  • 7595阅读
  • 16回复
复刻open-interface 基于Arduino的radio link和CW keyer [复制链接]
离线汤圆
只看楼主 倒序阅读 0楼 发表于: 2017-03-27
看这个挺好
硬件上用了usb隔离 用了usb终端 emi 过滤  稳定性应该不会太差  想复刻个小的   把arduino 换成pic单片机   去掉键盘功能 用上位机控制 存储的呼叫内容   搜集了一些东西 时间合适就开搞
还是开源
坑我先挖好,我选了选器件 结果发现跟这个 open-interface  一样的方案了  所以就叫复刻吧
Linker Keyer  Parts Selection
USB Hub    TUSB4041I-Q1    Automotive Four-Port High-Speed 480Mbps USB 2.0 Hub
USB2UART Bridge    CP2102/9    SINGLE-CHIP USB-TO-UART BRIDGE    PS: Internal 24MHz Osc
    FT232R
    LTM1884    Isolated USB Transceiver with Isolated Power    VERY high cost
    ADUM3160    Full/Low Speed USB Digital Isolator
    ADUM4160    Full/Low Speed 5 kV USB Digital Isolator
Keyer Controller    PIC18(L)F2X/4XK22    28/40/44-Pin, Low-Power, High-Performance Microcontrollers with XLP Technology    PS: XLP Tech Low Power Low EMI
High PSRR  LDO    LT3045    LT3045 - 20V, 500mA, Ultralow Noise, Ultrahigh PSRR RF Linear Regulator    Ultra Low Noise, Ultra High PSRR, > 50dB @ 10MHz
    LP38798    LP38798800-mAUltra-Low-Noise, High-PSRRLDO
EMI Filter Line Termination    USBDFxxW5    EMI filter and line termination for USB downstream ports
    STF202    EMI Filtering, USB Upstream Line Termination and ESD Protection
    PACUSB−D1/D2    USB Downstream Port Terminator
Isolated Low Noise DC DC    LTM8048    3.1VIN to 32VIN Isolated μModule (Power Module) DC/DC Converter with LDO Post Regulator
还有一些usb 抗干扰设计技术文档
Docs
Intel EMI Design Guidelines for USB Components      http://www.ti.com/sc/docs/apps/msp/intrface/usb/emitest.pdfIntel High Speed USB Platform Design Guidelines    http://www.usb.org/developers/docs/hs_usb_pdg_r1_0.pdf
    NXP ESD protection for USB 2.0 interfaces AN10753    http://assets.nexperia.com/documents/application-note/AN10753.pdf
DESIGN AND SIMULATION OF INTEGRATED EMI FILTER    http://www.scs-europe.net/dlib/2016/ecms2016acceptedpapers/0270-is_ECMS_0135.pdf
USB Hardware Design Guide AN0046 - Application Note    https://www.silabs.com/documents/public/application-notes/AN0046.pdf[table=1363,#ffffff,,0][/table]
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
剑桥大学集体台 G6UW 成员:www.g6uw.org
MDO MMDVM 和 HAM Pi 项目: bg3mdo.ts-ham.com
欢迎访问唐山业余无线电:www.ts-ham.com
曾经的约克:www.atyork.com
业余无线电技术群:416460403
离线BH3NEK
只看该作者 1楼 发表于: 2017-03-27
期待进度。
楼主给的链接有的打不开,是不是需要梯子呀
[ 此帖被BH3NEK在2017-03-27 08:35重新编辑 ]
呼号:BH3NEK
直频:145.100MHz
中继: 439.125MHz-8 亚音103.5
          147.925MHz-3.8 无亚音
          APRS:144.640MHz
承德ham微信号:CDHAM01
QTH:河北承德开发区
离线汤圆
只看该作者 2楼 发表于: 2017-03-27
估计要梯子吧
补充句
ftdi 可能不会用 假货也多 cp212x 可能会用
比较不能接受的是ftdi 前几年砖赝品事件
ssb呼叫cw呼叫 可以考虑弄个sd卡上 查个数字键盘  按键放盒子上本来不方便
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG7NQF
只看该作者 3楼 发表于: 2017-03-28
个人建议CH340......
