  • 2940阅读
  • 2回复
ST公司汽车AB类音频功放选型指南 [复制链接]
离线BG0APD
只看楼主 倒序阅读 0楼 发表于: 2017-12-18
ST offers a complete class-AB product portfolio. As well as standard class-AB power amplifiers, ST proposes audio amplifiers in class SB (Single-ended Bridge) and SB-I (SB improved). As a result of their high efficiency, these classes reduce power dissipation by up to 50% compared to standard class AB, simplifying thermal management in current power sets. Moreover, ST has introduced a digital input to offer a clean sound, immune to external interferences. Amplifiers can now be directly connected to the DSP output without any signal conversion. ST also proposes amplifiers that are compatible with start-stop and hybrid engines.
ST's class-AB automotive audio amps offer:
Clean, powerful audio
A wide portfolio, single-channel devices to powerful quad-channel single-chip devices
Robust designs with integrated protection against short circuits, ESD, load dumping, over-temperature
Ability to drive very low impedance speakers (as low as 1 ohm)
Products compliant with new stop-start engine and hybrid engine standards
Optional I²C interface and diagnostics
Optional digital input
Optional augmented efficiency
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 1楼 发表于: 2017-12-18
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 2楼 发表于: 2017-12-18
邮箱:BG0APD@163.com
电话:15309910960
