  • 3213阅读
  • 5回复
SmartSDR 新版  v1.8 or v2.0 ... v1.8.3.167已发布 [复制链接]
只看楼主 正序阅读 0楼 发表于: 2016-06-29
[ 此帖被BG4DRL在2016-07-04 01:23重新编辑 ]
只看该作者 5楼 发表于: 2016-07-03
SmartSDR v1.8.3 Now Available for Download
-  DAX v1.8.3.167
-  SmartSDR CAT v1.8.3.167
The cumulative SmartSDR v1.8.3 ecosystem Change Log detail is listed below.
  v1.8.3 2016-06-30
General release of SmartSDR for Windows.
v1.8.2 RC 2016-06-24
#3622    Firmware: Mic audio will transmit even if DAX is enabled unless DAX is actively streaming.
#3718    SmartSDR for Windows: Installer no longer installs DAX drivers when the DAX option is unchecked.
#3721    Maestro: Direct frequency entry on Slice B menu now functional.
#3696    Maestro: GPS menu no longer appears when using a FLEX-6300.
#3713    Maestro: Slice AGC controls in the Audio menu now become Squelch controls when in FM mode.
#3701    Maestro: WiFi now supports these characters in the SSID and/or password: , " ' < > &
#3727    Maestro: Diversity controls in Audio menu are now greyed out when the parent Slice does not exist.
#3684    API: Fixed Vita49 info class typo.
v1.8.1 Alpha 2016-06-16
#3597    Firmware: Various fixes under the hood to address random radio crashes (sometimes with ~400 Hz tone afterwards)
#3602    Maestro: (6700 only) Can now access Diversity Slice Volume and AGC controls in the Audio menu.
#3485    Maestro: VFO B knob now controls VFO A RIT or XIT if Slice B is not present.
#3676    Maestro: Renamed MEM buttons on TX menus to ATU MEM for clarity.
#3626    Maestro: Fixed 'Radio not found' error when updating to a new version.
#3652    Maestro: Slice RX filter knobs no longer appear to change the filter when in FM or NFM modes.
#3666    SSDR for Windows: changed radio connection lost message if the client was disconnected by another user.
#3673    SSDR for Windows: radio upgrade failure message is now more descriptive.
v1.8.0 Alpha 2016-05-27
#3505    Firmware: Users can now disconnect users that are currently connected to a radio.
#3494    Maestro: It is now more difficult to accidentally unmute a Slice immediately after muting it by long-pressing the AF knob
#3644    Firmware: Added automatic power foldback for high SWR situations (starting at 25 W reverse power)
v1.7.34 Alpha 2016-05-25
#3657    Firmware: Fixed missing CW sidetone.
#3610    Firmware: Waterfall black level is now restored properly on startup.
#3566    CAT: Added checks to prevent UHE when disconnecting.
#3615    Maestro: Waterfall time labels 1:00 and greater are no longer cut off.
#3625    Maestro: Battery indicator no longer remains visible after the external battery has been depleted.
#3432    Maestro: Fixed Maestro Display menu button not responding to touch input after radio disconnect/reconnect.
#3565    Maestro: Fixed a UHE when unplugging the charger from the Maestro.
#3629    Maestro: Can now change Slice frequency when in Diversity Slice menu.  Fixed UHE when touching inside Diversity Slice menu.
#3599    Maestro: Fixed slow Maestro startup when the Maestro server is not available.
#3598    Maestro: Network status text in lower left of startup now differentiates between availability of internet and the Maestro server.
v1.7.33  2016-05-11
#2901    Maestro: Knob encoder reversal improved.
#3434    Maestro: Added control to disable Mic2 PTT.
#3340    Maestro: It is now harder to accidentally change frequency when pressing a VFO knob.
[ 此帖被BG4DRL在2016-07-03 13:18重新编辑 ]
在线爱不交租
只看该作者 4楼 发表于: 2016-06-30
据说还是1.6好用
只看该作者 3楼 发表于: 2016-06-30
离线BD7MYM
只看该作者 2楼 发表于: 2016-06-30
离线BA7NQ
只看该作者 1楼 发表于: 2016-06-30
SmartSDR软件,是一个单独的产品。
当前,购买6300/6500/6700的用户,都可以获得SmartSDR 1.X版本的使用授权。
当SmartSDR的新产品2.X出来后,如果1.X的用户要升级到使用2.X,需要付费升级。
这个就好像你购过微软Windows XP的使用许可,要升级到Windows 7,需要给一定的升级费,在升级到Windows 10,还需要给一定的升级费。