离线汤圆
只看该作者 4楼 发表于: 2017-03-28
回 BG7NQF 的帖子
BG7NQF:个人建议CH340...... (2017-03-28 02:13)
Linux和Mac上 驱动不太好吧
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG5TOX
只看该作者 5楼 发表于: 2017-03-28
FT232RL比较靠谱
Callsign:BG5TOX (微信同号)
QQ:327586364
离线bi4sqm
只看该作者 6楼 发表于: 2017-03-28
我打了几篇open interface的板子,实验中。。。
离线汤圆
只看该作者 7楼 发表于: 2017-03-28
回 bi4sqm 的帖子
bi4sqm:我打了几篇open interface的板子,实验中。。。 (2017-03-28 17:49)
很不错  目前盒子 对抗干扰都不行  这个应该open interface的不错 但是太大了  存储按钮在盒子上 不方便操作 没有ssb 并且呼叫器
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG4RFF
只看该作者 8楼 发表于: 2017-03-28
回 汤圆 的帖子
汤圆:Linux和Mac上 驱动不太好吧
 (2017-03-28 07:03)
安卓和limux的驱动都可以在江苏沁恒找到
BG4RFF
江苏如东、四川泸县
BG4RFF#163.com
QQ:4俩8拐拐勾4勾
手机:妖怪怪儿,五个妖狗动钩钩(防止恶意电话,先短信联系)
离线BG7NQF
只看该作者 9楼 发表于: 2017-03-29
回 汤圆 的帖子
汤圆:
Linux和Mac上 驱动不太好吧
OS: ubuntu-kylin  16.04 LTS  live CD version
Chip: CH340G
It can be detected and driver will be installed. Device name is ttyUSB0.
See attach screen snap for more information.
I tested in minicom for real communication. It worked well in 115200 bps.
Sorry I could not find Chinese IME in Live CD.......and also sorry for my poor ENG....
离线汤圆
只看该作者 10楼 发表于: 2017-03-29
回 BG7NQF 的帖子
BG7NQF:OS: ubuntu-kylin  16.04 LTS  live CD version
Chip: CH340G
....... (2017-03-29 01:21)
精彩 精彩 精彩
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG7NQF
只看该作者 11楼 发表于: 2017-04-05
回 汤圆 的帖子
汤圆:精彩 精彩 精彩  (2017-03-29 06:40)
后续进展如何呢
离线汤圆
只看该作者 12楼 发表于: 2017-04-06
回 BG7NQF 的帖子
BG7NQF:后续进展如何呢 (2017-04-05 21:01)
选了选元器件 正在开始电路图
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG7NQF
只看该作者 13楼 发表于: 2017-04-15
回 汤圆 的帖子
汤圆:选了选元器件 正在开始电路图 (2017-04-06 05:12)
寻求一位MAC OS X 用户,测试一下CH340在OSX下兼容性。。。
离线汤圆
只看该作者 14楼 发表于: 2017-04-15
mac
用户 但是我没有ch340...
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
离线BG7NQF
只看该作者 15楼 发表于: 2017-10-19
回 汤圆 的帖子
汤圆:mac
用户 但是我没有ch340... (2017-04-15 06:41)
我去,原来又在这里碰头了。。。。。
我的CH340已经测试完毕,可以正常使用。WCH有 OS X下面的驱动包,装上即可。
在xcar那边看到你的帖子,我也有一片VCDS 5053线出了问题,搜到你的帖子,深入挖掘了一下呵呵。没想到在.net找到你:哈哈缘分呐
离线汤圆
只看该作者 16楼 发表于: 2017-12-04
回 BG7NQF 的帖子
BG7NQF:我去,原来又在这里碰头了。。。。。
....... (2017-10-19 13:05)
真是缘分
大陆呼号:BG3MDO
英国呼号:M6IDO
OP: 王原
QTH: 英国 剑桥
业余无线电技术群:416460403
