
离线bg8ah
只看该作者 9楼 发表于: 2018-11-17
回 BD7OXR 的帖子
BD7OXR:欢迎加入老头乐[表情] 有问题就找 VR2UPU
 (2018-11-16 06:53)
我一直不能发射,在坛里求教也没有彻底解决。郁闷!
E-mail: 379798120@qq.com
* 电话:135-5853-6856
* BG8AH :179:
* 邮编:635200
离线bg8ah
只看该作者 10楼 发表于: 2018-11-17
回 BD7OXR 的帖子
 (2018-11-16 06:53)
可有联系VR2UPU方法?
* 电话:135-5853-6856
* BG8AH :179:
* 邮编:635200
离线bg4csp
只看该作者 11楼 发表于: 2018-11-17
回 BD7OXR 的帖子
 (2018-11-16 06:53)
各种模式都要玩一下。
离线BA9BF
只看该作者 12楼 发表于: 2018-11-22
我安装上2.0.0版后,不能正常解码,能发射,对方也能解调,就是我的页面上没解调出任何信号!白板一张!
这个是2.0.0设置上的问题吗?
Email: ba9bf@163.com
离线bg4csp
只看该作者 13楼 发表于: 2018-11-24
回 BA9BF 的帖子
BA9BF:我安装上2.0.0版后,不能正常解码,能发射,对方也能解调,就是我的页面上没解调出任何信号!白板一张!
这个是2.0.0设置上的问题吗?[表情]  (2018-11-22 23:49)
我跟你正好相反,可以接受,可以解码,但是点击发射状态是在发射,就是声音传不出去。一直CQ但是ALC不起表。郁闷。
右侧的接受解码栏里面只看到别的电台们在互相握手。。眼馋啊。。。
难道真的要我手握话筒对着电脑喇叭按PTT????
离线hamly
只看该作者 14楼 发表于: 2018-11-24
回 bg4csp 的帖子
bg4csp:我跟你正好相反,可以接受,可以解码,但是点击发射状态是在发射,就是声音传不出去。一直CQ但是ALC不起表。郁闷。
难 .. (2018-11-24 12:59)
看看声卡设置
DE BH6KWC OM64
只看该作者 15楼 发表于: 2018-11-24
回 bg4csp 的帖子
检查声卡以及电台的模式
900兆:要奇奇陆吧三铃摇摇就散
离线VR2UPU
只看该作者 16楼 发表于: 2018-11-24
回 bg4csp 的帖子
bg4csp:
声音可按软件上的TUNE按钮,从软件送出一个单音, 经过计算机系统的声卡控制相关设备,如电台机器上的声卡, 有些计算机系统把音效音量关闭或处于低水平。 另外声音进入电台机器的通路, 有很多机器是区分并须要阁下动手设定, 如SSB是从前端话筒进入, 数据是从后端插孔进入。
至于ALC不起表, 有可能音量未足够. 最佳是ALC表显示极低数值, 音量过大引起镜影讯号干扰.
离线bg4csp
只看该作者 17楼 发表于: 2018-11-26
回 VR2UPU 的帖子
VR2UPU:声音可按软件上的TUNE按钮,从软件送出一个单音, 经过计算机系统的声卡控制相关设备,如电台机器上的声卡, 有些计算机系统把音效音量关闭或处于低水平。 另外声音进入电台机器的通路, 有很多 .. (2018-11-24 18:04)
谢谢前辈指导,看来问题出在USB声卡上,我原来fldigi可以USB声卡SSB的,现在也不行了。这几天比较忙,等空下来再仔细研究USB声卡问题出在哪里。
离线BA9BF
只看该作者 18楼 发表于: 2018-11-26
大家对WSJT2.0.0版本测试结果如何了?
能和低版本的兼容解码吗?请说说自己测试的结果吧!
离线bg4csp
只看该作者 19楼 发表于: 2018-11-27
回 BA9BF 的帖子
BA9BF:
还没测试2.0,刚搞定1.9
今天我用另一台电脑安装后USB声卡正常了。顺便通联了几个日本和印尼友台。
以前那台是虚拟机系统,看来虚拟机连接还是有问题。
