  • 4588阅读
  • 8回复
手把手教你做SDR. [复制链接]
离线net2000
只看楼主 倒序阅读 0楼 发表于: 2017-11-27
离线bd7imm
只看该作者 1楼 发表于: 2017-11-27
看着这繁星点点的板子... 多少只手把手....
作者写了,要焊600多个贴片......
GenesisRadio G11 SDR  板子:$300
(G11 Multiband HF and 6m SDR S/H Sample and Hold Transceiver <2012>)
  • 1. LF version: 137 KHz or 500 KHz (RX 50KHz – 2MHz)
  • HF version: covers up to 5 HF bands, depending on BP/LP filters selection.
  • 160m monoband. 6m monoband.
  • 2. Min synthesizer step: 1Hz, adjustable.
  • 3. All-mode CW/SSB/FM/ DIGITAL *
  • 4. IIP3 30-32dBm *
  • 5. MDS is -116 to -122dBm * RF preamplifier on: MDS is from -130 to -133dBm. *
  • 6. Image rejection: -35 to -60 dB [hardware], better than 60dB [software]
  • 7. RX sensitivity: 0.15-0.2uV for 10 dB S/N ratio. Max S/N measured: 70dB.
  • 8. SFDR (Spurious free dynamic range) is 93-100dB these results are with signals
  • spaced 5 kHz or more.
  • 9. Receiver 1dB compression point is + 5dBm
  • 10.Second antenna RX2 input
  • 11.Support for transverter with split RX input.
  • 12. Transmitter output power is 10W min (5W on 6m) and it is adjustable in software to
  • almost 0W. Transmission is possible only on amateur bands
  • 13. TX carrier suppression: 45-60dBc [hardware]
  • 14. Image rejection: -35dBc to -50dBc [hardware], 60dB with GSDR SDR software
  • 15.Built in microphone preamplifier with adjustable 2 position gain to enable operation
  • with with single-input sound card [LINE IN or MIC in]
  • 16.Built in IAMBIC CW keyer with independent CW monitor
  • 17.Control circuit for keying RF linear power amplifier
  • 18. Power supply +12V to +14V @3.5A
  • 19.Specified operating temperature range is from 0C to +55deg C
  • 20. Dimensions 240 x 240 x 88mm weight 1.5kg
  • 21.Kit assembly: 5-8 hours **
  • 22. G11 control via USB connection with GSDR software running on XP, Vista or WIN7 OS
Genesis G59:  套件:$399
(All Mode 160-6m SDR Transceiver Kit)
"The Best SDR Kit on the Amateur Radio Market"
Receiver:
  • adjustable synthesizer with 1Hz step, IIP3 32-35dBm,
  • MDS: -116 to -122dBm (RF preamplifier ON: -132 to -134dBm.).
  • RX Sensitivity is 0.15-0.2uV for 10 dB S/N ratio and max S/N measured ratio is 70dB.
  • Image rejection is from -35dBc to -50dBc (hardware) or better than -80dBc (hardware + software). SFDR (Spurious free dynamic range) is 93-100dB or over 100dB for G59C.
  • Receiver 1dB compression point is + 10dBm.
  • Second RX antenna input.
Transmitter:
  • G59 output power: 10mW, GPA10 output power: adjustable 0-10W.
  • Carrier suppression is from 45-60dBc (hardware).
  • TX Image Rejection is from -35dBc to -50dBc (hardware) or better than 60dB with GSDR software.
  • G59 has built-in microphone preamplifier, IAMBIC keyer with CW monitor.
[ 此帖被bd7imm在2017-11-27 17:48重新编辑 ]
☃  I aM on Mountain top
    −••• −•• −−••• •• −− −− 居然被你发现了,看来这个惊天秘密必须告诉你了:二战结束后SSB单边带模式开始出现在业余界,流行方案是用一块昂贵的9M晶体滤波器和5M的VFO进行混频,能同时支持9-5=4MHz的LSB和9+5=14MHz的USB.于是这个传统被延续了下来,低于10MHz的波段用LSB低边带,高于的用USB高边带
离线bd4ahs
只看该作者 2楼 发表于: 2017-11-27
这个核心跟郁金香差不多,都是avala。。
BD4AHS
ex: BG4AHS、BG1HS/4、BG1HS、BG1-1-0817
秦岭/Qinling
96-97年 BG1-1-0817
97-99年 member of BY1BY / BG1HS
99-2000年 BG1HS/4
2000-2006年 BG4AHS
2006年~ BD4AHS
QTH: http://aprs.fi/?call=BD4AHS
离线bh1swf
只看该作者 3楼 发表于: 2017-12-17
是完全开源的吗?
离线bg6qbt
只看该作者 4楼 发表于: 2017-12-18
能做个玩玩吗??
QQ:58822205
离线徐徐2009
只看该作者 5楼 发表于: 2017-12-18
真的要手把手,,,
QQ616710081  旺旺:电源学习网
ATS20 ATS25 ATS100 收音机
高频假负载
7.023MHZ 晶振    7.050MHZ 晶振
 DIY 6波段电台
25欧功率合成馈线
手动 自动  50w 短波功放  FT-817功放
离线BG6JJI
只看该作者 6楼 发表于: 2017-12-18
采购够累的
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 7楼 发表于: 2017-12-22
我水平低,怎么找不到说明ADC的位数?
我读书少  不要骗我
离线bg4iww
只看该作者 8楼 发表于: 2017-12-22
看到贴片就头疼。不是觉得难焊,而且看起来真的很累
BG4IWW
山东日照——蓝天,碧海,金沙滩,太阳升起的地方
