  • 5403阅读
  • 5回复
SDRPlay RSP2 高级应用--测量射频功率 [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2017-04-01
SDRplay RSP2 经过实验 精度不错的 测量射频信号功率电平,再一次体现为什么他叫作 ”无线电频谱仪“,作为业余条件可以作为测试仪器使用,不单单简单的SDR接收机
可以作为现场方便的”无线电测试仪“ 测试参考
视频 看不了自己想办法
https://www.youtube.com/watch?v=MRR-x_TjOp4&feature=youtu.be
[ 此帖被BA2Bi在2017-04-01 21:11重新编辑 ]
离线BA2Bi
只看该作者 1楼 发表于: 2017-04-01
Making accurate RF Power measurements using the RSP2 in the field
http://www.sdrplay.com/making-accurate-rf-power-measurements-using-the-rsp2-in-the-field/
The cost of wirelessly connecting IoT devices continues to fall rapidly thanks to the fact that Moore’s Law is still just about alive and well.  This means integrating more and more smart sensors to some form of low bit-rate wireless connectivity as offered by the likes of Sigfox, Weightless or LoRaWAN  technologies continues to be a popular quest.  This in turn means new and interesting challenges for network developers and OEMs.   Network coverage, especially where ‘fire and forget’ or ‘best endeavor’ techniques are used,  becomes increasingly important.
Thus the availability of low cost and reasonably accurate RF power measurement equipment is needed in the field, to allow remote monitoring prior to full deployment.  As well as designing reliable antenna and transmission systems, there is also the need to analyze and indeed identify sources of interference within the spectrum allocated for the operation of such IoT networks.    On both these fronts the RSP2 works very well as demonstrated in this video:
SDRplayRFPowerMeasurement
只看该作者 2楼 发表于: 2017-04-02
只会翻书不会翻;墙
离线BG5ILE
只看该作者 3楼 发表于: 2017-04-20
RSP1不能做射频功率测量和简易频谱吗?
离线BA2Bi
只看该作者 4楼 发表于: 2017-04-21
回 胡海峰 的帖子
胡海峰:RSP1不能做射频功率测量和简易频谱吗? (2017-04-20 09:52)
也可以的
离线bd3af
只看该作者 5楼 发表于: 2024-05-21
