如何重装DAX驱动程序
如何重装DAX驱动程序
BA7NQ
UID:2748
7813小时
管理员
发表于: 2018-07-31
DAX是FlexRadio的音频和数据输入输出通道,可以理解为这是一个Windows系统上的虚拟声卡设备。
有时候因为操作系统的补丁自动更新问题,会引起DAX的工作不正常,可以按照一下方法恢复:
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers?_ga=2.238077766.718458986.1532996724-1575211826.1525739359
If you are requested by support to reinstall your DAX drivers, please use the procedure below.
This procedure assumes you are running on a 64-bit operating system. If you are using a 32-bit version of Windows, you will need to change the directory path to replace 64-bit Drivers with 32-bit Drivers.
In the example below SmartSDR is version 1.6.21 is used to re-install 64-bit DAX drivers.
Make certain you are running this procedure from the
latest
SmartSDR for Windows application folder installed on your PC.
Shut down SmartSDR
Close the DAX Control Panel
Close any sound card applications that may be using a DAX sound device
Using the Windows Search, type in
CMD
Right click on
cmd.exe
and
Run as Administrator
Change directory to where the DAX_IQ driver is located:
cd \Program Files\FlexRadio Systems\SmartSDR v1.6.21\64-bit Drivers\IQ_DAX
Run the DAXIQ driver uninstall batch file:
SmartSDR_IQ_DAX_uninstall.bat
Run the DAXIQ driver install batch file:
SmartSDR_IQ_DAX_install.bat
Change directory to where the RXAudio_DAX driver is located:
cd \Program Files\FlexRadio Systems\SmartSDR v1.6.21\64-bit Drivers\RXAudio_DAX
Run the RXAudio_DAX driver uninstall batch file:
SmartSDR_RX_DAX_uninstall.bat
Run the RXAudio_DAX driver install batch file:
SmartSDR_RX_DAX_install.bat
Change directory to where the TXAudio_DAX driver is located:
cd \Program Files\FlexRadio Systems\SmartSDR v1.6.21\64-bit Drivers\TXAudio_DAX
Run the TXAudio_DAX driver uninstall batch file:
SmartSDR_TX_DAX_uninstall.bat
Run the TXAudio_DAX driver install batch file:
SmartSDR_TX_DAX_install.bat
Change directory to where the MICAudio_DAX driver is located:
cd \Program Files\FlexRadio Systems\SmartSDR v1.6.21\64-bit Drivers\MICAudio_DAX
Run the MICAudio_DAX driver uninstall batch file:
SmartSDR_MICAUDIO_DAX_uninstall.bat
Run the MICAudio_DAX driver install batch file:
SmartSDR_MICAUDIO_DAX_install.bat
Close the command window
Reboot the PC
BA7CK
UID:21
14244小时
管理员
发表于: 2018-08-02
无聊的围观
bi1eyg
UID:436642
182小时
发表于: 2020-04-29
管用,能解决问题!!
QQ:582572627,Email:dtklf@21cn.com
RIG:八重洲FT-857D FT-991A ANT:PAC-12天线;
