  • 5730阅读
  • 2回复
Android 游戏 Morsey [复制链接]
离线BG0GE
只看楼主 倒序阅读 0楼 发表于: 2016-07-26
Morsey: Morse Code Typing Game
Now with Google Game Services, including a Leaderboard and Achievements! The fastest, funnest, way to learn Morse Code!
Morsey is a Morse Code Typing Game for Android, which will teach you Morse Code faster than any other game on the Play store.
Check out: http://morsey.yolasite.com/
★ Type Morse Code by tapping on the surface area
★ Use the HINT button to display Morse Code for letters
★ Hit the lightning button to quickly submit the Code
★ See if you can get the top score for the day
Further game details:
During the game, tiles drop at random speeds, which the user must type before they hit the bottom
bar. Tile speed increases as the user correctly types in Morse codes. Tiles may have extra effects,
currently these are:
• Score multipliers (x3, x5, x10)
• Freeze effect (freezes all tiles for a few seconds)
• Brick effect (the user must type in the code twice for such a tile)
• Swirl effect (removes all tiles from the window, allocating points)
• Heart effect (gives a player an extra life, up to a maximum of 10 lives)
You start with 3 lives, and lives are lost if a tile hits the bottom. Points are allocated to
alphabet letters according to difficulty (denoted by colour):
• E, T, A, M, I, N, S – Pink – 10 points
• H, R, D, L, C – Yellow – 20 points
• U, O, W, F, G, Y – Blue – 50 points
• P, B, V, K – Purple – 80 points
• Z, J, X, Q – Orange – 100 points
官网
邮箱地址:BG0GE@163.COM
137二0五4陆2零五
离线BD4DLN
只看该作者 1楼 发表于: 2016-07-26
https://play.google.com/store居然能访问了
https://plus.google.com  居然也能访问
[ 此帖被BD4DLN在2016-07-26 13:20重新编辑 ]
离线bd1gk
只看该作者 2楼 发表于: 2018-01-09
连接被重置,无法打开官网呀,能帮忙上传附件么?
